EV's Recommended & Top Rated DTV Indoor UHF/VHF Set Top Antenna Review Round-Up Guide - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #3151 of 3347 Old 04-13-2012, 08:05 AM
Dave Loudin's Avatar
Start with the amplifier off and have your TVFool report handy. See if you get all the stations at nearly due south down to KFPB-LD. If so, you're set!
Dave Loudin is offline
post #3152 of 3347 Old 04-21-2012, 10:35 PM
CingKrab's Avatar
Hi:
Would it be possible to get an indoor antenna recommendation based on my tvfool report?
http://www.tvfool.com/?option=com_wr...7fcf77e8e34cbd
I was thinking of a Terk HDTVa but any recommendations would be great.
CingKrab is offline
post #3153 of 3347 Old 04-22-2012, 05:11 AM
arxaw's Avatar
For your channels to the NW shown in green on your TVFool report, do not use an amplified antenna. I would try the budget RS antenna. If not available locally, check ebay.
Indoor reception is impossible to predict, due to different building materials that can block signals. For best results, put the antenna near a wall facing West or Northwest, and away from all electronic devices, including the TV. To extend the coax length, add more, connect a longer piece, using a barrel splice.
arxaw is offline
post #3154 of 3347 Old 04-22-2012, 01:21 PM
CingKrab's Avatar
I would love to try the RS Budget antenna, but I can't even find any listings for it on ebay.ca. What would be the next model that you'd recommend?
CingKrab is offline
post #3155 of 3347 Old 04-22-2012, 01:28 PM
arxaw's Avatar
I found it there with a simple search on their site for radioshack antenna.
http://www.ebay.ca/itm/RadioShack-HD...-/120899240541
arxaw is offline
post #3156 of 3347 Old 04-24-2012, 12:18 PM
stevesr0's Avatar
I understand that in order to post the tvfool link, I need to make 3 posts first? So, this is #1.
stevesr0 is offline
post #3157 of 3347 Old 04-24-2012, 12:18 PM
stevesr0's Avatar
Post 2 of 3
stevesr0 is offline
post #3158 of 3347 Old 04-24-2012, 12:19 PM
stevesr0's Avatar
This is the 3rd of three posts.
stevesr0 is offline
post #3159 of 3347 Old 04-24-2012, 12:28 PM
stevesr0's Avatar
I purchased and installed a Monoprice 4730 indoor/outdoor DHTV antenna.
After installing it about 3 feet above the TV upstairs, I found that the channels were frequently pixelating, freezing or going to no signal message.
With a friend, I tried the antenna out of doors (through a bedroom window) on the same floor and the reception was better but still inadequate.
I contacted Monoprice tech support who told me that their antennas are only for "green" and "yellow" channels. Since antennaweb tells me that my channels are red, blue and purple, if they are correct, I need a more "powerful" antenna.
I found this site and thread where people are kind enough to offer advice, so I am submitting my link to tvfool with a request for advice on a suitable antenna and placement.
My house is surrounded by trees which in all directions are higher than the roof (by more than 20 feet). The area is hilly, so I doubt that any transmitter is in direct line of sight.
My link is http://www.tvfool.com/?option=com_wr...7fcf99c735cd96.
Thanks is advance for any assistance/advice.
Steve
stevesr0 is offline
post #3160 of 3347 Old 05-23-2012, 04:30 AM
Tim_in_NC's Avatar
I'm trying to get a better signal to my Garage TV ... it has an internal HD tuner and I'm currently using a Radio Shack Double Bowtie Antenna like the one pictured here >
I'm having problems getting a good, consistent signal with lots of drops on channels such as 5.1 and 50.1 ... etc ...
Here is my TV fool report ... any recommendations on a better antenna? Thanks
http://www.tvfool.com/?option=com_wr...073b62fbb0c2b0
Tim_in_NC is offline
post #3161 of 3347 Old 05-23-2012, 05:10 AM
arxaw's Avatar
Your existing bowtie antenna should work well for your strong signals at the top of your TVFool list. Many building materials reduce signal strength of indoor reception. Locating the antenna in or near an East/NE-facing window should work best for you. Also locate the antenna away from all interfering electrical/electronic devices. Add a longer coax if necessary.
arxaw is offline
post #3162 of 3347 Old 05-23-2012, 10:19 PM
deltaguy's Avatar
Quoted: 17 Post(s)
If some of the green TVFool channels come in consistently, it may be a matter of location, aim, and height. Different frequencies travel differently, even if they originate from the same location. I know this makes things more difficult because of the need to adjust the antenna, but that's how indoor reception works. Changing the height of the double bowtie by a foot or 2 may be the difference between perfect picture and unwatchable breakups. Indoor reception is learned 1 channel at a time. Good Luck.
deltaguy is offline
post #3163 of 3347 Old 05-24-2012, 05:53 AM
arxaw's Avatar
Exactly.
Finding a hot spot by trial & error (where signals for all channels are relatively clean and strong and free from electronic/electrical interference) is the key to good indoor reception. It will likely yield better results than throwing money at another antenna and putting it back in the exact same location as the previous one.
arxaw is offline
post #3164 of 3347 Old 05-24-2012, 09:04 AM
Tim_in_NC's Avatar
Thanks guys ... I'll keep trying new locations ...
post #3165 of 3347 Old 06-03-2012, 03:04 PM
jeffyscott's Avatar
My 86 year old mom just moved into an assisted living facility. Before considering cable, I thought I'd try an antenna for her and see if she was satisfied with that. Unfortunately, for TV reception anyway, her room is on the west side of the building and the signals all come from the east.
Because she would like something unobtrusive and having limited mobility she can not be fiddling with it, I set her up RCA ANT1450B from walmart.
She did need the amplification, I tried it with the amplifier unplugged and missed more stations and some of the ones she did get would pixelate, etc.
She is picking up all the channels I'd expect except 6.1 (also 6.2) and 10.1 (10.2-10.4 also).
I thought I might get a different antenna and see if she would get more channels. But I'm sure what might be good to try next?
Is there some particular reason why 10 and 6 would no be picked up?
Since I'm not yet allowed to post a link, I will post a follow-up with link to TV fool report.
jeffyscott is offline
post #3166 of 3347 Old 06-03-2012, 03:05 PM
jeffyscott's Avatar
Note that channel 10 is not identified in the linked report, but call letters are WMVS:
http://www.tvfool.com/?option=com_wr...13496a77b6955a
post #3167 of 3347 Old 06-03-2012, 03:41 PM
arxaw's Avatar
Your signals are strong. But you chose one of the worst indoor antennas. This particular model 15-1874 passive antenna from RS would likely work better. I am basing this suggestion on actual experience, in more than one instance.
Put it near a window if possible, and as far away from any and all electronic/electrical devices as possible to reduce the chances of interference. Odds are, there is a reception hot spot in the rooom, somewhere. With indoor reception, the difficulty lies in finding it. Patience and trial & error, with repeated rescanning will likely find it. Adding a longer coax will help you relocate the antenna away from sources of interference, which may include the TV itself. Use a barrel splice for that purpose.
BTW, WMVS shows up on the tvfool report I clicked on, above. Select the "Only Digital" option. It is on real channel 36.
arxaw is offline
post #3168 of 3347 Old 06-03-2012, 07:02 PM
jeffyscott's Avatar
(yep, I saw WMVS I meant it did not list the virtual channel, 10.1)
Well, if I got almost all the channels with a terrible antenna a better one should get them all.
I'd seen that RS antenna recommended here, but thought she'd prefer the appearance of the flat style over the rabbit ears. I was also thinking the rabbit ears would require fiddling...but maybe that not the case any longer with the signals being digital.
Is there any point in putting it in the window when her only windows are on the west and all the transmitters are to the east?
post #3169 of 3347 Old 06-03-2012, 07:22 PM
arxaw's Avatar
TVFool does not always list all virutal channels. Sometimes, only the real transmit channel is listed.
Manufacturers make and sell flat antennas for people who buy on looks instead of performance. They sell a lot of them and occasionally, they even work if one is lucky. But they usually don't work as well as a conventional TV antenna.
The only "fiddling" needed will be extending the VHF dipole rods no more than about half their length each in a "V" and finding a hot spot to place the antenna. With indoor, don't expect an antenna to work as well in one spot as it will in another. And it may be a difference of only a foot or so. Reception hot spots are usually (but not always) near an exterior wall and more likely in or near a window, even a window facing the wrong direction.
YMMV considerably. Indoor reception is a crap shoot that often requires lots of patience.
If reception is not satisfactory, putting the antenna near an exterior wall or window can often be very important. Also, try placing the antenna at different heights in the room. Higher or lower by even only a foot can make a huge difference.
arxaw is offline
post #3170 of 3347 Old 06-03-2012, 08:00 PM
jeffyscott's Avatar
Yes, I've discovered that 10-1 is actually real channel 8, so it is VHF (there is an SD simulcast of it on real channel 36, so that's why the call letters showed up there). That is likely why that one was missed by that antenna, since it has no long rods for picking up VHF signals. Not sure why 6-1 and 6-2 were missed, though, as they are real channel 33.
Anyway, after reading on the different types of antenna at TVfool, I guess the rabbit ears are still the only real option for VHF. I'll guess give that radio shack one a try.
post #3171 of 3347 Old 06-03-2012, 08:14 PM
arxaw's Avatar
Yes, I've discovered that 10-1 is actually real channel 8, so it is VHF (there is an SD simulcast of it on real channel 36, so that's why the call letters showed up there). That is likely why that one was missed by that antenna, since it has no long rods for picking up VHF signals. Not sure why 6-1 and 6-2 were missed, though, as they are real channel 33...
Probably interference on ch 33 where the antenna was sitting, or overamplification by the antenna's amp.
arxaw is offline
post #3172 of 3347 Old 06-03-2012, 10:09 PM
deltaguy's Avatar
Quoted: 17 Post(s)
You could also try the classic single bowtie from RS if it looks better to you. Even though the packaging says "uhf", your PBS on rf 8 is strong enough for it to work for you. RS allows returns, so try a couple of antennas while your at it. I think the bowtie is a better uhf antenna than the RS budget. Good Luck.
deltaguy is offline
post #3173 of 3347 Old 06-07-2012, 07:52 PM
jeffyscott's Avatar
Must be interference, I tried with and without plugging in the amplifier.
Tried the RS 1874, the only way I picked up the one VHF channel was by connecting it with the amp from the other antenna. For the UHF channels the RS 1874 did not pick up some that the other antenna did.
So, since the omnidirectional design seems to work better for this situation, I'm debating whether to leave well enough alone or try this:
http://www.radioshack.com/product/index.jsp?productId=11694069
or this: http://www.shopko.com/detail/philips-digital-tv-antenna-indoor-hdtvuhfvhf/22831
or this: http://www.americantv.com/productpage/Jasco-24746-GE_Futura-_TV_Antenna,054011627?itemCd=054011627&linkBack=L3Byb2R1Y3RsaXN0L0FudGVubmFzLDUwMjI%3D
(those all say they pick up VHF)
or maybe this: http://www.walmart.com/ip/GE-Amplified-Antenna/20976616
post #3174 of 3347 Old 06-08-2012, 11:42 AM
tylerSC's Avatar
Quoted: 821 Post(s)
Liked: 182
Is there any point in putting it in the window when her only windows are on the west and all the transmitters are to the east?[/quote - If you prefer a flat panel style antenna, then the Mohu Leaf usually gets the best reviews for that type of antenna. But could be problematic for some VHF unless signals are strong. They also make an amplified version if necessary. If the Radioshack budget did not work, try upgrading to the Terk HDTVa which adds rabbit ears. Plug it in, but try with amp off and then on to see which way works best. Maybe add a barrel splice and RG6 extension cable if necessary. Another idea is Clearstream 1 Convertible now sold at Walmart for $59. Works good for UHF and also gets VHF at my location, and worked better for me than the flat panel Micron version that was $79. But if wife likes that flat panel Micron version, you could always give it a try. And they sell a RCA-Audiovox inline amp at Walmart for $19.99 that you could always add to it if necessary, and Antennas Direct sells their own amp for this antenna as well. Walmart should be easy returns if you get unsatisfactory results. Just a few ideas there.
tylerSC is offline
post #3175 of 3347 Old 06-08-2012, 02:27 PM
jeffyscott's Avatar
Success!
Since I was returning the RS budget model, I picked up the Antennacraft Amplified Omnidirectional while I was there. It worked great and pretty effortlessly. After trying it in a few spots, the window was the best location for channel 10 (real ch 8), the one VHF channel, as had been the case with the RS budget antenna. Set it up there, ran a full channel scan and it got them all.
It picked up 33 channels (the first antenna had only gotten 22, I think). I deleted 2 weak analog channels and one other analog signal is not perfect, but all the digital channels seemed fine.
post #3176 of 3347 Old 06-08-2012, 03:01 PM
tylerSC's Avatar
Quoted: 821 Post(s)
Liked: 182
Glad that Antennacraft model worked for you. I was wondering about that one as well. It may be similar to the Antennas Direct Micron antenna, but not sure. They had it on sale about a week ago, and if it goes on sale again I might get one to try in my 2nd floor bonus room. I use a CS1 there now.
tylerSC is offline
post #3177 of 3347 Old 06-20-2012, 09:15 PM
HDGTX's Avatar
Hello all, Did anyone catch the advert for an indoor ant here last week, that show a flat indoor ant that was white on one side & black on the other? Do you have the name &/or
web site ? Anyone purchased & tried one out yet?
John
HDGTX is offline
post #3178 of 3347 Old 06-20-2012, 11:07 PM
deltaguy's Avatar
Quoted: 17 Post(s)
A link to TVFool results for your location would be helpful. The Mohu Leaf antenna has a black side and a white side. This may be the antenna. You might be able to receive OTA signals for considerably less money. Please post a TVFool link.
Have you tried other antennas prior? If so, which ones? Do you have a correct-facing window toward the broadcasting antennas?
deltaguy is offline
post #3179 of 3347 Old 06-21-2012, 04:02 AM
ProjectSHO89's Avatar
Quoted: 288 Post(s)
Liked: 131
John
SEARCH keyword "Leaf"
ProjectSHO89 is offline
post #3180 of 3347 Old 06-21-2012, 06:24 PM
tylerSC's Avatar
Quoted: 821 Post(s)
Liked: 182
It is the Mohu Leaf, and is one of the few recommended flat panel style antennas. It comes in amplified and unamplified versions.
tylerSC is offline
Reply HDTV Technical
Terk Hdtva Indoor Amplified High Definition Antenna For Off Air Hdtv Reception , Terk Hdtvo Amplified Hdtv Antenna , Antennas Direct C2 Clearstream Television Antenna , Channel Master 3414 4 Outputs Distribution Amplifier , Eagle Aspen Dtv2buhf Directv 2 Bay Uhf Antenna , Terk Fdtv1a Flat Digital Omni Directional Amplified Indoor Antenna Black
