Official Epson Pro Cinema 1080UB Thread - Page 55 - AVS Forum | Home Theater Discussions And Reviews
post #1621 of 1649 Old 10-30-2011, 01:14 AM
heavy-b's Avatar
Originally Posted by Lord_Zath View Post
Ordered. was actually cheaper through epson store than amazon - and found a code for 10% off, too!
So you could likely get 8 for the price of my one!
Another question - I have the opportunity to get a larger screen at a steeply discounted price. A 120" Optoma panaview Greywolf II 1.8 gain motorized. My current screen is about 100" and 1.0 gain.
Does anyone have experience with this projector and 1.8 gain? I find that the black levels are already good with my 1.0 gain screen. My concern would be that it would not be bright enough, but I bet the contrast would be awesome. Or do I have that backwards and the higher gain will give a brighter image which will offset the loss of brightness due to the larger screen size? I have never seen a 1.8 gain screen in action so I have no idea.
Any thoughts would be appreciated.
heavy-b is offline
post #1622 of 1649 Old 12-02-2011, 09:35 PM
heavy-b's Avatar
WOW, heard a very loud pop about 1 minute after turning on the projector; and then of course no picture and a red flashing light on the projector. Bulb blew. It was 3.5 years old and the picture was getting noticeable darker, but only had 1843 hours on it in the low lamp setting. Had a spare lamp and put it in.
What a difference!! It is so bright again!
heavy-b is offline
post #1623 of 1649 Old 12-02-2011, 10:54 PM
ricwhite's Avatar
Quoted: 21 Post(s)
I can't go more than about 1200 hours on my 1080UB before it gets too dim. I keep the old bulb as a stand by. I'm looking at upgrading to the Epson 61000 and the bulbs in that are rated at 4000 to 5000 hours. I'm guessing I can get at least 2000 to 3000 before I'm tempted to replace. Huge difference, though, compared to the 1080UB.
ricwhite is offline
post #1624 of 1649 Old 12-04-2011, 08:12 AM
leiff's Avatar
Quoted: 37 Post(s)
I'm at 3000 hrs on first bulb and still looks great. I still have the extra bulb my pro came with too.
leiff is offline
post #1625 of 1649 Old 12-06-2011, 12:11 AM
heavy-b's Avatar
What kind of screen are you using?
heavy-b is offline
post #1626 of 1649 Old 12-07-2011, 09:59 AM
leiff's Avatar
Quoted: 37 Post(s)
white carada no gain I think. Its a short throw distance to my wall. 15 ft. I use natural mode at night as its the brightest mode that still looks good. During daytime I use cinema day to compete with ambient slight. sometimes i will use cinema day setting with contrast turned way down on a movie at night if the film looks very dark to brighten the picture but the result is not very nice. I wonder if people here can share there values if they use cinema day for night time viewing. I rarely use high bright mode which is maybe why I'm still happy with my bulb
leiff is offline
post #1627 of 1649 Old 06-01-2013, 06:02 PM
guitarman's Avatar
Quoted: 12 Post(s)
Ah ha ha, I bought a Pro Cinema 1080 UB used for $600. Ok with an all black screen up I could see six of more Spalding sized dust blobs. I worked for Optoma and had to open a couple of hundred projectors to input a video upgrade to the video board which made the panning on certain movement up to the level and the DC3 H79. Anyway it was easy opening up the 1080ub.
You remove all the bottom screws and the small black screws on the back input panel. The top prys up real easy from the back to the front. You then remove the ribbon connector to the video board and take the whole top off. Man I had cobwebs in there and a bunch of dust. I used a vacuum we have that has a power slider so I didn't hv to use full power. If you don't have one just stay a half inch off of everything. I also used a lint free cloth to clean all the dust on under the top cover and used the vacuum on it afterwords.
Oh did I fail to say after I was done I put up a full black video pattern and there wasn't one dust blob / zero gone.
I moved the ribbons loops away first and used the vacuum cleaner on each panel.
I made this air puffer from a solder sucker, had to drill the tip a bit wider to fit a piece of a clean air blower nozzle tube. About 1 and 1/2 inches length outside the blower nozzle nozzle
I used this last and shot about 4 puffs down into each side of each panel. You'll see the ribbons for each panel and an opening. Just move back the loop from each panel and slide the nozzle in the 1 & 1/2 inches and puff away them specs of dust. An hour and a half told buy Epson my butt. It takes like 10mins.
So if the blobs on your 1080ub are getting you down give this a try.
Another tip, don't ever vacuum the ehaust vent. This just sucks dust all around inside the projector. I did this when I had just 3 dust blobs and ended up with six.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #1628 of 1649 Old 06-03-2013, 06:27 AM
David44's Avatar
Sounds like you're a patient person. So how does the image look compared to more current projectors?
David44 is offline
post #1629 of 1649 Old 06-03-2013, 01:17 PM
guitarman's Avatar
Quoted: 12 Post(s)
It's an excellent projector. I viewed The Game and MI 3 two good movies for evaluating blacks more so with The Game. Very deep black level with no haze in deep dark content. Just as good as the RS1 and RS2 but much better color tones easier on they eye's. What's really surprising is the native contrast being so high 4000.1 you can really see it in midtone video or daylight stuff.
Old thread but I thought it could use this dust blob help. I was lucky but there's even a better way. Leave the top off setup the projector and run a full black screen image while you puff away the dust with that device I made. Start at the top of the panel working your way down. You'll find the panel with the dust.
I confirmed this way works best. Just work on it top off projector on it's simple. I was able to remove every spec of dust. If down the road just do it again if need be. This problem was a main drawback for these LCD's but not anymore. This one the fix is very easy.
Tom/guitarman
VideoDementia
post #1630 of 1649 Old 06-04-2013, 04:46 AM
leiff's Avatar
Quoted: 37 Post(s)
leiff is offline
post #1631 of 1649 Old 06-04-2013, 08:24 AM
Lord_Zath's Avatar
Quoted: 112 Post(s)
Liked: 109
As I posted in the other thread:
I'm running on one of the mwave replacements, and so far so good. I'd estimate about 1000 hours into it and no issues whatsoever.
Holding the fort on old games that play the same as the new ones, minus the $400 price tag.
Lord_Zath is offline
post #1632 of 1649 Old 08-19-2013, 08:30 AM
Carlp336's Avatar
well mine worked on saturday and not sunday. red light the turbo and no picture. swapped the bulb for a spare i had, and there was no change.
whats the likely hood mine spare is bad ? is my 1080ub dead?
Carlp336 is offline
post #1633 of 1649 Old 08-21-2013, 10:44 PM
swettfly's Avatar
right,I had to remove the extension arm since the unit was being installed in a low ceiling room, 7.5'. kkcY
swettfly is offline
post #1634 of 1649 Old 01-12-2014, 06:09 PM
NYURDRMS's Avatar
I just had the same thing happen to mine. Did you ever get yours to work or did it die? I just had the blinking red light with a fan kicking into high gear, then it shuts off. I try to reset the power and same thing. I am thinking of ordering another bulb to see if that is it, but I don't want to waste the money if I need to get a new projector.
NYURDRMS is offline
post #1635 of 1649 Old 01-13-2014, 06:36 AM
Carlp336's Avatar
i had two bulbs. swapping did nothing.
Carlp336 is offline
post #1636 of 1649 Old 01-13-2014, 12:15 PM
Lord_Zath's Avatar
Quoted: 112 Post(s)
Liked: 109
I only had it happen to me once. I doubt switching bulbs fixes it. Try unplugging it from the wall (when it's off). Make sure the rocker switch is on. Then flip the rocker switch off. Plug it into the wall. Turn on rocker switch. Turn on power.
If you get blinking lights, you can try checking the manual to see what it's indicating:
http://files.support.epson.com/pdf/plhc1080/plhc1080-ug.pdf
post #1637 of 1649 Old 01-13-2014, 08:36 PM
NYURDRMS's Avatar
Thanks guys, I have tried the unplugging and plugging back in several times with the same result. It is blinking once a second which according to the manual says there is something wrong with the internal components and not the bulb, which was confirmed by the tech support person at Epson today. She recommended I take it into the shop, but I have to assume whatever part is damaged is going to cost more than this projector is worth now. I guess it is time for a new one.
Thanks for the responses.
Chad
NYURDRMS is offline
post #1638 of 1649 Old 01-14-2014, 04:25 AM
lvisneau's Avatar
I had that happen a couple days ago when i tried to put a new avr in my system. Almost like it was getting a bad signal. Just for giggles, Pull out all connections and restart the pj. I reinstalled my old avr and it fixed it. Weird to say the least. It's ok , I should be getting my new 55es soon.
My sono build
Psn Id- lvisneau or lvizzzy
Xbl- chief vizzy
lvisneau is offline
post #1639 of 1649 Old 03-25-2014, 01:35 PM
guitarman's Avatar
Quoted: 12 Post(s)
That's a odd fix but if it helps others great. You can never get enough tuning info so here goes. I got out my colorfacts equipment and went to work on the 1080ub pro.
Cinema night
Brightness -2
Contrast +3
Color saturation +7
Tint +1
Color temp 6500
Skin tone 3
Brightness high
Auto iris on. when I tuned it this was off you have to grayscale tune correctly. It doesn't matter turning it on afterwards..
Advanced
2.2 gamma
RGB
Offset Red +13
Offset G 0
Offest B +14
Gain Red 0
Gain G 0
Gain B -13
That's it, give them a try, this line up looks awesome, colorful and natural every bit like any projector I've used colorfacts on.
Tom/guitarman
VideoDementia
post #1640 of 1649 Old 06-23-2014, 07:02 AM
tibz35's Avatar
Hi everyone,
Sorry to revive an older thread, but I just ordered a 1080UB for my Father, and I wanted to just hear some advice on the following (if possible):
1. He is a huge sports/hockey fan, and wanted to know if there was any noticeable lag/motion blur...On my personal 70" Sharp LED TV I do notice a ghosting when it pans the ice...
2. Is the fan that noticeable if sitting behind and below the projector?
Thanks in advance!
tibz35 is offline
post #1641 of 1649 Old 06-23-2014, 04:37 PM
Lord_Zath's Avatar
Quoted: 112 Post(s)
Liked: 109
1. You'll probably notice motion blur yes. It's not crazy - either that or I've just gotten used to it.
2. Fan noise is OK. I have mine on high altitude mode, which causes the fan to spin faster for better airflow and cooling. That said, I only notice the fan noise when I have my speakers muted.
post #1642 of 1649 Old 06-24-2014, 12:25 PM
tibz35's Avatar
Thanks very much Lord_Zath - Actually have one more question:
This is the first time I'm setting up a projector, does this model have any ability to adjust the screen size easily?
For example, can I have it set for the full 120" for movies, and then easy change it to say 80" to watch TV?
tibz35 is offline
post #1643 of 1649 Old 06-24-2014, 09:34 PM
Lord_Zath's Avatar
Quoted: 112 Post(s)
Liked: 109
Yes there's a simple zoom slider by the lens. Though you will probably not want to go smaller once you see the glory that is projection. I'm on a 2-story white wall and love it. No screen needed (it may help somewhat but... meh). Roughly 183" diagonal.
Going smaller screen will yield better colors, but size wins out IMO .
post #1644 of 1649 Old 03-02-2015, 01:11 AM
SomeDouche's Avatar
Sorry to bump the thread, but if anyone is looking for oem epson bulbs for the 1080ub, i have 2 i am going to get rid of for very cheap. Pm me if interested. Both for $150 is what im asking, both are new oem bulbs.
SomeDouche is offline
post #1645 of 1649 Old 08-05-2015, 07:38 PM
Liked: 0
Hey guys! I just gone one of these Baby's used for $200 and I love it. Came with 2 extra bulbs too! I am having a strange issue however. I noticed that my projector has some convergence issues, really not noticeable (probably 1/2 pixel on red and green). But whenever a White screen comes up, the upper right corner is shifted yellow, and the bottom left is shifted blue. I will take pictures when I get everything all setup. But does anyone have any ideas on what is going on or what this is called so I can get some research done? Thanks guys! Also @guitarman , I will try your calibration settings when I get home!
sonicdude987 is offline
post #1646 of 1649 Old 08-06-2015, 06:29 AM
bnieman's Avatar
What you are noticing is imperfect convergence of the Red, Green, and Blue panels. Unfortunately it was a crapshoot with these projectors as to how good the convergence on each unit was. There is no way I am aware of for you to fix it. Epson's policy was to send out a replacement unit if the projector was under warranty and it was luck of the draw as to what you would receive back.
I once contacted Epson about a dust blobs about a year after I bought mine and since I had the "Pro" version with VIP warranty they sent me a replacement projector FedEx Overnight. When I received the replacement I was to ship my original projector back in the box the replacement came in. Much to my dismay, when I fired up the replacement projector I noticed a convergence problem exactly like you're describing. Luckily I hadn't shipped my original unit back yet and I called Epson to explain the situation. In the end I went to a Espon service center with my original projector (with great convergence) and had it cleaned under warranty. The cleaning eliminated the dust blobs and the projector was like new again.
The convergence issue is common in a lot of projectors and shouldn't be noticeable under normal viewing circumstances from typical viewing distances. If you picked the projector up for $200 with 2 extra bulbs that is an incredible deal. You paid about the price of a replacement bulb for two bulbs AND the projector.
Also, if you ever do have dust blubs there is information in this thread as to how you can clean it yourself. I haven't attempted it yet but have the information handy. I had my projector professionally cleaned by the same service center after my warranty expired and it was around $120 for the cleaning.
Enjoy your new projector! It's a great unit and you got an amazing deal!
bnieman is offline
post #1647 of 1649 Old 08-06-2015, 10:01 AM
Liked: 0
Thanks for all of the info! It doesn't really bother me that bad, but it is good info to have! Thanks man!
post #1648 of 1649 Old 11-19-2015, 05:22 AM
jim1701's Avatar
Replace ballast on 1080UB Pro?
A few weeks ago, my projector just shut off and will not come back on. No power light, nothing. I sent it to be repaired and after three weeks of waiting on a replacement ballast from Epson, they were informed that Epson no longer makes the part. Mendtronix says they can't find the part from their alternate sources. Any idea how I can repair my low usage projector? I still have the spare replacement bulb unused, so I don't want to ditch this machine.
Jim
jim1701 is offline
post #1649 of 1649 Old 11-19-2015, 03:36 PM
luclin999's Avatar
Jim
If you are determined to fix your current projector then the only option that I can see is to keep watch on Ebay and Craig's list for a used 1080UB that is listed as being for sale for parts. Still a bit of a crapshoot as to whether or not the used machine will have the part that you need in working condition though.
luclin999 is offline
Epson Powerlite Home Cinema 1080 Home Theater Projector , Epson Home Cinema 8700 Ub Projector , Panasonic Pt Ae4000u 1600 Lumen Lcd Home Theater Projector
taboola here
