OTA recommendations for deep fringe - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 58 Old 05-13-2008, 07:51 PM
jhe
jhe's Avatar
Sorry to disappoint you folks but I removed my Winegard 4800 preamp. In it's place I added dual 20 db preamps, both in my basement neither on the mast yet.
Hooked up to my old LG tuner I got 2 more stations. So with 40 db gain I have no signs of overload on any station and getting 2 I could not get without the preamp.
Then hooked up a Zenith converter box and got another 8 channels solid.
I am only 11 miles from lots of powerful stations.
When you want to get stations at -80 to -100 dbm don't expect anything without preamps. If I run without them I lose well over half my stations! My weakest now that comes in good tvfool lists at -103 dbm. Strongest are listed at -41 dbm.
Excluding the grey ones weaker than -110 dbm I am getting all stations I expect except one marked with adjacent channel and cochannel issues.
Where I am I can get the -40 dbm range stations easy with just an indoor antenna (need either a preamp or it must be near a window.) but they still work good with my high gain and outdoor tower antennas. Without preamps I lose all stations weaker than about -60 dbm.
My new preamps are a Research Communications and then a Kitztech.
I have most all RG11 cabling. Several splitters before signals get to my tuners, so the overload issues would be the preamps mostly.
A friend of mine is even closer to the tv towers, about 5 miles maybe. He can't use dual preamps but his 4800 alone works well for him. Has a Parascope too.
Both in his case and mine there is no line of sight, which is why the locals are at -41 dbm.
I have to thank you folks for making me try this! I was actually trying to get overload to see how close I was to problems with only 28 db gain in the 4800!
jhe is offline
post #32 of 58 Old 05-14-2008, 06:30 AM - Thread Starter
ziggy29's Avatar
Interesting, because if you look at my OP you'll see that my goal was to pick up stations in the -101 to -108 range (give or take). I don't have a preamp yet -- just a 91XG -- and my initial tests (without fine tuning) saw most of these signals coming in loud and clear with the antenna less than 12' AGL.
I suspect that I'll need to see how various weather and atmospheric conditions affect the reception; it's possible that I happened to run my tests under ideal conditions. I suspect I may use a preamp, but if I do, given the apparent strength of the signals already I'll likely choose one with relatively low gain and high tolerance for overloading (because of ch 27).
ziggy29 is offline
post #33 of 58 Old 05-14-2008, 12:59 PM
jhe
jhe's Avatar
And I am a bit amazed that ziggy29 can receive anything at the -100 dbm levels without a preamp! I never have even received signals at -75 dbm without a preamp using about 4 different antenna setups.
Thanks Rick0725 for the calculator, I will try that out later.
But quickly let me say I am not hiding anything that I know of. One difference for me from Texas I expect is we have more hills here that give me excessively bad multipath with quite a wide range of delays. Often see multiple ghosts on analog. With my older tuners 2 degrees errror from optimum aim can lose me a channel and hang up the tuner so I have to power down and up. Wet ground also requires re-aiming my antenna for most channels. I expect this has a significant impact.
I also note with tvfool calculated for my work location which is about 3 miles from my house the Needham MA tower signals (main Boston stations) come in at over 10 db stronger. My line of sight is also blocked by hills fairly close in that could cut my signals maybe more than the model. I think the hill blocking me from Needham is about 3 miles away.
I was surprised too that dual 20 db gain preamps don't seem to overload.
My 4800 was only tried after using no preamp and then 2 different ones near 20 db from Channel Master and Winegard. It got me better results. 2nd best was the lower gain Winegard. The Channel Master one was useless though it seems generally highly rated.
It is true that I benefit for the NH stations (which I want the most) by having them opposite to the strong stations. However the RI and NewBedford weak stations are also coming in right in line with the strong Boston ones.
Back when I first set up my antenna in 1999 or so, digital was much weaker on all channels and I would lose about 3 key stations without the 4800 preamp use.
Today I need all this stuff to get PBS (HD feeds) and some other NH stations.
jhe is offline
post #34 of 58 Old 05-14-2008, 05:47 PM
Falcon_77's Avatar
Quoted: 18 Post(s)
In CA can receive all but 1 local station w/o a pre-amp from the 4228 in my attic, but I suspect my signals are stronger than the TV Fool plot indicates (-88 to -102). I get about 80% with a rabbit ear/loop combo in my window, un-amped and all of them with a 4221 in a window. Not having any local stations within 50 miles helps.
In CT, I'm lucky to get a whisper w/o a pre-amp on the distant stations in the -100's. However, I'm dealing with local stations within 15 miles at this site and the 7777 was most definitely overloading (and will be replaced).
There's no substitute for actual tests, but TV Fool is still an excellent tool.
Falcon_77 is offline
post #35 of 58 Old 05-14-2008, 06:21 PM
Falcon_77's Avatar
Quoted: 18 Post(s)
Originally Posted by Rick0725 View Post
enclosed is an example from the spreadsheet using an example at my home.
I don't see where this spreadsheet takes into account the difference between NTSC peak power and ATSC average power. I'm assuming this is an important difference when considering overload or am I missing something?
post #36 of 58 Old 05-15-2008, 08:43 AM
jhe
jhe's Avatar
The calculator looks useful as a start except I don't have excel. But there are limitations.
1 I see vast differences as to what works for both preamps and antennas with each of my different tv tuners, none of which have any proper specs.
2 It doesn't take into account the probably 20 db of signal I lose just from the multipath canceling chip. I realize this doesn't help as far as the preamp overload but it does absolutely change the amount of IM you may have to live with to get the signals needed up out of the noise.
3 With lots of stations at high power and different channel mixes I am quite sure there are lots of variations as to what is harmful and what can be ignored. IM that is not at the frequency you want should be able to be ignored.
4 The biggest problem is the big guess for loss from blocking line of sight. 10 db error here would be easy and make a completely different preamp viable. I suspect this would also be where the tvfool calculations are most in error too, though I have not seen anything that better matches my received signals.
In my situation I have approx 1/3 of my signals at 11 miles away and the other 2/3 are at mostly 40 to 50 miles. Also the calculator seems to worry about the overload at the tuner which for me is a non-issue due to the number of splitters I use to feed various devices. So I would only have problems from overload at the preamps which just doesn't seem to happen in any observable way. If I was to judge by the LG tuner I might have thought I was getting some overload that was wiping out some weak signals I should get, but once I got the Zenith and found virtually everything receivable just fine that the LG was missing that theory went out the window.
It is interesting that the Zenith gets me all the missing stations that are in the direction of the strong ones! LG does fine on at least 2 of the 3 I get in the opposite direction. So I assume this means the older tuner can't handle a mix of strong and weak signals nearly as well.
So far I have tested with my LG HD tuner and the Zenith converter box only. Next I will try out my Samsung 260F and see what works there. My new preamp will be going up on the mast soon as I get my new rotor, but with the two 20 db ones in series working I don't think that will do anything except improve my noise floor. There should be no more than around 4 db loss between my tower mount vs my current basement location.
jhe is offline
post #37 of 58 Old 05-15-2008, 11:28 AM
jhe
jhe's Avatar
the system losses are taken into account with the following entries
???? Add'l Loss in excess of Line-of-Sight, due to Terrain/Clutter Diffraction, Attic/Indoor Loss, etc. I typically add 2-4 db for inside (attic), 6 db for hills and multipath. If I have to choose between 2, I choose the one with less gain. If I have both availabe, I swap...both most users do not have that option.
???? Rcv System Loss. length of coax, splitters, filters. I calculate the loss on the shortest and longest run and see where it takes me. do the math so to speak on paper and outline the losses associated with splitters, length of coax run other misc gadgets in between.
adding 10 db to the first entry narrows me to a Titan...cm7777. And eliminates the others. the ones eliminated are the key. less risk making that internet purchase. I stick with the popular amps at cm and winegard, the electronics inside are about the same within the product category.
this is not an exact science. you just want to get in the ballpark, you will not get exact, but you are able to eliminate the risky components with some data manipulation...which is better than guessing.
give me an example and I will calculate it for you to see where it goes for the heck of it.
channel
transmit power - strongest channel
misc losses
distribution system losses
mileage to towers
OK. The key channel I want now (till Feb.) is 57.
It has 589 kw at 49 miles
Strongest channel is 11 miles away at 948 kw at channel 42
I estmate about 40 ft of RG 11 cable with preamps now at about half way pt in cable run.
I'm guessing the strong stations I lose 15 db from hills and more like 25 db for the distant station I want. Both are listed as "1 edge" in tvfool.
tvfool reports I would need to be at 42 ft for LOS to ch 42 and at 132 ft for ch 57.
My antenna is at 25 ft.
Signals are weaker in summer as they have to pass through a grove of trees.
My dual blakes need transformers and a combiner so that should be about a db loss.
Distribution losses I'd estmate at about 11 db for 3 2-way splitters.
Since you don't cover my current preamps figure I'd be using AP4700 or AP4800 Winegard units since they used to both work marginally for me but not as good as my new ones.
correction: Forgot to check the old analog stuff. So:
Strongest analog channel is channel 62 at 4497 KW and also 1 edge and 11 miles
jhe is offline
post #38 of 58 Old 05-16-2008, 06:18 AM
jhe
jhe's Avatar
Thanks Rick0725. That sounds really close to what I get here! Except my locals seem to work OK with the high gain preamp also, except when airplanes fly over. I may add a second antenna just for the locals and lower gain as you suggest.
My AP4800 lately has not been getting channel 57 but something happened in the last year. I'm thinking it might have been damaged by nearby lightning. It had been working pretty good: I normally got a nice picture fully watchable about 80% of the time at nights, but rarely during the day time.
My current new more expensive preamps seem to fix that and I am getting solid signals reading up in the Good range of the LG meter during days too. (with AP4800 when it was working I got typically bottom end of Normal on meter. Plus I am now pulling in stations I could never get before. Maybe these handle overload better as well as having lower noise specs.
jhe is offline
post #39 of 58 Old 05-17-2008, 10:29 AM - Thread Starter
ziggy29's Avatar
I have to wonder if there's something unusual about our geography here.
First of all, I'm doing some more testing this weekend. I purchased and built a YA-1713, though I won't need it until KTBC-DT moves from 56 to 7 next year. I tested it with an NTSC tuner in the bedroom and got a decent picture on channel 7 (where the analog signal currently is). So I'm set when I need this next February on ch 7.
Now then -- check these out. Looking at my TVFool info in the initial post of this thread, you'd think reception was a challenge (basically shown as -101 to -108 dBm). But with the 91XG and NO other amplification or preamp, I've temporarily mounted it on a T-post near the garage for testing. Here's the location of it -- it's pointed roughly (but not exactly) in the direction of the towers at 119 and 120 degrees and about 5' off the ground. Fortunately, the T-post was oriented in a way that points the antenna to around 120-125 degrees:
I have absolutely locked on the distant Austin locals 59-60 miles away. Here's a screen shot going into my DirecTV HR20-700 for KEYE-DT (42-1, actual channel 43):
I saw tuner 2 get as high as 92%.
Even the toughest of them (KNVA-DT) is coming in at 40-45% strength and giving a solid and consistent signal. All the other stations in this direction on that antenna farm are in the 60s and up, with most being in the high 70s and low and mid 80s. Again, this is only 5' off the ground and with trees in the way, and with a 100' run of RG-6.
Also ch 27 (KXAM-DT 14-1) is around 90-91% and isn't causing a problem (as it shouldn't without a preamp).
I have to wonder if unusual geography is playing into this. What I'm seeing is nothing at all what I would have expected from the TVFool results. I'm thinking that I'm not even going to bother with a preamp at all, at least not for now based on what I've seen. This garage in the background is where I plan to mount the antenna permanently, with the masts going just above the roofline maybe 3-4 feet apart, just between a couple of trees. My original intention was a rooftop mount, but an outside wall mount might be good enough, especially since it will mean I can adjust it without getting on the roof.
ziggy29 is offline
post #40 of 58 Old 05-17-2008, 09:52 PM
Falcon_77's Avatar
Quoted: 18 Post(s)
Impressive results. Looking at the temporary mount on a fence has me concerned (a fence like that will reflect signals), but there is no substitute for results.
A couple years ago, I was convinced that OTA wouldn't work at my location. My first tests were with a Terk antenna in my computer room (A bad idea, with so much noise). Antennaweb almost steered me away again months later, but sometimes DTV can work wonders.
How do the analog UHF stations look on the 91XG?
post #41 of 58 Old 05-18-2008, 01:40 AM
AntAltMike's Avatar
Quoted: 140 Post(s)
Liked: 63
The channel 27 Jointenna will reduce the signal strength of channel 27 by about 20 or so dB with negligible effect on your nearest lower (21) and higher (33) channels.
Preamplifier and tuner overloads have multiple deliterious characteristics that are nearly impossible to calculate in systems in which there are significant differences in signal levels but generally, when a preamp input is excessive, the degradation first becomes visible on the weaker channels, not the stronger ones.
If you have any problem with unamplified reception of the weaker channels and if you decide to go with the preamp, the Jontenna will do about as much for you as the Tin Lee product and costs only 1/3 as much. The advantage of the Tin Lee filters is that they are better shielded, which is important if you are near several transmiters, as most of my installations are, but that shielding is of negligible benefit in your situation.
AntAltMike is offline
post #42 of 58 Old 05-18-2008, 10:07 PM
jhe
jhe's Avatar
Signals per tv fool are -41 dbm to -110 dbm
Tested tuners: Zenith converter DTT900, Samsung 260F LG 3410A
preamps none, Research Communications (9260), or Research Communications with kitztech (kt100VG).
11 channels with LG and no preamps
12 channels with Zenith Converter and no preamps
12 channels Samsung with 20 db (1 preamp)
14 channels Zenith with 20 db (1 preamp)
15 channels LG with 40 db (2 preamps)
19 channels Samsung with 40 db (2 preamps)
22 channels Zenith with 40 db (2 preamps)
Note: channel 13 VHF has it's own Channel Master preamp and was not varied, but Samsung could not receive it!
I assume I am not getting any overload issues even with 40 db gain due to getting more channnels with all tuners, and due to signal meters reading higher in all cases as I added gain for all channels or reading the same for some strong ones.
See previous posts for info on splitters, antennas, etc.
Preamps are still in my basement. The Research Communications unit will be going on my mast next.
Channel totals were not necessarily completely glitch free but were fully watchable. Did not count any with pictures that froze or blocked badly.
When I did get glitches it was often on the stronger stations too, but all cases the more preamp gain the less problems I had with glitches.
Finally I noticed that the Zenith converter could handle far wider antenna angle range than the other tuners for most channels.
jhe is offline
post #43 of 58 Old 05-19-2008, 07:15 AM
AntAltMike's Avatar
Quoted: 140 Post(s)
Liked: 63
I just went back and read a few earlier posts in this thread and will contribute the following
1. Winegard AP4800s actually have 36-38 dB gain between about 500 MHz and 530 MHz. A few years ago, someone reported observing that on his unit and so I bench-tested tested two of mine and found the same thing.
2. Manufacturers tend to use input signal level as their reference level for preamp overload, whereas most tend to use output level as their reference for distribution amplifier overload. FWIW, if you work the numbers backward, the Winegard 4800 and 4700 have the same maximum output.
3. Winegard briefly made an intermediate gain product it called AP4747 with 23 dB of gain. I bought a few of those. The slip of paper shipped with them is for the AP4700 and AP4800, and makes no mention of the AP4747. I even called Winegard up and asked about it, but the technician I spoke with couldn't find any references to such a product in his files. A few years ago, an AVSForums member working for a big company said they were a specialty product his firm had Winegard make up. I was never able to verify that, but it is as good an explanation as anything I can dream up myself. I assume that it uses the same power amplification component as does the AP4700 and AP4800.
Anyway, I compared the performance of two Winegard AP4747, 23 dB gain amplifiers with two Channel Master 0064DSB amplifiers with 23 dB of UHF gain. The Channel Master amplifier's published specs indicate that their overload point is about 10 dB LOWER than Winegard's published spec, but the Winegard's started visibly beating up a weak analog channel the antenna was receiving when the signal input and output signals were about ten dB LESS than the point at which the Channel Master unit began to cause those symptoms.
We don't know diddley about calculating the interference that strong signals will cause on weak signals in an overdriven amplifier. ChannelMaster used to define overload as the point at which 5% sync compression took place, but then one year, they instead defined it as the point at which -46dB of cross modulation was developed, in each case with a channel load of four identical strength channels. Coincidentally, the numerical overload figures they gave were exactly the same for excessive cross-mod as for excessive sync compression. Coincidence, or did the sales team simply acknowledge that more customers were asking for intermodulation specs and attempt to accommodate those customers by calling their sync compression limits the new cross-mod limits?
If you look at the published overload specs for high quality power amplifiers, they have several different ones published because cascades of amplifiers interact in different ways and can exceed one type of intermodulation threshold first in one configuration but exceed another first in another config.
It appears that the more responsible, mast-mounted preamp manufacturers are now furnishing as their published overload specs a level at which an amplifier carrying just one channel will develop some arbitrary reference benchmark of on-channel 3rd order IMD. From there, an engineer is supposed to work from that benchmark and figure out how it affects his system. Some rules of thumb I have been taught previously are: 1) that each time you double the number of equal strength channels, the maximum input or output level for that amplifier at which the benchmark 3rd Order IMD stays at that level goes down by 3dB, 2) that each time you double the number of fully driven amplifiers in a cascade (for home owners, that would typically be two amplifiers), your maximum input/output must go down by 6dB, and, 3) for each 1dB you lower the input/output, you reduce 3rd order IMd by 3 dB.
I have also read in a technical paper that when an amplifier develops -40dBc on its own digital channel, it develops 12 dB lower 3rd order IMd (-52 dBc) on its adjacent channels. I am in a market where my local 39 (temporary channel assignment) often exceeds desirable channel 38 and 40 by twenty or more dB, but while my receivers can accommodate adjacent channel signal differentials of 26 to 28dB, the intermodulation distortion caused by the strong channel 39 will exceed the maximum endurable levels for
processing of channels 38 and 40 before it exceeds the level it inflicts upon itself. I have a similar, vexing problem with temporary strong digital channel 51 and weak digital channel 52.
Cable TV engineers have it easy because all of their signals are at the same level and because their spectrum is fully loaded, so they are engineering to avoid one uniform, interference threshold level, but in the off-air antenna business, we don't have a clue how to figure out the nature and levels of the interference that our amplified spectrum throws on our weak channels. Fortunately for us, the ATSC waveform can take a licking and keep on ticking, but because everyone's situation is unique, it explains why people here encounter so many situations in which someone is certain that something will work for someone else that doesn't work for them, and vice versa.
post #44 of 58 Old 05-19-2008, 07:53 AM
AntAltMike's Avatar
Quoted: 140 Post(s)
Liked: 63
I doesn't.
It is.
...or am I missing something?
You aren't.
post #45 of 58 Old 05-19-2008, 08:00 AM
jhe
jhe's Avatar
how are two 20 db preamps wired in your setup?
Try a Winegard ap 3700 preamp for VHF only on a separate line and combine the separate uhf lines with the pico uvsj.
This is a VHF only pre-amp with a gain of 17 dB. With 2.6 dB of noise and medium overload tollerance . the AP-3700 is one of the lowest noise VHF only pre-amps available. It has a built in selectable FM Trap and UHF is bypassed.
http://www.solidsignal.com/prod_display.asp?prod=AP3700
Thanks for the VHF preamp tip. For now I am happy since I get our channel 13 on the LG I use most (due to the hard disk) but after Feb we will have a bunch more VHF to get.
My current VHF preamp is a Channel Master with FM trap. I think I have a Blonder Tongue UV combiner.
My UHF preamps are right beside each other currently in my basement. Antenna line feeds into the Research Communications unit, then it's power supply. Then to the kitztech all in one box and to the line up to my tv.
There is maybe 2 ft of cabling between the boxes.
Been pondering a lot why this all works for me and others get great signals with just an antenna and no preamp when they are talking levels at -100 dbm that I have trouble getting with preamps. I think it all boils down to three things:
1 tvfool states that their resolution is somewhat limited. I can see from topo maps that I am fully blocked from Needham towers by a hill but tvfool says I have line of sight. This must mean my locals are weaker than specified.
2 I think due to error correction and the more evenly used spectrum on each channel that digital tv may be somewhat more tolerant of overload than analog in preamps.
3 I am in a bad multipath area and I suspect that equals somewhere about 20 to 25 db loss of usable sensitivity at my tuners, especially the older generation ones.
I think the Zenith performance is from this better multipath handling than any big sensitivity difference. It does seem to handle a mix of strong and weak signals better too, since it is the one that pulls in RI stations best, which are about in line with the locals in Needham MA.
jhe is offline
post #46 of 58 Old 05-19-2008, 08:05 AM
AntAltMike's Avatar
Quoted: 140 Post(s)
Liked: 63
...I don't have excel.
A free downloadable .xls reader is available on the Microsoft website.
Regarding the rest of the commentary here, you people can buy old, analog field strength meters on eBay for typically $20 to 30, and you can buy old digital FSMs designed for analog only signal measurement for typically $100 to $200. You can get a pretty good approximation of your digital signal strength by adding 8dB to the readings they develop when used on a digital waveform.
post #47 of 58 Old 05-19-2008, 12:25 PM
Falcon_77's Avatar
Quoted: 18 Post(s)
Are there any you would recommend?
I'm considering using a Leader 941, which would probably be better than looking at the AGC reading on my TV, which is the closest I can get to a signal strength reading right now.
post #48 of 58 Old 05-19-2008, 04:21 PM
AntAltMike's Avatar
Quoted: 140 Post(s)
Liked: 63
I often use a Leader 941 to measure digital signal strength. The nice thing about it is it only weighs a couple of pounds. The bad things about it are, 1) it uses C cells rather than internal rechargeable batteries, 2) it only reads to whole dB, and, 3) you can't select exact frequencies: you can only select the aural and visiual carrier frequencies used in the cable standard and broadcast off-air channel plans.
post #49 of 58 Old 05-20-2008, 05:21 PM - Thread Starter
ziggy29's Avatar
Getting closer to the finished product. (Or at least finished for now.)
All I need now is the wall mounts and the mast which are coming soon. I know where the wall mounts will go and I nailed in horizontal 2x4s between the studs where the mounts will be attached to the garage wall in order to add strength to the install point.
I put a conduit into the ground and ran the coax from the garage to the house underground through the conduit today, a run of about 40'. I more thoroughly tested the YA-1713 on analog ch 7 into the bedroom, since the digital signal for that FOX affiliate is moving from 56 to 7 in February, and got a pretty solid analog picture. I just don't know whether to mount the VHF yagi on top or the 91XG. I'll probably put the 91XG 3-4' higher than the YA-1713 (which would be just above the roofline) unless I *need* the extra gain on channel 7.
Signals are holding up great, but we haven't had any bad weather since I started mounting the antenna to a T-post on Friday in its temporary position. Hopefully the rest of my mounting hardware and supplies will come by Friday so I can get this up, finished and grounded over the weekend.
ziggy29 is offline
post #50 of 58 Old 05-20-2008, 05:37 PM
Falcon_77's Avatar
Quoted: 18 Post(s)
Both UHF and VHF show improvement for increased antenna height, though for different reasons at times.
If analog 7 is strong in the bedroom, you can probably have it on the bottom of the stack. This seems to be the most popular configuration for a separate UHF/VHF stack (UHF on top and VHF on bottom).
KTBC-DT 7 will be relatively strong at 30kW, but I see their Construction Permit is for a directional antenna. The coverage for Llano appears to be comparable from the service area contour, however.
http://www.fcc.gov/fcc-bin/FMTV-serv...DT1238906.html
post #51 of 58 Old 05-20-2008, 05:53 PM - Thread Starter
ziggy29's Avatar
Thanks. "Strong" is a relative term for analog TV. There was a little bit of fuzz but the picture was entirely watchable with no dropouts. And this was on a setup where I drove a spare T-post into the ground just long enough to have the VHF antenna attached to it, about 5' AGL and right into thick bushes no more than 25' away.
So I'm pretty confident that will provide an adequate signal, especially since the antenna will be higher, less obstructed by obstacles and the signal should be stronger come next year.
ziggy29 is offline
post #52 of 58 Old 05-23-2008, 02:10 PM - Thread Starter
ziggy29's Avatar
It's not permanent yet (still need to ground it and get all the cabling where I want it) but I got the setup mounted on the side of the garage, with a couple feet of mast buried into the ground.
This is a 91XG about 13' AGL. There is no amplification and currently about twice as much coax as I need (125' to the tuner, currently).
Checked the signal meters. Even KNVA-DT (49) is coming in close to 60%. All the others are in the 80s. KVUE-DT (33) is coming in around 96%. On this tuner, I get lock on just about anything above 40.
Heck, this thing is even getting a 65% signal on KAKW-DT (13), which is a Spanish station I don't care about. So apparently this thing has at least some high VHF gain, especially since the antenna is pointed near 120 and the KAKW signal is almost 30 degrees counterclockwise to it.
Guess I need to get it down before any thunderstorms come so I can get it grounded (will be tricky since I mounted it to an outbuilding and my understanding is that this should be grounded to the house ground into the electric panel 30-40' away). Once grounded I can secure this more permanently.
Good stuff. This exceeds even my most optimistic expectations.
[Edit to add: I lowered the mast about another 1.5' into the ground to help stabilize the top of it in the wind and avoid the need to guy it. I lost a little signal on KNVA-DT but actually gained a little on the other channels, and sometimes hit 100% on KVUE-DT.
There's still a place for the YA-1713 about 3' below the 91XG, just above the roofline.]
ziggy29 is offline
post #53 of 58 Old 05-28-2008, 04:39 PM - Thread Starter
ziggy29's Avatar
(Probably) final update for a while.
I more or less have everything in place. Wall-mounted mast on the side of the garage, well-secured and also buried 2' into the ground for stability, mast 13' high. 91XG on top, YA1713 on bottom about three feet below.
I have the coax coming down from the 91XG at the right length. I need to shorten the length of the coax from the YA1713 to the UVSJ (mounted under the eaves) which is what you see dangling in the picture. It has 15' but I only want 6'.
It's all grounded. I had an electrician look at this yesterday and make sure it would be adequately grounded. I showed him what I planned to do and he said that was enough. So I got the mast clamp and the ground rod clamp and secured the ground from the mast clamp through the coax block to the ground rod.
Despite being directional, adding the YA1713 for high VHF kicked up the signal meter for KAKW-DT (62-2 on real ch 13) from 40 to 99-100% even though it's about 25-30 degrees skewed from that station's tower. Not that I need it since it's Spanish, but if they ever change formats, I'm set. This antenna should have me good to go with KTBC-DT moves from 56 to 7 in February.
KNVA-DT (54-1, real ch 49) is still a bit challenging. The signal is now in the 40s and occasionally low 50s; the picture is usually good but occasionally breaks up. I'll leave it at least until Feb 2009 since this station will be powering up more at that time. If it's still trouble then, I'll consider a preamp. Everything else remains in the high 70s and above. I'll be interested to see what storms do to impact the reception.
For a data point, adding the YA-1713 about 3' below the 91XG didn't seem to impact the existing UHF signal strength one way or the other.
My thanks to all who helped me determine the right components for this setup. I continue to be amazed at what a good OTA picture I can get -- and with HD -- this many hilly miles away from the towers.
ziggy29 is offline
post #54 of 58 Old 05-28-2008, 07:40 PM
Falcon_77's Avatar
Quoted: 18 Post(s)
Per their DTV transition report filing, KNVA wants to use the current facility as the post-transition facility:
http://fjallfoss.fcc.gov/prod/cdbs/f...ibit_id=618114
Hopefully, they will file for an increase in ERP when the contour freeze is lifted in August. Continuing to use the existing Non-Directional antenna is probably the main objective and not the directional antenna proposed by the allotment table. Perhaps you can write them and ask for more power.
Other than that, I'm glad it's working well. It's always nice to hear success stories.
post #55 of 58 Old 05-30-2008, 06:10 PM - Thread Starter
ziggy29's Avatar
Hmm. The TVFool info I looked at showed they were powering up in February -- from the current 197 kW to almost 355 kW. What you showed was an engineering survey recommending that they not change their current ERP?
The birds have already discovered the 91XG. Seems like a popular place to build a nest.
If I really needed more power from a CW affiliate, I could probably throw another low VHF antenna up there and point it to KCWX, which should come in considerably stronger. Seems odd they'd still be on low VHF (ch 5) after 2/2009 except that they had their requests for 8 and 9 rejected because of interference issues (more than the allowed 0.5%).
ziggy29 is offline
post #56 of 58 Old 06-11-2008, 05:50 PM
Falcon_77's Avatar
Quoted: 18 Post(s)
KNVA has filed a maximized application for 49, so perhaps they aren't completely pleased with 197kW after all. If granted, the ERP would be increased to 500kW.
http://fjallfoss.fcc.gov/prod/cdbs/f...ibit_id=645616
http://fjallfoss.fcc.gov/cgi-bin/ws....01&fac_num=144
Hopefully, this would be enough to make it reliable.
post #57 of 58 Old 06-23-2012, 10:06 AM
Grigor Rasputin's Avatar
jhe,
I,m here in Burlington, MA trying to get WLNE and WJAR (from Providence)
reliably with my newly installed CM 7777. What I'm experiencing is a total wipe-out
of all channels, including the close Boston channels (11 miles) in the Needham area.
The strong Boston channels are directly in line with the Providence antenna farm, in
Rehobeth, MA. Is it really possible that the loss of all channels is attributable to the
overdriving of the 7777 pre-amp? Since I'm a newbie to OTA I know I would benefit
greatly from any remarks you may make about your related experiences.
Thank You, GR
Grigor Rasputin is offline
post #58 of 58 Old 06-23-2012, 03:09 PM
rabbit73's Avatar
Quoted: 494 Post(s)
Liked: 206
NOTE: Grigor Rasputin is not the thread starter, but his problem is similar, so he has posted at the end of this old thread. He is talking to jhe in post #45 above who is in Lexington, MA.
I think you should have started your own thread GR, but maybe this will work. Don't be surprised if admin separates your post out to a new thread.
GR:
Welcome to the Forum. Your tvfool report for Burlington looks like this:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1349de0acca553
A tvfool report with your exact address would be more accurate, but you probably can't post an active link yet. You can, however, give us the URL in bold type near the top of the report and we can post it.
Yes, quite likely. It is also possible that your tuner is overloaded.
There are preamps that can tolerate higher signals levels than the 7777, but you still need to be concerned about the tuner.
Rehobeth, MA.
That makes it a very difficult problem to solve, because your local signals are about 35 to 40 dB stronger and in the same direction.
Don't get your hopes up, but one possible idea would be to insert an attenuator between the antenna and the input of the preamp. Adjust the value of the attenuator (perhaps 10 to 15 dB) to eliminate the overload, but still retain sufficient gain to help you with the Providence signals. You could also try an attenuator between the output of the CM power supply and the TV. The best location for an attenuator would depend upon which is being overloaded first, the preamp or the tuner. Without even adding the antenna gain, your strongest signal (WMFP at -24.2 dBm) plus the preamp gain, puts you at the overload point of the tuner.
ATSC Recommended Practice:
Receiver Performance Guidelines
Document A/74:2010, 7 April 2010
5 RECEIVER PERFORMANCE GUIDELINES
5.1 Sensitivity
A DTV receiver should achieve a bit error rate in the transport stream of no worse than 3x10E-6
(i.e., the FCC Advisory Committee on Advanced Television Service, ACATS, Threshold of
Visibility, TOV) for input RF signal levels directly to the tuner from –83 dBm to –5 dBm for both
the VHF and UHF bands.
After you got through messing with attenuators, the results probably would not be as good a just removing the preamp, which would be a lot easier. There is an expensive solution which involves separate antennas, two preamps, custom bandpass filters for CH49 and CH51, and A/B switches.
What antenna are you using, and where is it located?
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is online now
Reply HDTV Technical
Channel Master Cm 4228 8 Bay Hdtv Uhf Antenna Cm4228hd , Channel Master Cm 7777 Titan2 Uhf Vhf Preamplifier Cm7777
