Cable splitter question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-08-2008, 11:49 AM - Thread Starter
csaag's Avatar
I currently have Comcast analog cable service, but for whenever I switchover to digital service I have a question about On Demand/pay per view etc.
I just installed a 4 way amp/splitter that allows a return path signal, but what about other (non amp)splitters? I have some old RCA 2 & 4 way splitters. Do they allow a return path signal? I've seen splitters being sold for satellite that state they have a return path, so I was wondering if an old RCA 2 way splitter would work with On Demand etc...
thanks
csaag is offline
post #2 of 3 Old 04-08-2008, 12:24 PM
CA_Guy's Avatar
thanks
Some splitters are "bi-directional" and some are not. My gut says that if the splitter is not clearly marked bi-directional, it is not. And since you are using some old splitters as well, make sure they will pass the frequencies you need. Over-the-air requires about 900 MHz, DSS higher. Cable systems vary but all will be less than 900 MHz.
CA GUY
CA_Guy is offline
post #3 of 3 Old 04-08-2008, 01:29 PM
bfoster's Avatar
All splitters are "bi-directional", the critical part is their pass band. 5 - 1000 Mhz is what you should be using.
bfoster is offline
Reply HDTV Technical
