Channel Master CM 4228 8-Bay Bowtie UHF Antenna (CM4228) - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 170 Old 08-27-2008, 12:33 PM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 151
Yep, Rabbit, you're who I was thinking of ...
fbov is offline
post #92 of 170 Old 08-28-2008, 06:28 AM
videobruce's Avatar
Quoted: 661 Post(s)
Liked: 254
If I want to do some testing on my own for cable runs and locating my antenna, what kind of signal meter do I need?
Ther are plenty of older 'analog' SLM's (Signal Level Meters) on e-bay for well under $200. Some as low as $50. Actually, there are digital meters (not for digital channels though) for around $250.
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #93 of 170 Old 09-12-2008, 07:19 AM
pimlottc's Avatar
I just noticed the new models are now up on Warren Electronics: 4221HD, 4228HD. Both are listed as "coming soon" with no price information. The old 4228 is still in stock but it looks the 4221 is gone.
pimlottc is offline
post #94 of 170 Old 09-12-2008, 09:20 AM
kousikb's Avatar
People living closer to Frys B&M may still be able to pick up CM4228 from the B&M store. I visted Frys store in Vegas (labor day weekend) and was surprised to see CM4228 with a price tag of $59 (IIRC) instore. They were also selling antenna mounts, some channel master pre-amp (don't remember the model number). They also had a whole bunch of CECB (Airlink) in stock. I feel, RS, CC, BB should start selling these 2-bay/4-bay/8-bay bowtie design antennas more than those crappy overpriced antennas now that the switchover date is nearing.
kousikb is offline
post #95 of 170 Old 10-19-2008, 03:49 PM
waterwingz's Avatar
Anyone know if the aluminum siding on my house will interfere with reception if its behind my CM4228? All the stations of interest near my house are in exactly the same direction and it would be very easy to point the CM4228 at them by mounting it below the eaves on the 2nd story of my house. This would put the aluminum soffits and siding out of the line of sight to the antenna but relatively close to the antenna ( < 1ft). It this going to be a problem such that I maybe need to put the antenna on a pole above the roof line ?
waterwingz is offline
post #96 of 170 Old 10-19-2008, 06:32 PM
holl_ands's Avatar
Quoted: 540 Post(s)
Liked: 240
Yes, placing a second reflector behind the CM-4228 will affect the antenna.
On some freqs it may improve and on others may reduce gain. Hence YMMV.
Higher is better anyway....you'll just have to try it to see if you have enough signal.
I experienced a similar effect sniffing for signals 70+ miles (and a mountain pass)
away. When I mounted a 4-Bay against a brick wall the signal vanished and
returned only when I moved it a couple yards away. Did I say YMMV???
holl_ands is offline
post #97 of 170 Old 10-19-2008, 06:35 PM
holl_ands's Avatar
Quoted: 540 Post(s)
Liked: 240
Here's an App. Note for Potomac Inst. FIM-71 and FIM-72 Signal Level Meters (NTSC)
discussing how to derive a correction for DTV measurement (12 dB):
http://www.pi-usa.com/pdf/dtva.pdf
Your meter may have a different correction, depending on measurement bandwidth, etc.
post #98 of 170 Old 10-19-2008, 06:38 PM
holl_ands's Avatar
Quoted: 540 Post(s)
Liked: 240
Due to their size, you may have to ASK Frys to retrieve a CM-4228 from their storage area.
post #99 of 170 Old 10-20-2008, 08:50 PM
MeowMeow's Avatar
I'd generally suggest going above the roof line. I recently was in a similar situation after a late fall move to a new house. I mounted my CM 4228 on the back porch roof, and the siding of the second floor was behind the antenna.
About a month and a half ago I mounted it against the side of the house and slightly above the roof line (rough 15' or so higher). Several channels improved in stability and a number of weaker signals that came in with tropo appeared much more often (from something to the order of once every two weeks to just about every night).
While not a radical improvement (I live in western PA, which means lots of hills) I felt the stability improvements alone were more than worth it.
MeowMeow is offline
post #100 of 170 Old 11-08-2008, 07:36 PM
CJBaker's Avatar
I'm in central Kansas (flat lands) and with the 4228 an 7777 on 125' of cable I'm able to get all of the Wichita stations 90 miles to the south EXCEPT Fox is not reliable. There is a fox station only about 20 miles away but it is 135 degrees away from the Wichita stations. Currently the antenna gets the station with a LOT of ghosts.
I thought that I had read that the chicken wire mesh behind the 4228 was to keep signals from the back side from getting to the antenna. My thought is if that IS the case then I could cut off a couple rows of mesh and let the first row of bow ties pick up the signal from the back. There are no other stations to the north that would cause problems.
I'd appreciate any thoughts on this. Thanks
CJBaker is offline
post #101 of 170 Old 11-09-2008, 06:43 AM
arxaw's Avatar
I have removed the 4228 screens to make mine bi-directional for VHF/UHF stations in two directions. See pic here. My stations are closer to 180° opposite directions and the farthest station I get is only ~70+ miles away. So it may or may not work in your situation. But it's simple to remove/replace the screens, and definitely worth a try. You may lose some gain when you do this.
arxaw is offline
post #102 of 170 Old 11-09-2008, 06:46 AM
videobruce's Avatar
Quoted: 661 Post(s)
Liked: 254
I came across this link from a Canadian forum regarding the 'new' imported '4228HD';
http://www.digitek.tv/index.php?page...emart&Itemid=1
Though these are speced for Austraila, the reported gain is 13-15 db and F/B ratio is 24db.
Also notice the other models. Most are familar.
post #103 of 170 Old 11-10-2008, 04:03 PM
stampeder's Avatar
Originally Posted by mtnbike-dude View Post
That first link is of the new Channel Master line. So, they just are repackaging somebody elses antenna. Typical.
You guessed it - here's what I found regarding the CM4228HD and DigiTek's PA4 antenna sold from Australia:
http://www.digitalhome.ca/forum/showthread.php?t=95467
stampeder is offline
post #104 of 170 Old 11-11-2008, 08:07 AM
videobruce's Avatar
Quoted: 661 Post(s)
Liked: 254
Someone is following me around..........
post #105 of 170 Old 11-11-2008, 11:27 AM
stampeder's Avatar
Naw, I've just been north of the border most of the time so I thought I'd drop in again.
post #106 of 170 Old 12-03-2008, 05:09 AM
arxaw's Avatar
The 4228HD is now available here, and at other online sites.
arxaw is offline
post #107 of 170 Old 12-03-2008, 07:55 PM
videobruce's Avatar
Quoted: 661 Post(s)
Liked: 254
I paid $50 for my orginal US made 4228 3 years ago. Now for a cheap Chineese import, it's $65.
post #108 of 170 Old 12-09-2008, 09:42 AM
antennaguyga's Avatar
Does anyone have the datasheet for the CM 4228 - the one that shows the gain at different frequency bands? I would like to compare the specs vs. the "new and improved" versions.
antennaguyga is offline
post #109 of 170 Old 12-09-2008, 10:22 AM
arxaw's Avatar
Only info I have is:
http://www.hdtvprimer.com/ANTENNAS/cm4228.html
http://www.hdtvprimer.com/ANTENNAS/comparing.html
arxaw is offline
post #110 of 170 Old 12-09-2008, 11:02 AM
holl_ands's Avatar
Quoted: 540 Post(s)
Liked: 240
post #111 of 170 Old 12-12-2008, 09:25 AM
I did several searches and even checked stark but missed that.
BTW, I was also looking to possibly buy one but there seem to be none to be had, including eBay.
post #112 of 170 Old 12-27-2008, 12:28 PM
arxaw's Avatar
Anyone tested the new model yet?
arxaw is offline
post #113 of 170 Old 12-27-2008, 11:56 PM
HDTVChallenged's Avatar
Liked: 215
Nope ... but it looks like a case of "let's use cheaper parts and charge 1.5 times as much as the original." .... meh, Pass. I'm glad I got the real deal a few years ago.
HDTVChallenged is offline
post #114 of 170 Old 12-28-2008, 05:35 AM
arxaw's Avatar
Agreed. Still, I'd like to see someone test/compare this thing and post results like this.
arxaw is offline
post #115 of 170 Old 12-28-2008, 08:11 AM
holl_ands's Avatar
Quoted: 540 Post(s)
Liked: 240
FIRST, someone has to post some ACCURATE measurements and hi-rez PHOTOS.
post #116 of 170 Old 12-28-2008, 07:28 PM
WJonathan's Avatar
Well, I was just going to ask about these redesigns. I was looking to upgrade to the 4228 over the 4221 to fix a particularly pesky local station. But I guess I'll wait until some feedback comes in on the new design.
WJonathan is offline
post #117 of 170 Old 12-29-2008, 04:02 AM
TWinbrook46636's Avatar
I have a ClearStream 4 (C4) from Antennas Direct which performs very well considering its size but I was looking for something more and bought the new CM4228-HD from Channel Master after reading reviews of the CM4228. Very disappointing. Despite being a much larger 8 bowtie design it got about 10 to 15 % less signal strength across the board and 7 less channels picked up. No improvement over the ClearStream 4 on VHF-HI either. I played around with it for about a week and that was the best I could get from it. It's also poorly constructed compared to the ClearStream 4. The only good thing about it was that is ships pretty much fully assembled.
TWinbrook46636
TWinbrook46636 is offline
post #118 of 170 Old 12-29-2008, 05:43 AM
arxaw's Avatar
I'm sorry to hear about your disappointing results with the "new" 4228.
It appears that Channel Master took a good thing. And ruined it.
arxaw is offline
post #119 of 170 Old 12-31-2008, 06:19 AM
videobruce's Avatar
Quoted: 661 Post(s)
Liked: 254
These were reviews of the orginal 4228, not the 4228HD import, correct?
That "Clear Stream" is that new odd looking antenna with those discs?
post #120 of 170 Old 12-31-2008, 06:24 AM
arxaw's Avatar
What's the purpose of those discs, anyway (other than to look unconventional)? Are they metal or pieces of plastic?
arxaw is offline
Reply HDTV Technical
