EV's Recommended & Top Rated DTV Indoor UHF/VHF Set Top Antenna Review Round-Up Guide - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1441 of 3347 Old 03-13-2009, 04:03 PM
dattier's Avatar
Quoted: 153 Post(s)
Liked: 62
Many TVs will save one set of QAM channel assignments and another set of ATSC channel assignments, and you will not have to rescan every time you switch between them.
You'll still have to reconnect your cables and go through the TV's menus to change its mode, but you won't have to rescan.
dattier is offline
post #1442 of 3347 Old 03-13-2009, 09:05 PM
nicoge21's Avatar
is the DB2 good for first floor with no line of sight?
nicoge21 is offline
post #1443 of 3347 Old 03-17-2009, 08:58 AM
javs1979's Avatar
Hi all,
I'm thinking about getting an indor antenna to use with my computer TV tuner (an Hauppauge WinTV-HVR-1800). According to tvfool.com (see results), I can get many channels which is a good thing. I live near Quebec City.
Problem is I don't know much about antennas. I may consider this one from The Source because it's already been reviewed in this thread.
Did someone try a Rosewill RMS-DA8300 or a Rosewill RMS-HDA5000 ? First one looks good and it fits well near a window. Last one can be placed indoor or outdoor. Both are sold at Newegg at a good price.
What you guys think ?
Thank you !
javs1979 is offline
post #1444 of 3347 Old 03-18-2009, 07:32 AM
Amiga's Avatar
EscapeVelocity here's another antenna you might want to try in your labs. It's quite flashy!
Artec Digital HDTV Flat Antenna
Amiga is offline
post #1445 of 3347 Old 03-18-2009, 06:33 PM
nicoge21's Avatar
So far all the indoor antennas I've tried have failed. My "temp" RCA ant111 barely get 3 stations at best. Sucks being blocked with no line of sight.
Stupid hills!!!! Surrounded by high hills, trees, and crammed in between several houses
nicoge21 is offline
post #1446 of 3347 Old 03-19-2009, 09:47 PM
oldsyd's Avatar
Ok, I've been testing the RS 1874, and it just isn't picking up
channel 7 very well. I even have it placed in front of the window
that faces the tower. The VHF is so stop and go, it is unwatchable.
I'm thinking an amplified indoor antenna would help, preferably
one with good VHF and UHF reception.
I'm not afraid to spend some money on a good indoor antenna,
but I'm still not able to drill holes and do it proper with an outdoor
antenna. This has to be a temporary install.
I've spent several hours trying to figure out what my best candidate
is, and I've narrowed it down to these 6 (in no specific order):
1. Terk HDTVi and HDTVa
2. Winegard Sharp Shooter SS-3000
3. Radio Shack 15-1862
4. Petra/Cornet
5. Terk TV-3
6. Channel Master CM-4030
The big problem is that I would like to pull in KWKB on UHF, but unfortunately
it's on the other side of the state from all the main broadcasters. Does this mean an omni is the way to go? The best would be a directional VHF with an omni UHF amplified indoor, do they even make those?
Thanks for looking, I'm attaching the TVFool map of my location again for reference.
~jay
Originally Posted by oldsyd View Post
Hi, I've read quite a bit here, but I'm still at a loss as to what might be one of the best choices for my situation.
I'm looking for the best solution for an indoor VHF-HI/UHF antenna. Unfortunately it needs to be an indoor antenna that will sit on top
of the TV.
I'm attaching my tvfool report, where you can see I need VHF channels 7 and 9 plus UHF channels 25-51. Unfortunately, channel 25 is on the complete opposite side of the other UHF stations. It's not a very good station (CW) anyway, so if I don't get it, that's OK.
Any ideas? Is there a full DB chart for all frequencies and all antennas discussed here?
Originally Posted by EscapeVelocity View Post
A bi-directional loop and dipoles (RE&Loop) antenna may be sufficient for you. Amplification may help as well.
So try RS 1874 Budget and the Petra/Cornet or Terk TV-3.
You may want to try lifting the antenna with books or something as even one foot can make a big difference in reception (sweet spots).
oldsyd is offline
post #1447 of 3347 Old 03-20-2009, 06:52 AM
Lord_Zath's Avatar
Quoted: 112 Post(s)
Liked: 109
You could also purchase a standalone pre-amp. The advantage to that is you're more flexible should you want to change antennas later.
How close are you to the antennas? Are they all in one direction?
Holding the fort on old games that play the same as the new ones, minus the $400 price tag.
Lord_Zath is offline
post #1448 of 3347 Old 03-20-2009, 08:12 AM
nicoge21's Avatar
is there absolutely no indoor solution to 1edge and 2edge stations? There's a rash of signals being blocked by the hills around here.
nicoge21 is offline
post #1449 of 3347 Old 03-20-2009, 08:45 AM - Thread Starter
EscapeVelocity's Avatar
Quoted: 573 Post(s)
Liked: 316
A lot of my stations are 1 edge and 2 edge. I live in flatland, but in a swampy depression.
If Channel 7 is your only problem then maybe try an amplified RE&Loop like the Petra/Cornet or the Terk TV-3. The RS 1892 will probably work as well, and without the need to change positions of the UHF elements via the remote.
Epson 8350 / Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 / Panasonic P50ST60 / Vizio P502ui-B1E / Sony 50W700B
Sony S790 / Panasonic BDT-220 / Roku 2 XS & Roku 2
Sony NT5 / Samsung F550 / Speakercraft CS3 / Yamaha YAS-105
EscapeVelocity is offline
post #1450 of 3347 Old 03-20-2009, 08:50 AM - Thread Starter
Quoted: 573 Post(s)
Liked: 316
Nicoge21, your toughest channel is going to be NBC Real Channel 7 post transition. But you should be able to get all the others in the UHF band in the Yellow....which will give you all the primary broadcasters, including ION and CW...plus some independents. You might even get some red UHF by adjusting the atenna.....but you should be able to get Green and Yellow in one position and forget.
Try the Radio Shack UFO 1892.
post #1451 of 3347 Old 03-20-2009, 09:02 AM
nicoge21's Avatar
none of my channels are yellow, all red and blue. TVfools has all mmy stations in 1edge 2edge and tropo, I have an indoor RCA ANT111 and I get WZMY, and WHDH (+THIS sub ch) in fine.
Nothing else.
Maybe I should try one of these hideous things
http://www.radioshack.com/product/in...ductId=2103088
nicoge21 is offline
post #1452 of 3347 Old 03-20-2009, 02:21 PM - Thread Starter
Quoted: 573 Post(s)
Liked: 316
I was going by your posted TVfool just above a few posts.
post #1453 of 3347 Old 03-20-2009, 02:40 PM - Thread Starter
Quoted: 573 Post(s)
Liked: 316
If you go that route, then you might be better served with a Channel Master 2016, which has some VHF dipoles on them.
Here is a test review of several antennas including the CM 2016, by HDTVexpert.
http://www.hdtvexpert.com/pages_c/Five_Antennas.html
Or maybe you would be better served by a Winegard 7084P or 7082P.
post #1454 of 3347 Old 03-20-2009, 03:27 PM
nicoge21's Avatar
i was gonna use it indoors, but probably wouldnt do any better.
In the antenna height option on TV fool i put it at 25 feet and a few channels were LOS. The rest were 1edge.
So I think my elevation really has something to do with it.
nicoge21 is offline
post #1455 of 3347 Old 03-22-2009, 12:24 AM
oldsyd's Avatar
Well, the RS 1892 didn't cut it for channel 7. Turning the amp on
made the signal quality worse. The dipoles just don't pull in channel
7 at all, or it's too flaky. I spent about 2 hours tweaking it changing the
height, position and length of the dipoles (rabbit ears) with poor results.
It also stinks that the saucer blocks a good deal of rotation on the rabbit
ears.
All the UHF stations come in great without the amp on, so I'm thinking
I might return it. The sound of the UHF antenna moving sounds cheap
like it might break over extended use, and the direction indicator doesn't
tell you which way it is pointing, only the number. I'm also thinking there
is signal loss through that TV/AUX switch, and on how the rotator is connected since if you watch analog stations, there is breakup as the
antennna rotates.
As far as VHF, are there more directional arrays for indoor?
It looks like I will have to order one online, since nobody seems to carry the Terk or Petra/Cornet around here.
oldsyd is offline
post #1456 of 3347 Old 03-22-2009, 08:51 AM - Thread Starter
Quoted: 573 Post(s)
Liked: 316
VHF dipoles are not as good as the UHF elements on these better indoor antennas.
If you can get by without 7, then an unamplified UHF antenna like the Channel Master 4149 or DB2 should work well for you. Otherwise you should be looking into a large outdoor(or attic) VHF/UHF combo antenna.
post #1457 of 3347 Old 03-22-2009, 09:18 AM
kedirekin's Avatar
At VHF wavelengths, the only practical indoor antenna is a rabbit ears or other type of dipole. More powerful directional VHF antennas, like an LPDA, are just too large for practical indoor use.
People have reported a 4-bay bow-tie with a large (36"x40") reflector shows modest gain on VHF-HI. I'd consider that a reasonable compromise - large, but not too large, and a fair amount of gain, but limited to VHF-HI.
kedirekin is offline
post #1458 of 3347 Old 03-22-2009, 09:51 AM - Thread Starter
Quoted: 573 Post(s)
Liked: 316
Ive heard of people making large VHF antennas out of not to thick wire, and attached directly to the ceiling.....but that is beyond my level of technical ability. Perhaps you could ask in The Official Antenna Thread!
post #1459 of 3347 Old 03-22-2009, 12:53 PM
oldsyd's Avatar
Hey, thanks everyone for putting up with me here. I'm kinda
crazy when it comes to finding solutions.
I think I'll return the UFO, since the UHF portion of it is overkill for me.
I've ordered the Cornet to see if that is any better as far as VHF is concerned. If not, I might just resort to a homebrew setup with a good UHF indoor and then custom cut a VHF specifically tuned to channel 7.
Things might change here too because channel 7 (KWWL NBC) is getting a new
transmitter in May (hopefully) and they will also be increasing power in June. And, in June we will be seeing the ABC affiliate drop from channel 55 back to VHF 9, so VHF will be important around here.
Just so you know, I do have two large UHF and VHF antennas in my attic right now fed into a combiner and preamp with a coaxial run to the basement and my primary TV, and it works great!
This indoor antenna is for the guest room, and with this old house and all the insulation and 100 years of dust in the walls, I really don't want to take on a project like snaking coax through the walls, especially when we will be moving soon.
Oh, and I did look at the Winegard SS-3000, but I haven't been able
to find any data regarding VHF-HI performance over a dipole. I'm guessing
it isn't much better.
Anyway, thanks for listening and you suggestions, I'll let you know how things work.
~j
oldsyd is offline
post #1460 of 3347 Old 03-22-2009, 01:42 PM
Rick313's Avatar
I was on a similar quest a few months ago and came to realize that rabbit ears are pretty much it for indoor VHF reception. However, if you're a do-it-yourself kind of guy, you might check out the following thread. It didn't help me much since I'm not one for building my own stuff, but it's there if you're interested.
How to build an indoor VHF antenna
When I was comparing various antennas, I found the Terk HDTVa to be superior to most others I've tried. The VHF dipoles are thicker and longer than most other antennas. However, the UHF reception is a little too directional for most people's taste.
Oh, and I did look at the Winegard SS-3000, but I haven't been able to find any data regarding VHF-HI performance over a dipole. I'm guessing it isn't much better.
The following page at HDTV Primer is a great resource for comparing various antennas including the Sharp Shooter.
Comparing some commercially available antennas
The Sharp Shooter was one of the many antennas I've tried, and I wasn't particularly impressed with it. In my opinion, it doesn't perform any better than many other antennas that cost less than half as much.
Rick313 is offline
post #1461 of 3347 Old 03-22-2009, 07:30 PM
Porschefan's Avatar
Hi,
I pretty new to the world of HD TV and have some very basic questions on how accomplish my next goal, which is to get as many Los Angeles-area OTA HD feeds as possible. I am currently a Dish Network subscriber and have two VIP612 receivers/DVR's.
I subscribed to the Dish "local" HD package, but discovered that meant only 4 HD feeds from the Los Angeles "big four" networks: ABC, CBS, NBC and Fox. I didn't even realize what I was missing until I noticed that all the LA Lakers games that are broadcast over KCAL, Channel 9 here are in standard definition, and I KNOW KCAL broacasts them in HD. Also no HD programming from the local PBS outlets. So I'm going to try to add an antenna and get these (and probably a lot more) channels in HD. According to Dish I won't be able to cancel their local channels and still run the antenna into the VIP612 for integration into the program guide and DVR functions, but I guess that's another thing I can't do anything about. I'll actually be happy enough if I can get the Lakers and the PBS stations in HD...that's not too much to ask right?
With the research I've done so far, I think I might be able to pull this off with an indoor antenna, but would be willing to go to an outdoor if that doesn't work out. I think I'm going to be in a good geographical situation since I live at the top of a hill (750 ft elevation) just east of downtown. From the roof of my house I have a clear line-of-sight view of all the broadcast antennae on Mt. Wilson--probably about 15-20 miles (?) as the crow flies.
I'm planning on ordering a Winegard SS-3000 because I kind of like the looks and it seems to get stellar reviews just about everywhere I Google it.
The questions I have before I go forward and order this are:
1. Am I on the right general path as far as what I'm trying to accomplish? Or am I missing something important, either about Dish or this antenna?
2. Are there any real strong recommendations about a better antenna to go with for a first try?
3. The little "user manual" for the SS-3000 is available here:
https://images-na.ssl-images-amazon..../251232910.pdf
The illustration of the components for the SS-3000 indicate that there are 2-ft. and 6-ft. coax cables included in the set. I doubt that I'll be able to get the antenna situated within a 2-ft. cable run of the VIP612 and may need to run an extension cord on the cable/plug for the amplifier unit. Is there any problem with purchasing the proper kind of cable and/or adding an extension cord to what they send you.
I hope I'm not over-complicating what should be a simple task! Any advice/suggestions welcomed.
TIA.
Best regards,
Stephen T. Porter
ABQ, NM
Porschefan is offline
post #1462 of 3347 Old 03-22-2009, 08:21 PM
oldsyd's Avatar
Thanks, Rick.
I did see those gain charts, but notice the Sharp Shooter isn't
on the VHF charts, only on some of the UHF charts, and the one
I was interested in that had the SS on it, he didn't plot a dipole.
Thanks for the link to the VHF DIY antenna, I just might do that
since it's only 1 VHF channel I need.
~j
oldsyd is offline
post #1463 of 3347 Old 03-22-2009, 09:05 PM
deltaguy's Avatar
Quoted: 17 Post(s)
That SS-3000 is an amplified antenna if it is the same as the one pictured on page 1 of this thread. You probably do not need amplification for the Mount Wilson channels and an amp may hurt reception instead of help it. I'd try something without an amp first. If you can place an antenna where it can see the broadcast towers without obstruction, which is true line of sight, you should be in great shape. The budget VHF/UHF combo from Radio Shack might work for you and you could return it if it fails to do so. Check out the TVFool site to see just how many channels you can try for at your location and the Los Angeles OTA thread here for insider advice. Good Luck.
deltaguy is offline
post #1464 of 3347 Old 03-23-2009, 08:48 AM
magna2's Avatar
Nicoge21,
I would recommend that you try an amplified directional indoor antenna such as a Terk HDTVa that would filter out some of the multi-paths that you are probably experiencing. From your tvfools printout, you are getting ample signal for your area but the 2-edge reception just mean that your signal is being received after being diffracted twice.
Again, the tvfool printout shows most of your channels are either in the green or yellow. So the culprit is probably the basic antenna that you are using. So a amplified antenna should help with the reception. As you have mentioned, Lawrence is a somewhat hilly in some areas and if you happen to be surrounded by hills due to being in a valley, I suspect that you are contending with multi-path issues as well.
magna2 is offline
post #1465 of 3347 Old 03-23-2009, 03:12 PM
oldsyd's Avatar
Someone specifically mentions here that the Terk HDTVa was unable to receive the station I am having problems with:
http://www.hdtvantennalabs.com/revie...a-reviews.html
oldsyd is offline
post #1466 of 3347 Old 03-23-2009, 03:44 PM - Thread Starter
Quoted: 573 Post(s)
Liked: 316
In my testing, I really didnt focus on VHF performance.
However the Philips MANT510 had very solid and long VHF dipoles.....and so did the Terk TV-3 and TV-2 .....all 3 of these had 44" long solid stiff dipoles.
post #1467 of 3347 Old 03-29-2009, 02:37 PM
nicoge21's Avatar
Best buy has a SMART antenna now
http://www.bestbuy.com/site/olspage....=1218067406680
If you have a smart antenna jack, try it!
nicoge21 is offline
post #1468 of 3347 Old 03-29-2009, 05:49 PM
holl_ands's Avatar
Quoted: 576 Post(s)
Liked: 253
I'm skeptical whether the Apex SM550 is even a true Smart Antenna.....
It only has one set of rabbit ears and a (too small) UHF loop around the clock,
so where are the multiple antennas?????
From Best Buy's description, I would conclude it's a typical amplified antenna
that can plug into the CEA-909 Smart Antenna I/F...but ONLY to pick up DC power....
although perhaps they're adjusting the amplifier gain????
BIG tip-off is the price is the same as a generic amplified rabbit ears
(so nothing left in the budget for a Smart Antenna electronics module).
PS: Here's SM-550 on the Apex website:
http://www.shop-apex.shoppingcartspl...87/6860063.htm
holl_ands is offline
post #1469 of 3347 Old 03-31-2009, 09:02 PM
jcleworth33's Avatar
Sage advice from KenH.
Originally Posted by Ken H View Post
In general:
Outdoors is better than indoors.
Bigger is better than smaller.
Directional is better than omnidirectional.
Mounting higher is better than mounting lower.
That's what she said.
jcleworth33 is offline
post #1470 of 3347 Old 04-01-2009, 01:13 PM
Krazy_Karl's Avatar
Any idea how the indoor or the outdoor Monoprice antennas work? I live in CT and my cable signal is terrible, was going to give one of these a shot since they are quite affordable and I was going to order some cables from them anyways. When I tried to scan with my Panasonic TH58PZ800U it came back with 0 channels, I was looking at the outdoor style. Thanks for the help!
Krazy_Karl is offline
Reply HDTV Technical
Terk Hdtva Indoor Amplified High Definition Antenna For Off Air Hdtv Reception , Terk Hdtvo Amplified Hdtv Antenna , Antennas Direct C2 Clearstream Television Antenna , Channel Master 3414 4 Outputs Distribution Amplifier , Eagle Aspen Dtv2buhf Directv 2 Bay Uhf Antenna , Terk Fdtv1a Flat Digital Omni Directional Amplified Indoor Antenna Black
