BenQ W 5000 little Test - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #91 of 5151 Old 12-25-2007, 06:31 AM
cbgugu's Avatar
From what i have read, the W10000 is still a better pj than the W5000!
Now that the price has come down to almost the same as the W5000
Which would you buy?
Gilbert
cbgugu is offline
post #92 of 5151 Old 12-25-2007, 06:38 AM
ravenous's Avatar
@Manos: How do you enter the Service Menu for the W5000 ?
The W9000 trick did not work.
HD-EP35 & PS3 & (soon to be) Regionfree Oppo BD-93. 148 : 481
ravenous is offline
post #93 of 5151 Old 12-25-2007, 06:45 AM
kuebler's Avatar
Quoted: 14 Post(s)
Where did you read this?
Falk Kuebler
kuebler is offline
post #94 of 5151 Old 12-25-2007, 09:49 AM
cbgugu's Avatar
from other threads and other sites due mainly to the 24p bug and the color rendition. Do you think the W5000 is a much better pj?
Gilbert.
cbgugu is offline
post #95 of 5151 Old 12-25-2007, 10:03 AM
kuebler's Avatar
Quoted: 14 Post(s)
Gilbert.
Thanks. I don't know, therefore I asked
But I think as tempting a new toy replacing my W9000 may be, it will be better to wait till Cedia for some real step forward (at least I hope so).
Falk Kuebler
kuebler is offline
post #96 of 5151 Old 12-25-2007, 10:09 AM
joflash's Avatar
Gilbert.
Hi Gilbert,
yesterday morning I have spoken to BenQ Support in Germany. Until now they are sure 1080p/24Hz does work properly, an it is due to the players that the automativ mode does not work (by the way the Sharp does have the same problem). If not they did promise an immediate update due to the fact that this is a guaranteed feature that is assured to the User. So don´t worry about that.
Greetings Jo
joflash is offline
post #97 of 5151 Old 12-25-2007, 11:40 AM - Thread Starter
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
Originally Posted by joflash View Post
Hi Gilbert,
Greetings Jo
and you think benq support know what they talk
fact is the w 5000 takes 24p from the sony bd player the pionieer bd player and the ps3 in 24p force but not displays it.
this issure is very common at lcd flat panel displays and also some
pr. have it.
wait for the new febr. issue from audio vision that is a very reliable
magazine in germany.
the also not found all the time 20000:1 cr.
when the pr. have max 8000:1 like "some" webpages
W.Mayer is offline
post #98 of 5151 Old 12-25-2007, 12:19 PM
joflash's Avatar
pr. have it.
Hi Wolfgang,
I don´t know whether they know what they are talking about or not. For me there is simply no - financial - other option than upgrading to the W5000 from my PE8720 hence I "only" pay about 800 Euro.
So I just hope that they can fix this issue. Normally they should be able to
By the way... do you know when the new audio vision will be issued?
Take my best regards.
Jo
joflash is offline
post #99 of 5151 Old 12-25-2007, 02:29 PM - Thread Starter
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
jo
the new feb. issue from this magazin will be out at 11th jan.2008
and the original plan was to have a w5000 test inside.
lets see....
W.Mayer is offline
post #100 of 5151 Old 12-28-2007, 07:15 PM
Himilce's Avatar
For me there is no 1080p/24 issue with this projector. I can see diferences between forced mode 1080/24p and Automatic on a Playstation 3 conected to w5000. The 1080/24p is clearly smoother. So, I guess w5000 owners will need players with "forced 1080/24p" available.
Himilce is offline
post #101 of 5151 Old 12-28-2007, 07:19 PM
sethk's Avatar
Sounds like 1080p/24 is missing from the EDID, hence the need to force the mode. That's an omission, hopefully one that can be addressed via firmware.
sethk is offline
post #102 of 5151 Old 12-29-2007, 06:43 AM
clehner's Avatar
Well, then you can be happy about that as you seem to not have seen the difference between 60Hz and mutiples of 24Hz.
The Benq W5000 does not (repeat: DOES NOT) process 24p with mutiples of 24Hz but with 60Hz or mutiples of 60Hz.
People who do not know the difference should just see somebody who can show them the difference (takes only a couple of minutes).
Regards
Christoph
Contact via Public Profile
clehner is offline
post #103 of 5151 Old 12-29-2007, 06:46 AM
clehner's Avatar
Absolutely, I can confirm that. It is internally processed with the typical 3:2 studders. The projector itself shows 1080p/24, however it is internally converted to 60Hz (or multiples thereof).
OTOH: What the projector can process is 25psf (e.g.) so if you know how to operate an HTPC with BR and HD-DVD you can speed up to 25p without even changing the pitch of the audio (thanks to reclock).
Also: I tried to setup the projector yesterday and it took me about 3 hours to iron out all the funny presets Benq (and the German vendor) seems to regard as 'optimal'.
Regards
Christoph
clehner is offline
post #104 of 5151 Old 12-29-2007, 07:30 AM
pipone39's Avatar
Well,is it fluid or not then?This is what we wait for...
I mean feeding the 5000 with the 24p forced on the ps3.
pipone39 is offline
post #105 of 5151 Old 12-29-2007, 08:43 AM
joflash's Avatar
Christoph,
which projector with the same or better capabilities, same price level would you prefer considering the 24p issue?
joflash is offline
post #106 of 5151 Old 12-29-2007, 08:50 AM
clehner's Avatar
Christoph,
Well, tough question. Direct answer to a direct (tough) question: Mitsubishi HC6000 or for a little more JVC RS1/HD1.
BTW: Both have a much better zoom range than the Benq.
HIH
Regards
Christoph
clehner is offline
post #107 of 5151 Old 12-29-2007, 11:53 AM
joflash's Avatar
Christoph,
Hi Christoph,
thx for your quick reply. HC6000 is about the same level but JVC HD1 is nearly double priced. So that´s what I want to show. It is very tough to get nearly as a good beamer as the W5000 if we consider the pricing. It is so disappointing that BenQ obivously has messed arround with 1080/24p. Otherwise this beamer would be outstanding in its price/performance ratio. I still hope BenQ will fix this problem, but to be honey I doubt that.
Again Christoph, as soon as I am in Berlin I will have a drop at your shop. Would be great to meet you.
Regards
Jo
joflash is offline
post #108 of 5151 Old 12-29-2007, 12:10 PM
Himilce's Avatar
Ok but if you are right...why I can see smoother images when I choose the forced 1080/24 mode on ps3? If the projector converts it to 60hz internally I guess I wouldn´t have to see any diferences between forced 1080/24p mode and the 60hz mode from ps3 because they would be the same.
Himilce is offline
post #109 of 5151 Old 12-29-2007, 03:56 PM
Digital2004's Avatar
deactivate the brilliant color, it's the sce of excessive dithering.
much much cleaner image with BC OFF.
Digital2004 is offline
post #110 of 5151 Old 12-29-2007, 03:59 PM
Movie_Mike's Avatar
HIH
Hi, and if you had to pick a DLP. Which one would that be ?
Thanks Mike
Movie_Mike is offline
post #111 of 5151 Old 12-30-2007, 07:23 PM
manos_kastr's Avatar
David using the Br. Color the image is more impressive but yes the dithering ie "here". Try to decrease the contrast between 40 to 45.
ISF Certified Calibrator
www.perfectimage.gr
manos_kastr is offline
post #112 of 5151 Old 12-30-2007, 07:28 PM
I agree. I have the same problem using either the LG BH100 or Pioneer LX70A.
www.perfectimage.gr
post #113 of 5151 Old 12-31-2007, 05:29 AM
hi Manos
indeed the brilliant color ON no matter its level, increases dithering dramaticly
OFF and it's a much better picture.
yet it's a mono DLP so dithering is still a bit there. well dithering is even there with a DLP: the mirrors movement dithering.
still this is a lot of projector for the price, too cheap.
happy new year !!!
post #114 of 5151 Old 12-31-2007, 06:08 AM
DERG's Avatar
Quoted: 36 Post(s)
Pardon the naive question, but, if the W5000 is used with HQV receiver doing all the video processing, would the W5000 still have 24P dithering issue?
How does the W5000 compare to the W10000?
Marantz VP15s Projector, CIH Man-Cave Home Theater, Marantz SR 8002, Oppo BDP-103 Blu-ray Player, 6 - HSU HB-1 MK2 Front & Surrounds, 1 - HSU HC-1 MK2 Center, 2 - HSU VTF-15H Subwoofers
DERG is offline
post #115 of 5151 Old 01-01-2008, 01:25 AM
joflash's Avatar
hi Manos
happy new year !!!
HAPPY NEW YEAR
What do you consider to be "too cheap"?
joflash is offline
post #116 of 5151 Old 01-01-2008, 05:05 AM
Robert Whitehead's Avatar
Quoted: 130 Post(s)
Liked: 47
The HQV video processing and the 24P dithering issue hve nothing to do with each other.
I would say the W10000 is definitely better. Read Kris Deering's glowng review of the W10000 at www.hometheaterhifi.com
Robert Whitehead is offline
post #117 of 5151 Old 01-01-2008, 05:29 AM
Movie_Mike's Avatar
Yes but here in Germany it's double the price so the comparing isn't that fair. Also the W5000 has HQV which should be a lot better when feeding the pr. with a 1080i TV signal or the small Toshiba HDDVD player.
After reading all the german forums all I can say ist that most of the guys want a high end pr. at the price of the W5000. Everbody should know thats not possible
I demo'd the W5000 comparing it to a XV-Z3300 (Almost the same as the XV-Z3000) and all I can say ist that at almost the same price I would rather have the BenQ.
The W5000 is really a lot of pr. for the price.
Happy New Year
Mike
post #118 of 5151 Old 01-01-2008, 05:35 AM
clehner's Avatar
Yes and no. Without 24p? I'd strongly NOT recommend.
Regards
Christoph
clehner is offline
post #119 of 5151 Old 01-01-2008, 06:26 AM
Movie_Mike's Avatar
Yes but reading that the W10000 & W9000 can do 24p I guess BenQ should be able to fix this issue.
True is that having this kind of problem with a new pr. is kind of lame
post #120 of 5151 Old 01-01-2008, 08:20 AM
Gilmour's Avatar
Know you of another better projector for 1900€ ?
Gilmour is offline
Benq W5000 Dlp Projector 1200 Ansi Lumens 1920 X 1080 Widescreen Hi , Benq W1070 1080p 3d Projector
