Preliminary results of my mini RS1 VW60 shootout - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2008, 09:19 AM
Cameron's Avatar
Congrats! I'm sure you will love it!
-- Well I have really blown my budget now. --
Cameron is offline
Old 03-07-2008, 07:22 PM
Mod & Bluray Reviewer
Lee Weber's Avatar
Quoted: 94 Post(s)
Liked: 260
Thank you.
This was my gut as I am deciding between the 2.
I have a 110" Stewart Studiotek 130, almost perfect light contol, and the PJ is mounted 13 feet away, and I am sitting 13 feet away.
I hope the rs1 is the winner for me...
Originally Posted by mbonikow View Post
I have no idea why people complain about the lens on the RS1/RS2. They are in the league of all good projectors. Mine does not display color fringing, can be adjusted for nearly perfect convergence at 60-70% of the screen and seems tack sharp, sharper than the Pearl lens. I have owned Sharp 12K dlp (same lens as 20K) and many other "fine" lens machines and none offered much better lens quality. As for a CRT having better lens or sharpness... give me a break
On comparing Sony's inflated 30K:1 contrast with iris trick to native RS1 contrast, again... give me a break
The way the eye works if you have bright highlights in the scene and dark background, which is the way most movies are shot to increase the perceived intra-scene contrast, then RS1 is a winner vs. VW60, 30K contrast ratio and all...
If Pearl has slightly lower absolute black, then this is due to clamping down of the iris and to me has little real world value as I don't watch a black wall, but rather a movie, which never is 0 IRE.
I have seen VW60 in excellent setup and have owned two Pearls and as nice as they are, the brightness compression from the iris is not for me. RS1 comes across as a more open, cinematic projector.
To me iris tricks are like breathing through a straw, sure you can do it, but why?
Lee Weber is online now
Old 03-08-2008, 06:09 AM - Thread Starter
Steve Dodds's Avatar
I don't think there is a loser in this competition. It's what is more important to you.
I can see brightness compression with the VW60, but it bugs me less than the slightly more elevated blacks of the RS1.
Steve Dodds is offline
Old 03-08-2008, 01:34 PM
kstirman's Avatar
Steve - what lens are you using? I still have my ISCO II from the LT150 days - I think you had the same set up way back when.
Kelly
kstirman is offline
Old 03-08-2008, 04:47 PM - Thread Starter
I have an Aussiemorphic and a Panamorph U15 on the way.
Yes, I used to have a good old LT150 way back when.
Old 03-10-2008, 10:26 AM
Lee Weber's Avatar
Quoted: 94 Post(s)
Liked: 260
What do you mean by elevated blacks??
Old 03-10-2008, 12:29 PM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 39
That's the first time I've ever heard of the RS1 as having elevated blacks. Having owned both the RS1 and VW60 I can't see how the VW60 could be considered to have better blacks. Don't get me wrong, blacks are fine on the VW60. Possibly equal even though it is with lower light output that the RS1 when both are in low lamp mode. Of course it may come down to the possibility of varying CRs from unit to unit.
My Theater Room JVC RS4910, Panamorph UH480, 148 in. 2.40:1 Dalite HD Pro 1.3, Klipsch THX Ultra II's x 7, Quad JTR Captivator S1 subs
My Previous Non-Dedicated space
RobZ is offline
Old 03-10-2008, 01:46 PM
zamboniman's Avatar
This one still baffles me regardless of projector variance when comparing to the vw60.. CRT yes... vw60 no..
I'm curious how is your RS1 configured
1. What bulb setting? Normal or High?
2. HDMI Input level? Standard or Enhanced?
zamboniman is offline
Old 03-10-2008, 03:47 PM - Thread Starter
I meant elevated compared to my VW60.
My Rs1 had very slightly higher levels of absolute black than my VW60. Emphasis on my.
http://www.avsforum.com/avs-vb/showt...8#post13197988
Whilst I may have had two aberrant units, Tom Norton at UltimateAV found the same thing.
Old 03-10-2008, 04:52 PM
zamboniman's Avatar
I understand what you are saying..... just having a hard time believing it. It seems like your RS1 is way way off compared to most or it has some settings wrong.
Which is why I'm curious of these settings.
I know having the HDMI input level set wrong will elevate the blacks incorrectly.
Granted the sample size of vw60's I've seen is not huge.... but every one I've seen didn't have the black level of the rs1 regardless of lamp or iris settings
Old 03-10-2008, 05:31 PM - Thread Starter
Mine does. Tom Norton at UltimateAV's does. GregR's was awfully close. This guy's was too.
http://www.dtvforum.info/index.php?s...=54118&hl=VW60
Even Jason Turk's seems to:
http://www.avsforum.com/avs-vb/showt...3#post13105753
Please note that I am not talking about contrast here. Just flat out black levels from a O IRE field. My JVC did often have better blacks when viewing higher APL images.
Old 03-10-2008, 05:45 PM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 39
On a 0 IRE field I'd agree that the VW60 has equal or possibly even better black level. The obvious argument is that the VW60 needs to use the iris to get there. I'm not arguing that the VW60 is not a better machine, in some ways, than the RS1. For many, it may be the preferred machine. I think most would argue that black level performance is better on the RS1 with actual film content, with the exception of a fade to black, due to it's high native contrast. For me, watching Underworld or specific scenes in Star Wars gave me a better appreciation for the native contrast of the RS1. The RS1 maintains a deep black (for a digital) while maintaining more brightness than the VW60. Sony did a great job with the VW60 and it's iris is much better than any I've personally seen but it is still an iris system. Regardless of the specs, etc. both are fantastic machines. I've seen AVSers prefer the VW60 over the RS1 and vice versa.
RobZ is offline
Old 03-10-2008, 05:59 PM - Thread Starter
I agree in general, but with a slight difference which comes down to prefference. On star fields like those in Star Wars or 5th Element, my VW60 produces slightly darker blacks (the sky), whereas the RS1 produces noticeably brighter whites (the stars). I'm willing to sacrifice some starlight for a darker sky.
In films like Dark City, Unforgiven, Moria from LOTR which are really dark, once again the VW60 gives me slighly darker (although not dark enough) blacks at the occasional cost of brightness compression.
I notice brightness compression (ie lack of contrast), but it doesn't bug me as much as knowing I could have better even slightly better black levels in low APL scenes. An ND filter on the RS1 lowered it's black level to about the same as the VW60, but compressed ALL whites as opposed to some occasionally as with the VW60.
If I could afford it, I'd probably have an RS2.
Even better would be an RS2 with a variable iris.
Old 03-10-2008, 06:07 PM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 39
Hopefully the next JVC has either an adjustable auto iris or a fixed iris combined with even better CR than the RS2.
The VW60's brightness compression never bothered me. I did notice a slightly bluish black though. What I did prefer is the smoothness of the image when fed 1080p24. Not to mention the lens control.
RobZ is offline
Old 03-10-2008, 06:40 PM - Thread Starter
Apparently you can get rid of the bluish black with some tweaking. That DTV thread I posted mentions how. I've not tried it myself.
An RS2 with changeable iris or VW70 with RS2 level native contrast would be the next logical step, and presumably do-able.
Old 03-11-2008, 05:20 AM - Thread Starter
I know I'm going to come across as a VW60 fanboy here, but I can't resist.
These are the HT mag results for the RS1 first:
http://hometheatermag.com/frontproje...oj/index5.html
Then the VW60:
http://hometheatermag.com/frontproje...60/index2.html
Of course, my argument is totally blown by their results for the RS2:
http://hometheatermag.com/frontproje...la/index2.html
The amazing thing is that there was no mention at all of the disparity between the RS1 and RS2.
Old 03-11-2008, 05:56 AM
Drexler's Avatar
Quoted: 78 Post(s)
Liked: 56
Well, they comment that the light ouput in the 0 IRE setting was below the measurement range of their light meter for RS2 and probably also for the RS1. If you have a black level below the detection limit then the light output in 100 IRE will give the measured contrast ratio. Thus, the brighter RS1 will yield a better result, but it doesn't say anything about the real contrast ratio.
Drexler is offline
Old 03-11-2008, 06:37 AM
Drexler's Avatar
Quoted: 78 Post(s)
Liked: 56
By the way, stating CR with four significant digits, as the authors has done (e.g. 12,790:1 for RS2), is very misleading and totally ridiculous when they hardly have one significant digit in the 0 IRE measurement (<0.01 ft-L). This implies they have high measurement accuracy, which is obviously not the case. Correctly stated it should be >10,000:1.
Edit: (the CR should actually be >10,000:1 for all three projectors, RS1, RS2, VW60). Hence, the measurements were not good enough for any comparison of the on/off CR of the projectors. Since the reviewers didn't seem to know what they were doing measuring on/off I'm not sure I would trust their ANSI CR either...
A bit OT, but I get annoyed when suppose to be professionals working with scientific instrumentation lack elementary science and mathematical training...
Drexler is offline
Old 05-19-2008, 06:50 AM - Thread Starter
Loathe as I am to admit to any kind of error, I feel I should say that I am going back to JVC.
I do think that, overall, the VW60 is a slightly better projector for most users.
But I've been driving myself nuts trying to tweak the best blacks out of the VW60 only to have them change through the iris. I didn't notice this before, but I do now and I can't rid myself of it.
The changes in white level haven't bothered me, but this does.
It's especially annoying because my current VW60 has excellent black uniformity, and I know that my RS1 didn't, but once you see a thing that bugs you there is nothing to be done.
You must change.
So I don't reconcile from anything I mentioned above. The VW60 is somewhat better.
But I'm going back to a JVC.
Old 05-19-2008, 07:55 AM
Cameron's Avatar
Maybe you should just get a RS2.
Cameron is offline
Old 05-19-2008, 08:06 AM
Tryg's Avatar
Tryg is offline
Old 05-19-2008, 08:20 AM - Thread Starter
Silly me.
I completely forgot you'd chime in.
Old 05-19-2008, 08:47 AM
Tryg's Avatar
did you ever settle on a screen that will work for you?
Tryg is offline
Old 05-19-2008, 08:55 AM
AVS Club Gold
Art Sonneborn's Avatar
Quoted: 41 Post(s)
Liked: 86
If the sensor is close to the lens one can obtain more significant digits in the low end. I'm not sure that that was what was done but ...
Art
My HT
iRule rules my theater
Art Sonneborn is online now
Old 05-19-2008, 04:34 PM - Thread Starter
Yep, I have a Firehawk.
Old 05-19-2008, 04:40 PM
Cameron's Avatar
So I saw your VW60 up for sale in the classifieds there. You mention that you will be going to a HD100? So I guess you are going the RS2 route then.
You will have to let us know how you like it!
Cameron is offline
Old 05-20-2008, 12:23 AM
pchemist's Avatar
I'm particularly sensitive to sharpness (or the lack thereof, which I find fatiguing -- like trying to focus on something that can't be focused on), so I'd like to ask if anyone has had the opportunity to compare a VW60 to an RS1 in the way I'm about to describe (which I did for a 1080UB, a VW50, and an RS1):
I obtained 1080p images containing alternating R/G/B single-pixel-width line segments from http://www.pbase.com/jackcnd/1080p_tests (I used the "original" versions to obtain 1080p images). Images were stored on a PS3 and fed to the projectors via HDMI.
Looking at a 1080UB near the center of the screen, there were two significant problems: (1) the red, green, and blue pixels couldn't be focused simultaneously (see attached black and white pic, paying particular attention to the blue pixels); and (2) even with the best obtainable focus, the pixels were smeared -- and sometimes the lines were even doubled (!) (see attached colored pic).
Problem #1, I assume, results from panel misalignment (but it's depth misalignment, rather than lateral misalignment); problem #2, I believe, results from inferior lens quality.
I saw the same problems (both the line doubling and the lack of simultaneous panel focus) on the VW50, at the center of the screen
[As an OT aside, I will mention that, on the 1080UB threads, there are frequent complaints of panel misalignment, as evidenced by significant color fringing seen on white lines. But the attached color pic suggests than some of those individuals complaining about panel misalignment many instead simply have bad lenses. The only way to tell is to put up patterns that have separate R/G/B line segments.]
By contrast, the RS1 at the center of the screen was remarkably sharp -- the line segments of all three colors looked as sharp, simultaneously, as they do on my computer's very high quality (Samsung SyncMaster 213T) 21" LCD screen; there was no visible blurring or fringing. Up to this point, I’d thought that LCoS pixels were “soft-looking.” Now I realize that the pixels themselves are sharply defined, but you need a PJ with good enough optics to see this (and, of course, very tight focus on the three panels to be able to have them be sharp simultaneously). There was a direct translation between the sharpness of the patterns on the RS1 and how it looked with movies, which appeared significantly sharper on the RS1 than on the VW50 or on the 1080UB (I used the Spider Man 3 Blu-Ray for this comparison).
Vertically and horizontally, lateral registration of the red and green panels on the RS1 was within 1/3 to 1/2 pixel. The only problem was blue, which was displaced horizontally by almost two pixels (vertically it was fine). But for image sharpness, this seems to matter less (at least for the blue; if the red and green were off by 2 pixels, that would likely be a different story) than having good optics and tight panel focus.
Not that one wouldn't also want to have the blue be where it's supposed to be. In fact, the RS1’s internal panel alignment compensation may fix this. The VW60’s, which shifts in fractions of a pixel, does so by dimming/brightening adjoining pixels -- it doesn't actually correct the alignment of the panels. So it can’t give you back the resolution you lose by misalignment (in fact, I understand that use of this feature actually reduces sharpness). But since the JVC’s panel alignment feature, by contrast, only allows for whole-pixel increments it could, at least in principle, electronically re-map the entire blue panel EXACTLY (by just shifting the blue panel pixel addresses by +2 vertically, for instance). Anyone know if this is true?
For me, the major benefit of this exercise was two-fold. First, it clarified just how important sharpness is to me -- the increased sharpness of this RS1 made watching movies less fatiguing (and yes, I still want a 3-chip for other reasons; I just want a 3-chip that's sharp!). Second, it changes the conversation -- instead of having to ask people, subjectively, how sharp a projector is, I now understand that this can be easily assessed: you just have to put up one of these single-pixel-width patterns, and look for the same crispness you see on a flat-panel LCD. If you've got this, you know that the video image will be sharp.
So I'm wondering whether anyone has done a test like this to compare the relative sharpness of the RS1 and the VW60.
pchemist is offline
Old 05-20-2008, 04:59 AM
reincarnate's Avatar
Originally Posted by pchemist View Post
Not that one wouldn't also want to have the blue be where it's supposed to be. In fact, the RS1's internal panel alignment compensation may fix this. The VW60's, which shifts in fractions of a pixel, does so by dimming/brightening adjoining pixels -- it doesn't actually correct the alignment of the panels. So it can't give you back the resolution you lose by misalignment (in fact, I understand that use of this feature actually reduces sharpness). But since the JVC's panel alignment feature, by contrast, only allows for whole-pixel increments it could, at least in principle, electronically re-map the entire blue panel EXACTLY (by just shifting the blue panel pixel addresses by +2 vertically, for instance). Anyone know if this is true?
You are one very astute individual who is good at exposing marketing ******** and inferior designs. Its usually the hype that matters, not the true performance.
The JVC can correct to within one pixel in the central area of the screen. If the physical alignment or optical aberration errors are constant then it will apply to the entire screen. These limitations hold true for all three panel digital projectors.
The humorous irony is that this inferior 1:1 pixel map destroying design claimed to be better. In reality it saved manufacturing costs as the factories quality control standards could be relaxed. It fooled most everyone, even the experts here.
For the RS1, I minimize the vertical and horizontal offsets and adjust the manual focus until the vertical and horizontal screen door pattern is equally sharp. Then take a tack sharp Sony PS3 blu-ray player and you are good to go.
reincarnate is offline
Old 05-20-2008, 09:48 AM
rsnyder005's Avatar
I have never seen the RS1/2 and the only JVC proj. I ever owned was the G1000. When watching Nardia on my VW60 using a Panasonic 30 blu-ray through the Yamaha RX-Z11 receiver and using a Dalite HP 133" screen(no anam. lens-just masking), I was completely blown away by the picture and just wonder can it get much better than this? Could an anamorphic lens make an improvement? just some observations, Ron
rsnyder005 is offline
Old 05-20-2008, 04:23 PM
mdputnam's Avatar
I now understand that this can be easily assessed: you just have to put up one of these single-pixel-width patterns, and look for the same crispness you see on a flat-panel LCD. If you've got this, you know that the video image will be sharp. So I'm wondering whether anyone has done a test like this to compare the relative sharpness of the RS1 and the VW60.
The RS1 can have miss-aligned panels too, and the amount can vary between machines, some will be better aligned than others. Here is Mark Peterson's explanation on how to get the sharpest focus on the RS1.
Human perception is not a direct consequence of reality, but rather an act of imagination. - Michael Faraday
mdputnam is offline
