EV's Recommended & Top Rated DTV Indoor UHF/VHF Set Top Antenna Review Round-Up Guide - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #3331 of 3347 Old 11-08-2014, 05:45 PM
Calaveras's Avatar
Quoted: 1282 Post(s)
Liked: 270
Originally Posted by lkaufma1 View Post
http://www.tvfool.com/?option=com_wr...d2435dff272968
Newbie and looking for suggestions for antenna please.
If you're only looking receive the stations in green on your TV Fool report it should be pretty straightforward since they are all Line-of-Sight and strong.
A Winegard HD7694P an Antennacraft HBU22 or 33 mounted outside and not looking through large trees should work fine.
If you want stations in yellow and red then you'll need a much larger and higher antenna and a rotor. 1 and 2 edge paths are more difficult.
Calaveras is offline
post #3332 of 3347 Old 11-08-2014, 05:50 PM
Liked: 1
Originally Posted by EscapeVelocity View Post
<span style="font-size:medium;"><b>Welcome to EV's Indoor Antenna Round-Up!<br><br>
The Ultimate Internet Guide to Indoor Antennas!</b></span><br><br><img alt="" src="http://i302.photobucket.com/albums/nn88/EscapeVelo/IMG_0105.jpg" style="border:0px solid;"><br><br>
Some introductory thoughts.<br><br><b>THIS GUIDE IS A WORK IN PROGRESS</b><br><br>
These antennas are listed in no particular order. This list of antennas are all recommended and better than average.<br><br>
There is no one best indoor antenna. Environmental factors present a plethora of situations that no one antenna can be best for all of them. In fact, most times the best indoor antenna is an antenna placed outdoors or an outdoor antenna placed indoors. Some may need VHF Hi and UHF, others only UHF, after the Feb2009 shutdown of analog broadcasts. <b>Antennas are a strange brew, sometimes it's more of an art than a science, and while these are generally well regarded antennas for indoor use, Your Mileage May Vary.</b><br><br>
Remember, outdoor placement is much preferred if you can swing it. Even if you get some of these outdoor antennas that are small, flat, and aesthetic and unobtrusive enough to go inside, they will do better outside on a patio or outside a window especially if facing the broadcast tower cluster. Some even put large antennas in attics.<br><br>
These are some of my personal favorites and I have personal experience with many of these antennas. Most are highly recommended antennas by others on the net and other AVSforum members in this thread; and in reviews and tests that I researched on the net<br><br>
The other end of the equation is tuner ability, sensitivity and selectivity. ATSC tuners have dramatically improved over the last couple of years. If you are on the fringe of reception even using the best antenna setups, you may want to consider improving your tuner with a set top box tuner. Both SD Coupon Elligible Converter Boxes and HDTV Tuner Boxes exist. LG and Samsung make great HDTV tuner boxes. LG makes some of the best tuners, and their CECB the Zenith DTT901 currently has one of the most sensitive tuners for those looking to keep using their old CRT NTSC analog sets. You can research tuners and converter boxes in the same subforum that you are now located in AVSforum.<br><br>
Please feel free to add your comments, suggestions, observations, corrections, experiences, questions, etc. They are most welcome.<br><br>
I am not an expert or highly trained and experienced technician, just an amateur enthusiast. I do not portend to be anything else. There are many other people on this site that are much more knowledgable and experienced than I.<br><br>
Special thanks to Seatacboy, golinux, fajitamosaic, Rick313, Rammitinski, and deltaguy, for their encoragement, enthusiasm, guidance and contributions.....and to KenH for making this thread a sticky.<br><br>
I hope this will be useful to others.<br><br>
Please let me know if you like it.<br><br>
Best regards<br><br>
EV<br><br><br><br><b>Newbies start here! Read this first!</b><br><br><div class="quote-container"><span>Quote:</span>
<div class="quote-block"><b>Antennas and Digital Television</b><br><br>
FCC Consumer Facts<br><br>
Federal law requires that all full-power television broadcast stations stop broadcasting in analog format and broadcast only in digital format after February 17, 2009. Broadcast stations in all U.S. markets are currently broadcasting in both analog and digital. If you have one or more analog televisions that receive free over-the-air television programming with an outdoor antenna or "rabbit ears" on the TV, you will either need a digital television (a TV with a built in digital tuner) or an analog television connected to a "digital-to-analog converter box" (which converts digital signals to analog signals for viewing on your analog set) in order to continue to watch programming from full-power broadcast stations. This Fact Sheet provides information on antennas and on what is needed for good quality reception of digital broadcasts.<br><br><b>Try Using Your Existing Antenna First</b><br><br>
First, it is important to know that if your television currently receives good quality reception on analog channels 2-51 with a broadcast antenna, it should be able to receive digital television (DTV) signals, including high definition television (HDTV) signals, with the same broadcast antenna. You do not need to purchase a "DTV antenna" or an "HDTV antenna" to receive DTV or HDTV signals. However, consumers should be aware that if they use a digital-to-analog converter box, they will still need to use an antenna to receive DTV signals.<br><br>
Prior to making any changes to your current antenna or antenna system, you should check to see if it will receive the digital signals being broadcast in your area. Connect your existing antenna to either a digital television or a digital-to-analog converter box connected to an analog TV. Make sure your TV is set up to receive over-the-air broadcasts (as opposed to being connected to a paid provider such as a cable or satellite TV company). It may also be helpful to perform a "channel scan," in which your TV will automatically check to see which stations it can receive. In many cases, this is all you will need to do to watch digital television broadcasts.<br><br><b>For Help With Reception Problems</b><br><br>
If you experience reception problems, the following information and tips may help to improve your reception for digital broadcasts.<br><br>
During the transition to digital TV, many stations are temporarily operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or receiver. Check with the TV station to find out whether they are planning changes that will improve reception.<br><br>
When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen, but you can watch the picture through the noise. Digital broadcasting will provide a clear picture even with a weak signal and in the presence of interference. However, if the digital signal falls below a certain minimum strength, the picture can suddenly disappear. This “cliff effect” means that if you typically watch analog TV stations that have a lot of static and distortion, you may have to adjust or upgrade your antenna system to get a reliably good signal for digital broadcasts.<br><br>
TV reception can be affected by factors such as terrain, trees, buildings, the weather (rain, wind, humidity), and damaged/deteriorated equipment. Often digital reception can be improved just by changing the location of your current antenna. Moving it away from other objects and structures, or placing it higher can often improve reception.<br><br>
Many antennas need to be oriented or aimed to get the best signal from the desired station. For indoor antennas, you may need to do this manually by trial and error. For outdoor antennas, a rotor that re-orients the antenna can improve performance, particularly when trying to receive stations that transmit from different locations.<br><br>
Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.<br><br>
Simple indoor antennas, such as rabbit ears, provide minimal performance that may or may not be suitable for your location. If you are unable to obtain satisfactory reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).<br><br>
Generally, an outdoor antenna will get better reception than an indoor antenna. If you already have an outdoor antenna and are getting good quality reception from VHF and UHF channels, your antenna should work fine for digital television.<br><br>
The performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.<br><br>
Try to keep the length of wire between your antenna and digital receiver as short as possible for best reception.<br><br>
You can use a single antenna to provide digital broadcasts to multiple TVs in your home. Remember, however, that each analog TV connected to your antenna will need its own digital-to-analog converter box to view digital broadcast programming.<br><br>
"Splitters" that are used to connect a single antenna to multiple receivers reduce the amount of signal available to each receiver. If you are having problems, check to see whether reception is improved without the splitter. In some cases an "active" splitter that includes an amplifier can solve the problem.<br><br>
If you are near a station's broadcast tower, reception of that station, as well as other stations, can be impeded by signal "overload". Consider using an "attenuator" or removing amplifiers to improve your reception.<br><br><b>If you decide to replace or upgrade your outdoor antenna, websites such as <a href="http://www.antennaweb.org" target="_blank">www.antennaweb.org</a> and <a href="http://tvfool.com/" target="_blank">http://tvfool.com/</a> provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive.</b> If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.<br><br><a href="http://forum.ecoustics.com/bbs/messages/34579/468153.html" target="_blank">http://forum.ecoustics.com/bbs/messa...79/468153.html</a></div>
</div>
<br>
Sage advice from KenH.<br><br><div class="quote-container"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Ken H</strong> <a href="/forum/post/14136288"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif" style=""></a><br><br>
In general:<br>
Outdoors is better than indoors.<br>
Bigger is better than smaller.<br>
Directional is better than omnidirectional.<br>
Mounting higher is better than mounting lower.</div>
</div>
<br><br><br><b>Performance rankings.....based on EV's observations....Rough Guide....YMMV</b><br><br>
These are rough guestimations, based on my personal observations. They have not been instrument tested yet. Just because something is at the top of the list, does not necessarily mean that it is the best antenna for you and your particular situation. You may be best served by an unamplified model or an omnidirectional model, and directional and amplified units tend to do better on net gain and distance measures. This list is also most certainly distorted by varying atmospheric conditions. I will address that by instrument testing these all on one day, so as to minimize human and atmospheric error.<br><br>
Performance rankings so far.....based on EV's observations....Rough Guide....YMMV<br><br><b>THIS IS A WORK IN PROGRESS and is changed and updated regularly as new and better testing data becomes available</b><br><br><b>Channel Master 4220 with CM 7777 amp on roof<br>
DB2 with CM 7777 amp on roof<br>
RS 1880<br>
RS 1892 UFO<br>
Antennas Direct ClearStream2<br>
Channel Master 4220 unamped indoors<br>
DB2 unamped indoors<br>
Winegard SS-3000<br>
Petra SuperPower 32db (Cornet 645A)<br>
Terk HDTVa<br>
RS Double Bow Tie<br>
Philips MANT940<br>
RS DA-5200<br>
GE Futura Outdoor<br>
Philips MANT950<br>
RCA ANT806<br>
Classic Single Bow Tie<br>
Philips Silver Sensor<br>
Godar Model 1<br>
Terk TV-3<br>
Philips MANT510<br>
RS 1634<br>
My First Attempt at the Coat Hanger Antenna, Youtube Video Specifications unamped<br>
GE Futura Indoor<br>
Terk TV-55<br>
RS 1874 Budget<br>
Picture Frame Antenna<br>
RCA ANT1500<br>
Channel Master 4030<br>
Samsung Axession TV DA1000/GE Contempo<br>
RCA ANT108 (very similar to the RCA ANT110 and others)<br>
RS 1868 Delta<br>
Terk TV-2<br>
RCA ANT1020<br>
Terk TV-5<br>
RS 1870<br>
Jensen TV 931<br>
Terk TV-1 without Loop<br>
RS FM Dipole</b><br><br><br><br>
EV's Favorites....so far<br><br>
RS 1880<br>
RS 1892 UFO<br>
RS DA-5200<br>
RS Single Classic BowTie<br>
RS 1874 Budget<br>
Petra SuperPower 32db(Cornet 645A)<br>
Godar Model 1<br>
Antennas Direc DB2<br>
Channel Master 4149<br>
Terk HDTVa<br>
Terk TV-3<br>
Terk TV-2<br>
Philips MANT510<br>
Philips MANT940<br>
Philips MANT950<br>
RCA ANT806<br>
RCA ANT108 (ANT110)<br><br><br><br>
Here is a chart designed by wwong incorporating the data that I collected in regards to antenna performance using a Zenith 901 Converter Box. Note the first 2 entries were tested on a seperate day, I was testing the Clearstream2 and used the DB2 as a control to help integrate the information into the above lists.<br><br><img alt="" src="http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118085&amp;d=121996112 9" style="border:0px solid;"><br><br><br>
Not sure on topic
Fcarollo is offline
post #3333 of 3347 Old 02-06-2015, 05:54 PM
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
Some introductory thoughts.......THIS IS A WORK IN PROGRESS and is changed and updated regularly as new and better testing data becomes available
Two points here:
1) With Radio Shack going out of business, this should be a good time to purchase some of the recommended Radio Shack antennas at deep discounts. The 15-1874 Budget TV Antenna is among the better "dipole-and-loop" designs for reception, as was verified in EV's test findings, and other decent-performing Radio Shack models are mentioned as well in EV's test listings.
2) Why has this thread been removed as an HDTV Forum "sticky" topic? There continue to be questions about indoor antenna performance posted in this forum. Who else has conducted rigorous, unbiased scientific testing and comparison of these different antennas? While EV apparently isn't hanging out on this forum, his work here is quite valuable, even though the new lightweight, flappy antennas (Leaf - Flatwave - HD-Blade) weren't tested because they weren't on the market until 2012. Please restore this topic as a sticky!
seatacboy is offline
post #3334 of 3347 Old 02-07-2015, 05:07 AM
ProjectSHO89's Avatar
Quoted: 279 Post(s)
Liked: 129
A large number of the listed antennas are discontinued or are otherwise no longer available making their reviews useless to current (and future) antenna shoppers.
Since the OP isn't around anymore, it's probably better to let the thread go idle and stay there.
ProjectSHO89 is offline
post #3335 of 3347 Old 05-11-2015, 11:27 AM
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
EV's "shoot out" among 20 different indoor antenna models actually was from a media market where all of the local TV stations' RF transmissions were on UHF. If some of your local channels are on "real" VHF, the results could differ from what EV documented. I do wish that EV would come back, his testing and evaluation was highly informative.
Newbies note: when this discussion thread was created in 2009, there literally were no lightweight-floppy flat antennas on the market. The Mohu Leaf, Winegard Flatwave, and their ilk literally did not come onto the market until late in 2011.
post #3336 of 3347 Old 05-11-2015, 01:15 PM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
It would be nice to see this thread updated, as there is still a need for indoor antennas. And those aforementioned flat panel antennas are now being used, such as Mohu Leaf and Winegard Flatwave. While they may be overpriced and a bit gimmicky, they do apparently perform well for some users based upon location. And the classic rabbit ears and loop can still be found at remaining Radioshack locations, and the Terk HDTVa is still around. However, if discretion or WAF is not a factor, then I still suggest using a small outdoor antenna indoors, such as a DB2 or a Clearstream antenna. A real antenna is probably still the best performer. And if necessary, you can always add a distribution amp or inline amp.
cajieboy and seatacboy like this.
tylerSC is offline
post #3337 of 3347 Old 05-11-2015, 01:17 PM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
And by the way, EV still posts in the plasma owners display thread, and has now apparently upgraded to an outdoor antenna. But it still would be interesting to see if he could still contribute to this thread, if he so chooses.
tylerSC is offline
post #3338 of 3347 Old 06-09-2015, 07:45 PM
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
I am wondering if anyone here has, or could, perform a "shoot-out" comparison of some of the antenna types which were not on the market back in 2009 when EV undertook most of his testing and evaluations. Here's a summary of indoor antennas which should be included, leaving out some models which are no longer readily available for purchase - and I'd leave out the amplified antennas from a shoot-out for simplicity's sake:
Mohu Leaf
Winegard FlatWave
Solid Signal HD-Blade
Channel Master CM-4001HD Flatenna
Clear TV X-72
RCA ANT-1052 ("Batwing")
RCA ANT-1400
Supersonic SC-607
Supersonic SC-602 (one of the very last "silver sensor" type antennas left on the U.S. market)
post #3339 of 3347 Old 06-10-2015, 08:53 AM
holl_ands's Avatar
Quoted: 528 Post(s)
Liked: 228
holl_ands is offline
post #3340 of 3347 Old 06-13-2015, 10:44 PM
deltaguy's Avatar
Quoted: 17 Post(s)
Originally Posted by seatacboy View Post
I am wondering if anyone here has, or could, perform a &quot;shoot-out&quot; comparison of some of the antenna types which were not on the market back in 2009 when EV undertook most of his testing and evaluations. Here's a summary of indoor antennas which should be included, leaving out some models which are no longer readily available for purchase - and I'd leave out the amplified antennas from a shoot-out for simplicity's sake:
Mohu Leaf
Winegard FlatWave
Clear TV X-72
RCA ANT-1052 (&quot;Batwing&quot
RCA ANT-1400
Supersonic SC-607
Supersonic SC-602 (one of the very last &quot;silver sensor&quot; type antennas left on the U.S. market)
I tried one of these. It's nice that the array can pivot 90 degrees. Having antennas at angles has worked for me at times. It would be nice if it could pivot upward as well. http://www.amazon.com/Adjustable-Ret...56495&sr=1-162
deltaguy is offline
post #3341 of 3347 Old 09-02-2015, 10:22 PM
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
Do joined indoor antennas work?
Some installers of outdoor antennas avoid using a "joiner" to connect two aerials pointing in different directions. The reason is that electronics experts believe this creates an out-of-phase condition in the overall signal strength and quality, in effect rendering real world performance less than with a single antenna.
So does anyone here have experience with having joined two indoor different antennas pointed in different directions? Did this help or hurt your efforts to pull in all of your local channels? I am particularly curious about those joining highly directional log periodic antennas (Zenith or Philips Silver Sensor, Terk HDTVi and HDTVa, and models from Supersonic and One By One).
post #3342 of 3347 Old 09-04-2015, 08:34 AM
holl_ands's Avatar
Quoted: 528 Post(s)
Liked: 228
First of all, let's be clear....using a conventional RF Combiner for two Antennas pointing in different direction ALWAYS degrades Noise Figure (i.e. Sensitivity) by about 4 dB due to Loss in the Combiner. And the amount of external Man-Made Noise will ALWAYS be higher...more of a problem in VHF (esp. Lo-VHF) than UHF Band...unless you have a nearby UHF Noise Source. MULTIPATH interference MAY and frequently is worse with two Antennas....however, this can be minimized depending on how Directive the Antennas are (hence hi-gain is better), how the Antennas are pointed relative to each other (Antennas tend to have NULL Response to the Sides, so best is when stations re at about 90-deg angles) and the relative angles of the SOURCES of the Reflections (Hills, Buildings, etc). So, YMMV....but for SURE, it's probably gonna be WORSE with an RF Combiner versus an RF A/B Switch.
I have helped MANY people with multiple Antenna configurations....MOST of them work well enough to be useful....esp. with strong local signals. BUT, if your reception is on the jagged edge of not working, it's a crap shoot....
post #3343 of 3347 Old 11-09-2015, 11:16 AM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
Walmart has recently added the Terk HDTVa antenna, now LOGTVa in their stores. With a better Smartboost amplifier. In addition to 2 large Terk flat panels. So they seem to be replacing Radioshack as the better source for TV reception products, as they now offer a good selection of antennas including Antennas Direct Clearstream 2V and Mohu Leaf, as well as RCA and GE branded antennas.
And speaking of Radioshack, the remaining stores cobranded with Sprint are becoming a sad state of affairs for TV reception accessories. As the inventory is now dwindling to a few various splitters and indoor rabbit ears that may not be replaced. And the Antennacraft factory has shut down, so no more larger outside antennas unless those remaining on clearance.
tylerSC is offline
post #3344 of 3347 Old 11-09-2015, 11:22 AM
tylerSC's Avatar
Quoted: 786 Post(s)
Liked: 180
Two points here:
For now that Radioshack budget rabbit ears and loop is still in stock, but may not be replaced after the current inventory is depleted. And their FM trap and UVSJ also seem to be disappearing.
tylerSC is offline
post #3345 of 3347 Old 11-09-2015, 11:40 AM
ADTech's Avatar
Quoted: 133 Post(s)
Liked: 72
Stay tuned....
Tech support for Antennas Direct
ADTech is offline
post #3346 of 3347 Old 11-09-2015, 01:53 PM
rabbit73's Avatar
Quoted: 473 Post(s)
Liked: 198
See The Two Antenna Trick (indoor) at hdtvprimer.com. There is also an outdoor version.
https://www.google.com/?gws_rd=ssl#q...hdtvprimer.com
My security software doesn't want me to go there, so I look at the cached version at Google.
http://webcache.googleusercontent.co...&ct=clnk&gl=us
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #3347 of 3347 Old 11-09-2015, 06:31 PM
holl_ands's Avatar
Quoted: 528 Post(s)
Liked: 228
FYI: Norton Anti-Virus has no problem with it....
If you want to TRY using an RF Combiner with Two Indoor Antennas....then JUST DO IT.....worst case is another trip to store to return the Combiner & extra Antenna....most Indoor Locations have plenty of signal strength anyway.....
Reply HDTV Technical
Terk Hdtva Indoor Amplified High Definition Antenna For Off Air Hdtv Reception , Terk Hdtvo Amplified Hdtv Antenna , Antennas Direct C2 Clearstream Television Antenna , Channel Master 3414 4 Outputs Distribution Amplifier , Eagle Aspen Dtv2buhf Directv 2 Bay Uhf Antenna , Terk Fdtv1a Flat Digital Omni Directional Amplified Indoor Antenna Black
