BenQ W 5000 little Test - Page 172 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #5131 of 5154 Old 09-23-2012, 04:40 PM
FeliCumbe's Avatar
Excellent settings ran those just now.
I reference using the Avengers right at the 32 minute marker...there's red hair...blue jeans...red shirt....lots of brown a little later as well as tan shoes on Banner all while they are in the sun.
Also used Prometheus right up until the title is shown there are red cells dividing and the red hues are a good marker....the aliens face on the mountain as well is a blueish hue good sharpness makes u feel like a dermotologist as your watching.
I really liked your settings. I saved it to ISF night. Does that mean that unless unless I run ISF night profile it will not use those rgbycmw settings?
I had my own concoction which I liked to run under whisper mode becuz I found that normal for my eyes anyway was always a bit too bright.
Anyway I know for certain the color temp changes should work via any profile...I switched between the two...yours(isf night) and my previous. And they are somewhat alike except mine does not let things hide in black as well.
The main difference tho is that I am now running Normal lamp and I dont find it as offensive as before.
These are my saved profiles settings which have def been enhanced with something from your settings....even if it is not running the saved isf night rgbycmw profile settings altho id like to think that it is:
picture tab basic:
bright 49
contrast 55
color 68
tint 0
sharp 6
picture adv tab:
Black 0 ire
Clarity -> detail enh +3 , chroma and luma +1
ct normal
gamma 2.2
bc off
color management......all colors range 0 all colors Saturation +51
dyn blk on
Iris 9
It is very similar to your settings,... colors run a slight nudge hot...but in IRE 0 the blacks are just black enough to define black but the shadows dont just hide things in darkness so easily.
Even more impressed than before so im certain in the minimum your ctemp nudges have helped...and id like to know if your CCA settings are still contributing here.....this is a real sweet spot...i can watch both these flics all over again.
Give it a try if you get a chance...I realize the color setting may seem high but it renders beautifully. Thanks again im able to run Normal lamp much more agreeable than before.
-Felipe Cumberino
Benq W5000 on a DA-Lite- Adcom GFA 555- Adcom GFP 710 - Oppo BDP-83 - Polk Monitor 10's fully upgraded audio grade xo's. -WDTV Live -Samsung flatscreen part time and non movie duties. Happy Happy Happy.
FeliCumbe is offline
post #5132 of 5154 Old 11-01-2012, 03:29 AM
Big Lebowski's Avatar
Quoted: 18 Post(s)
Originally Posted by maxleung View Post
Anyone have an issue where there is a slight outline around colors? For example, if there is a solid line on a white background, there is a slight halo to the left and right of it (but none at the top and bottom). I have the values in the clarity control set to 0, sharpness set to 3, and yet the halos are still there!
On my PC (RGB mode) this is a simulation of what it looks like, zoomed in:
The outline is ALWAYS two pixels to the left and right of a strong color. There is never anything on top or bottom.
I've tried all kinds of settings in the service menu (playing with color wheel index, sharpness settings, clarity controls) and I can't seem to get rid of it. It bothers the heck out of me, even though during movies it seems to be ok at my normal viewing distance.
Any idea why my W5000 is doing this? The effect is not seen on my other displays, so it isn't a display driver issue on my PC. I even tried different graphics cards.
Text looks really odd because of this - especially if the text is red or purple on a white background - makes it look fuzzy!
Have you ever tried feeding 4:2:2 YCbCr to your W5000 and see if it makes any difference in this case?
I guess also one thing worth to try would be testing chroma resolution patterns using Spears & Munsil test disc and see if there is any difference in chroma resolution between RGB, YCbCr 4:2:2 and YCbCr 4:4:4.
Big Lebowski is offline
post #5133 of 5154 Old 11-23-2012, 11:44 AM
leeperry's Avatar
Originally Posted by Big Lebowski View Post
Originally Posted by linskun View Post
So, you suggest to use 100% saturation Color window for measuring value and 75% saturation Color windows for desired value.
Yes. I would also suggest not to try forcing primaries at 100% saturation levels too much but to consider also lower saturation poi0nts 0-75%.
So my workflow for CCA will be :
- Entering measured value
- Tuning all x,y desired value
That will work.
- Measuring Y of a Color and multiply by the Reference Y
You multiply measured white Y by reference Y for each color.
What i don't understand is : i need to reach the new Y calculated by tuning or simply entering the new Y on desired Y ?
You modify Y by entering new desired Y value then you check is it ok by taking readings and looking at HCFR Y-field. To check if they are correct is to compare each color (RGBRYM) to measured white.
Example: Your white reading in HCFR is 15.000 then your red should be 3.189 and green 10.728 and so on. Then you go to ISF CCA and change your red, green and so on Y-values up or down depending on the readings you just took. Then you again measure all colors and white and again calculate what Y your colors should be compared to white Y. Then repeat procedure.
You need to do this many times because every time you change any Y-value it will make something else moving too. But once you have done this many times your changes are so little that you will reach your goal.
Also remember that adjusting Y's will change x and y so adjust them also during Y adjustments.
Also one in a while take full gray scale readings from 0 to 100%. If it needs to be corrected use ISF CCA white x and y but leave its Y at 1000 always.
Some peoples use service menu color temp settings to adjust that but I rather use only CCA W at that point.
I know this sounds messy but you will get hang of it by following that procedure.
Once you have reached your goal try moving to 0%, 25%, 50%, 75% and 100% saturation measurements and adjustments to get all saturation levels as good as possible. When you get this right you have nearly reference quality display.
Ouh, I was hoping that this would be a whole lot easier =o
I'm about to buy the W1070 that has that ISF menu: http://www.audiovideohd.fr/i/imgs/17106-4.jpg
It's got that CCA table but you can also specify the xyY coordinates of the primaries and secondaries apparently.....so I was hoping to be able to input the Rec.709 gamuts values et voilà? Perfect gamut and 0% drifiting saturations in HCFR? Not quite? I really want the W1070 to abide by the Rec709 gamut.
Thanks for any advice!
leeperry is offline
post #5134 of 5154 Old 11-28-2012, 03:05 AM
leeperry's Avatar
guys, I don't understand....can CCA be used to put back the drifting green primary on the exact Rec.709 xy coordinate? It would appear not, so if this thing can't move primaries, wth is it good for? frown.gif
http://www.avsforum.com/t/957897/benq-w-5000-little-test/2100_100#post_14675366
http://www.avsforum.com/t/957897/benq-w-5000-little-test/4800_100#post_18107521
http://www.hometheatershack.com/forums/home-theater-projectors/17754-benq-w5000-4.html#post160950
That's the W1070: http://www.audiovideohd.fr/album-Benq,W1070/17120.html
http://www.audiovideohd.fr/i/imgs/17120-4.jpg
Apparently, that's a no-go:
You cannot really much expand gamut with ISF CCA controls. Meaning that if you for instance measure blue with SM CCA turned off and it is not reaching Rec.709 x and y, you wont get there playing with desired values. This is normal behaviour for these controls but it does not mean you cannot get pretty much perfect picture. Concentrate also saturation below 100%. If you can get saturations 0, 25, 50 and 75 perfect don't worry if 100% is a little off. It is much better than just having 100% right and others completly wrong.
Ideally I would like to make it spot-on Rec.709 and then map gamuts from SMPTE-C and EBU from within the PC, but apparently that will be impossible =(
leeperry is offline
post #5135 of 5154 Old 07-20-2013, 08:20 PM
Blasst's Avatar
Quoted: 78 Post(s)
Liked: 78
Been awhile since we've had some action in this thread.
Who is still running with their W5000?
Still running mine without any issues for at least 2-3 years if my memory serves me right. Put in a new bulb this year and have been very happy with it. I will wait until 4k gets to a nice price point before I retire the beast from the main viewing room.
Blasst is offline
post #5136 of 5154 Old 07-21-2013, 06:52 AM
meiqupk's Avatar
right,absolute black shouldn't be gamma corrected, just things encoded above absolute black. 12.gif
meiqupk is offline
post #5137 of 5154 Old 07-21-2013, 01:34 PM
Max Headroom's Avatar
Up and running!
Carpe Diem
Max Headroom is offline
post #5138 of 5154 Old 07-23-2013, 02:24 PM
Mike Butny's Avatar
Quoted: 463 Post(s)
Liked: 835
I hope Benq brings back the W5000 body style.
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7009 Receiver, 3-Marantz Ma700 and 2-Ma6100 mono blocks, 9.2 set-up, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, Infinity ( soon to be replaced by B&W ) bookshelf Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, PSA S3600I & S3000I subs, Richard Grey, Monster Power, and Panamax powerline conditioning/surge protection.
Mike Butny is offline
post #5139 of 5154 Old 01-24-2014, 02:59 PM
Blasst's Avatar
Quoted: 78 Post(s)
Liked: 78
I was hoping we would hear something from Benq at CES for some 4K info, but looks like we'll be waiting a bit longer.frown.gif
Blasst is offline
post #5140 of 5154 Old 01-24-2014, 03:16 PM
Seegs108's Avatar
Quoted: 4961 Post(s)
Liked: 2478
Why were you expecting BenQ to make an announcement? There are no consumer 4K DLP DMDs.
Seegs108 is offline
post #5141 of 5154 Old 01-25-2014, 12:05 AM
Bronco70's Avatar
Hey Blasst , so still running with a 5000. long time. I'm using a 6000 for years. about to go to the 3'rd lamp after about 6000 hours still happy not sure what will prompt an upgrade. Remember the old PE7700 thread?
Joe
Bronco70 is offline
post #5142 of 5154 Old 01-26-2014, 01:42 PM
Blasst's Avatar
Quoted: 78 Post(s)
Liked: 78
Not expecting , just hoping they would have something in 4K for us coming up.
Joe
Bronco, glad to see you are still around and kicking my friend, and that your PJ is treating you well. Ya the PE7700 was a massive thread, I still have my original 7700 along with another I picked up for my son and friends gaming in the garage.....lucky punks.biggrin.gif
Blasst is offline
post #5143 of 5154 Old 01-26-2014, 01:51 PM
Seegs108's Avatar
Liked: 2478
You're going to need to petition TI to release a consumer 4K DMD otherwise no one, not even BenQ, can release a 4K DLP projector.
Seegs108 is offline
post #5144 of 5154 Old 04-15-2014, 01:59 PM
Mike Butny's Avatar
Quoted: 463 Post(s)
Liked: 835
I wish Benq would start using using .95 DMD in all their projectors instead of the .65 DMD, I I believe the W5000 was the last time they used the .95.
post #5145 of 5154 Old 04-15-2014, 02:16 PM
Mike Garrett's Avatar
Quoted: 6606 Post(s)
Liked: 4294
Until there are 4K DLP chips, this is not going to happen. Right now the size of the chip is one of the things that separates the higher end single chip DLP's from the lower end single chip DLP's. Even then, it will take a long while to filter down.
mjgarrett100@gmail.com
Mike Garrett is offline
post #5146 of 5154 Old 04-15-2014, 02:51 PM
Mike Butny's Avatar
Quoted: 463 Post(s)
Liked: 835
I currently own the W6000 and had the W5000, I always thought the W5000 produced the sharper picture. The W6000 has it beat in brightness and black levels but I always thought the W5000 was a tad sharper in PQ, I assume it was because of the 0.95 DMD compared to the 0.65DMD in the W6000.
post #5147 of 5154 Old 04-16-2014, 04:40 PM
Electric_Haggis's Avatar
Quoted: 24 Post(s)
I currently own the W6000 and had the W5000, I always thought the W5000 produced the sharper picture. The W6000 has it beat in brightness and black levels but I always though the W5000 was a tad sharper in PQ, I assume it was because of the 0.95 DMD compared to the 0.65DMD in the W6000.
Completely agree. Went from a W5000 to an Optoma HD86, then the W6000.
There's just something about the larger 0.95"
The W7500 and Optoma HD91 are both "2cm" chips.
2cm = 0.78"
How does the 2cm compare ?
Electric_Haggis is offline
post #5148 of 5154 Old 01-17-2017, 08:43 AM
Blasst's Avatar
Quoted: 78 Post(s)
Liked: 78
Was time for a new bulb here also. Picked one up from the link above, and it is as advertised. I had slightly over 2000 hours on the high lamp setting. I have a bat cave so really didn't notice a lack of brightness, though after putting in the new bulb, I had that additional "pop" for brightness back. I'm glad the old 5K keeps putting out a fine image, and am hoping it will keep doing so, until I can afford a 4k PJ down the road.
Well almost 5 years have passed since that post, and I just picked up another bulb for the W5000. Really had no idea I would still be using the same projector for this long. Still waiting for a 4K PJ that I can afford. I bought a LG OLED this year and it is really fantastic. Wish I could have that type of image in the projector right now.
Mike Butny likes this.
Blasst is offline
post #5149 of 5154 Old 01-18-2017, 06:45 PM
stanger89's Avatar
Quoted: 3312 Post(s)
Liked: 1772
You should look at the JVCs, either the 2015 models that are currently on closeout (RSx00), or the new 2017 models (RSx20 models) if input lag is important to you. They'll put your BenQ's image to shame.
stanger89 is offline
post #5150 of 5154 Old 01-18-2017, 10:04 PM
Blasst's Avatar
Quoted: 78 Post(s)
Liked: 78
stanger89,
I started a thread almost 3 years ago asking about what to replace my W5000 with, Replace a Benq W5000 with....? and you had some advice for me there. Which 2015 JVC would you recommend?
Blasst is offline
post #5151 of 5154 Old 01-20-2017, 07:19 AM
stanger89's Avatar
Liked: 1772
I've got an RS600 now, very happy with it, for the most part. Though since I game a bit, I'd grab a new RS520 or RS620.
post #5152 of 5154 Old 06-14-2017, 12:39 PM
GerardA's Avatar
Hi,
My W5000 is still running but the last time I turned it on the startscreen was not blue anymore but purplish.
My lamp has about 2000 hours running time.
Would this be a lamp problem or something with the electronics?
GerardA is offline
post #5153 of 5154 Old 06-14-2017, 06:29 PM
Seegs108's Avatar
Liked: 2478
Originally Posted by GerardA View Post
Hi,
Can you post an image of what the issue looks like?
Seegs108 is offline
post #5154 of 5154 Old 06-15-2017, 03:07 PM
GerardA's Avatar
Hi,
I'm so happy that's not possible anymore! It's working normal again, I hope it stays that way....
Maybe the hdmi-cable was not connected properly or...
It looked like the Green was missing.
GerardA is offline
Benq W5000 Dlp Projector 1200 Ansi Lumens 1920 X 1080 Widescreen Hi , Benq W1070 1080p 3d Projector
