RS2/ PRO-FPJ1 Owners: Setup Discussion Thread - Page 144 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #4291 of 4315 Old 02-29-2016, 10:42 AM
marchewd's Avatar
Quoted: 20 Post(s)
I have attached the troubleshooting page. It says with the lamp indicator light blinking and the warning light on that it's either Lamp does not light up and the unit is unable to project, lamp is turned off during projection or lamp cover is removed. However, it doesn't say what to do or what could be causing it. I have unplugged it for several hours and when I plugged it back in, it says the same thing. I know the lamp and lamp cover are installed properly since it has been working fine for the last 400+ on the bulb. However, just to be safe, I tried two older bulbs as well as my two spare bulbs and I get the same error on the projector. The fan doesn't even kick on. Once you press the power button, it immediately kicks on the warning light and lamp light starts blinking.
marchewd is offline
post #4292 of 4315 Old 02-29-2016, 11:22 AM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3595
Originally Posted by marchewd View Post
Hey everyone, I went to turn on my projector today and I get red lights on the standby/on and warning indicators. The lamp is blinking orange. I have tried using my two new bulbs as well as two bulbs I pulled due to hours. The current bulb is only at 300 hours. Doesn't matter which bulb I try I still get the same result when trying to power on the projector. I have tried different outlets as well. Anyone have any ideas?
Sounds like you have a choice to make. Send in for out of warranty repair or purchase a new projector.
mjgarrett100@gmail.com
Mike Garrett is offline
post #4293 of 4315 Old 02-29-2016, 11:28 AM
marchewd's Avatar
Quoted: 20 Post(s)
Yeah, that's what it's looking like. Just terrible timing to make a purchase!
marchewd is offline
post #4294 of 4315 Old 02-29-2016, 11:47 AM - Thread Starter
CCLAY's Avatar
I wonder if you have a fan problem? It makes sense the lamp wouldn't light if the fan does not turn on.
My Home Theater is a work in progress.
CCLAY is offline
post #4295 of 4315 Old 02-29-2016, 12:39 PM
marchewd's Avatar
Quoted: 20 Post(s)
Probably just need to pull it off the ceiling and open up the unit. Just a PITA to do that! LOL
marchewd is offline
post #4296 of 4315 Old 02-29-2016, 08:40 PM
marchewd's Avatar
Quoted: 20 Post(s)
I talked to my local Pioneer Elite service center and the owner was nice enough to tell me things to try from the service manual. It turns out it was the lamp door latch sensor was acting up. I used a screwdriver to depress it a few times then blew a very quick blast of compressed air on the sensor. Put the lamp door back on and fired up the projector. Came right back to life thankfully! Just wanted to let everyone know what to try if they ever encounter the same issue I had. Thanks again for everyone's help today!
marchewd is offline
post #4297 of 4315 Old 03-01-2016, 12:24 PM - Thread Starter
CCLAY's Avatar
Glad it was something minor
CCLAY is offline
post #4298 of 4315 Old 03-16-2016, 07:42 AM
BigCity's Avatar
Anyone point me to a specific post in this thread with a comprehensive settings list before I begin the journey through 144 pages of info? Had an unfortunate incident with my neice a few weekends ago and all my settings were "adjusted".
BigCity is offline
post #4299 of 4315 Old 03-16-2016, 12:33 PM - Thread Starter
CCLAY's Avatar
I posted some info on the first page if that helps
CCLAY is offline
post #4300 of 4315 Old 04-07-2016, 04:55 PM
Basa14's Avatar
Quoted: 24 Post(s)
I'm in the process of retiring my loyal FPJ1 as I am getting a new PJ. I'm keeping the FPJ1 as a backup but cannot find the lens cover. Does anyone know what the part # is for one? JVC sells them on their web page:
http://store.jvc.com/catalog.php?cat_id=S103&page=1
Would the one for the HD1 fit the FPJ1?
Thank you for your help,
Basa14
Basa14 is offline
post #4301 of 4315 Old 08-10-2016, 06:49 AM
KauffD's Avatar
Just replaced my first bulb, and the resetting of bulb life didn't take. That really doesn't bother me though. The projector runs great, but I can't get a HDMI source to show up. Tried directly linking from ps3 to pj, but still nothing. It worked perfectly until then. Did I change something when I tried (multiple times) to reset the bulb life?
I'll have to buy another HDMI cord to see it that helps.
KauffD is offline
post #4302 of 4315 Old 08-11-2016, 11:11 AM
KauffD's Avatar
Update.
Unplugging the power has reset the projector, but it the lamp counter hasn't reset...
Oh well; at least I didn't have to upgrade.
KauffD is offline
post #4303 of 4315 Old 10-11-2016, 01:23 PM
temery's Avatar
I'm hoping someone can help out with this old projector here -
I recently got a JVC RS2 for next to nothing - I was replacing an old 720p DLP Mitsubishi projector so I was happy to take it. (this also shows i'm not overly picky on the PQ!)
I use my setup for Sports, Video games, TV, movies, in that order.
After getting this projector setup, I cannot, for the life of me, get the projector to focus properly. I can get to the focus menu on the test screen, and it goes from slightly blurry to very blurry, but I cannot get it nice and clear. I've left if at the best possible spot but words are clearly blurry and its still noticed during sports and movies/games etc.
I am not sure if there is much I could troubleshoot to try and fix this issue? Would it be a result of just needing to be cleaned, and if so, how do I go about that?
If the bulb was significantly old would that cause this? I would think the bulb would only get dim (it doesn't appear to be dim) or have poor colors if it were a cheap knockoff (colors look great)... is there anything I could try out to fix this before I dump it off?
temery is offline
post #4304 of 4315 Old 10-11-2016, 04:09 PM
mhdiab's Avatar
Quoted: 60 Post(s)
Liked: 38
Is the lens clean? Use proper product if not
mhdiab is offline
post #4305 of 4315 Old 10-12-2016, 08:33 AM
temery's Avatar
Not sure I only mounted it and played with the settings a little - after some searching it appears there is some parts I should try to clean up - I've been trying to find a thread with some pictures to get an idea of how to do it (and what to use) but so far every thread i come across is in another language and the pics are gone.
temery is offline
post #4306 of 4315 Old 10-12-2016, 09:30 AM
mhdiab's Avatar
Quoted: 60 Post(s)
Liked: 38
mhdiab is offline
post #4307 of 4315 Old 12-26-2016, 09:43 PM
jmadden91's Avatar
Liked: 0
Hi guys, I've just picked up a second hand rs2, there doesn't seem to be any lens shift nobs underneath. It's labled as an rs2-g. There are 2 holes where it looks like they should be. Would there be any reason for them to be missing?
jmadden91 is offline
post #4308 of 4315 Old 12-27-2016, 09:51 PM - Thread Starter
CCLAY's Avatar
Wow, been so long since I fiddled around there. If memory serves, some of the earlier models had manual lens shift. I believe the G series went to all remote controlled lens up/down left/right shift.
CCLAY is offline
post #4309 of 4315 Old 02-11-2017, 11:18 AM
JosephF's Avatar
I'm getting close to needing a new lamp for my RS2. Are they still available and if so where is the best place to get one these days?
JosephF is offline
post #4310 of 4315 Old 02-13-2017, 11:01 AM - Thread Starter
CCLAY's Avatar
They are. I have a new bulb still in the box that I need to install here in the near future. I believe it's a Osram brand bulb. I will get the number off the box and post it here. Or do an 'Osram' search in this thread. There has been lots of good posts here on 'how to' replace.
CCLAY is offline
post #4311 of 4315 Old 02-13-2017, 04:48 PM
limulus's Avatar
Have you guys been waiting until they blow or does the quality just go to crap? I'm still on an original lamp after all these years. But we don't use ours so much.
Formerly known as J--- H----. Member since 11/2002. My real name was showing up in Google too much!
What we have heah...is a failyah to communicate.
limulus is offline
post #4312 of 4315 Old 02-13-2017, 07:10 PM
Midwest User1's Avatar
Originally Posted by KauffD View Post
Update.
FYI to reset the lamp timer you have to follow the instructions in the manual while the projector is turned OFF (manual doesn't state that it needs to be off).
Midwest User1 is offline
post #4313 of 4315 Old 02-15-2017, 07:44 PM
JosephF's Avatar
Can you get them already installed in a housing? Even though I have no problem with doing a little soldering, I really don't want to deal with it.
Frankly at that point I'd just spend the extra $$$ and get an OEM replacement.
JosephF is offline
post #4314 of 4315 Old 02-16-2017, 11:33 AM - Thread Starter
CCLAY's Avatar
https:/www.amazon.com/JVC-DLA-RS2-Replacement-Projector-BHL-5009-S/dp/B0017OK2S8
I believe this is what you're looking for.
I called Osram and they really don't have much anymore on the RS2 bulbs. I guess we should buy up what we can now for the future if we are to keep our projectors.
CCLAY is offline
post #4315 of 4315 Old Today, 05:29 AM
JonJonson's Avatar
Liked: 0
Hey guys, I recently got a RS2 projector. Without the remote unfortunately, and when I tried adjusting the focus/zoom with the onboard controls, as per users manual, nothing happens.
Is the remote control necessary for such changes (which wouldn't make sense) or could my focus/zoom mechanism just be broken?
JonJonson is online now
