DirecTV AM21 (OTA Tuner) Now Available - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 81 Old 09-08-2008, 07:10 AM
gwsaunders's Avatar
Great forum!
I live in Savanmnah, GA and don't receive the locals in HD from Directv.
I have an HR21 and just ordered the AM21 last night. What do I do when it arrives? Do I just plug it in to the HR21 and start receiving OTA? Do I have to buy a separate OTA antenna. If so, can you guys recommend one?.
It can't be visible in the room- wife won't go for that. Are the OTA antennas easy to hook up-just a coax cable from the antenna to the box?
As you can tell I don't know squat about this stuff but its killing me to not get college football in HD.
Greg
gwsaunders is offline
post #62 of 81 Old 09-08-2008, 07:30 AM
RoyGBiv's Avatar
Quoted: 75 Post(s)
Liked: 35
I don't own an AM21, but as I understand it it hooks up as follows: The power supply from the wall goes to the AM21. There is then a cable that goes from the AM21 to HR21 to supply power to it. There is also a USB cable which goes from the AM21 to HR21. Then, you will need an antenna of some sort connected to the AM21 by coax cable.
If you are near the transmitting towers in Savannah you will possibly need only a small interior antenna, which might even be able to be put in a cabinet or wall unit with your equipment, if that's what you use. You could almost certainly get good reception with an attic mounted antenna, running the coax to the AM21, or you might need an outdoor antenna. More info on an antenna that's right for you can be obtained in the Savannah, GA thread in the local info and reception section.
SMK
RoyGBiv is offline
post #63 of 81 Old 09-08-2008, 09:46 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
What he said. Then, in the menu, you just go through the setup of the antenna and you'll be watching your locals OTA. that will include many, if not all, of the sub-channels. It depends on what D* has in their database. Unfortunately, you can't manually add or remove channels, so there may be a sub-channel or two that will be missing.
CIAO!
Ed N.
egnlsn is offline
post #64 of 81 Old 09-08-2008, 01:38 PM
gwsaunders's Avatar
Sweet.
Thanks guys. I'll update once I get the AM21.
Greg
post #65 of 81 Old 09-11-2008, 01:58 PM
Angel L.'s Avatar
I got the AM21, Will it work with a H21? D* says its not compatible!
Angel L. is offline
post #66 of 81 Old 09-11-2008, 02:01 PM
Bronco70's Avatar
Not compatible
Bronco70 is offline
post #67 of 81 Old 09-11-2008, 02:02 PM
Scott Pro's Avatar
It will, later this year, there will be a software update to the H21 to make the am21 compatible. They won't say when.
ScottPro
Conifer Mountain, CO
Scott Pro is offline
post #68 of 81 Old 09-11-2008, 06:30 PM
Angel L.'s Avatar
I have the am21 and cant use it until the update!
Angel L. is offline
post #69 of 81 Old 04-14-2010, 02:15 PM
memo90061's Avatar
Where does the AM21 get the OTA guide data? Does DirecTV provide the OTA guide data or does it download it from somewhere?
memo90061 is offline
post #70 of 81 Old 04-14-2010, 09:28 PM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
It comes from DirecTV as part of the regular guide data, which means it's originally provided to DirectV by Tribune.
texasbrit is offline
post #71 of 81 Old 05-09-2010, 05:27 PM
Burl's Avatar
One of my old H20-600's croaked and Directv has shipped an H21-200 to me as a replacement even though I told them I needed to be able to receive locals OTA (if you are not aware, the H21-200 will not receive OTA). Will the AM21 work with the non-DVR H21 or H23?
Jeff Burleson
Burl is offline
post #72 of 81 Old 05-10-2010, 07:25 AM
RoyGBiv's Avatar
Quoted: 75 Post(s)
Liked: 35
Yes. And, since they sent you an H21, you should call and ask them to give you the AM21 free. When I bought a new HR22, I told the CSR that I needed the AM21 for OTA that was not provided by DirecTV. He said he couldn't give me one, but when I placed the order (which I did while we were on the phone), he then gave me a credit for the same amount.
SMK
RoyGBiv is offline
post #73 of 81 Old 01-06-2012, 03:48 PM
jeffdb27's Avatar
I am considering switching from DISH to DirecTV. I really love that my DISH has two OTA tuners. Is there (going to be) anything like the AM21 that will work with DirecTV's new whole-house system. I have been told by someone who has that system that there are no built-in OTA tuners.
Jeff
jeffdb27 is offline
post #74 of 81 Old 01-06-2012, 05:22 PM
ProjectSHO89's Avatar
Quoted: 207 Post(s)
Liked: 110
The AM21 is dual-tuner.
You have to add it to one of the other D* boxes.
ProjectSHO89 is offline
post #75 of 81 Old 01-06-2012, 08:42 PM
adb
adb's Avatar
I don't believe the new D* boxes have a place to connect the am21 tuner.
adb is offline
post #76 of 81 Old 01-07-2012, 06:25 AM
Quoted: 207 Post(s)
Liked: 110
Yes, they do. The AM21 connects to the USB port of the receiver.
post #77 of 81 Old 01-10-2012, 07:24 AM
jeffdb27's Avatar
Thanks for the information. I'll have to look into this further. Sounds promising.
Jeff
jeffdb27 is offline
post #78 of 81 Old 01-11-2012, 09:02 AM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
The AM21 will connect to any of the DirecTV HD boxes (including the new HR34 Home Media Center)
post #79 of 81 Old 01-11-2012, 02:55 PM
Beerstalker's Avatar
Liked: 24
IT will connect to any newer than the HR20 or H20. Those two already have ATSC tuners built in so the AM21 won't work with them. But HR21 and greater, or H21 and greater work fine.
Beerstalker is offline
post #80 of 81 Old 01-11-2012, 03:12 PM
rad
rad's Avatar
Quoted: 24 Post(s)
Liked: 24
Jeff
Just so you know, adding the AM21 does not increase the number of concurrent recordings. For the HR21->HR24 you're limited to two, for the HR34 it's five total.
rad is offline
post #81 of 81 Old 01-14-2012, 08:36 AM
RoyGBiv's Avatar
Quoted: 75 Post(s)
Liked: 35
And with the HR34/AM21 combination, only two of the five concurrent recordings can be OTA as the AM21 has only two OTA tuners.
SMK
RoyGBiv is offline
Reply HDTV Technical
