Has anyone tried this VGA-HDMI cable? - AVS Forum | Home Theater Discussions And Reviews
Old 06-25-2008, 09:02 AM - Thread Starter
RSongco's Avatar
Hello
My neighbor just bought a Pillips LCD TV and wanted to use it as an Internet browser as well. I gave him an old Windows server box that only has a VGA port and recommended he get a VGA-HDMI converter box (around $70). He found a cheap VGA-HDMI cable on eBay (item 370063584968) and wanted to know if it would work. My suspicion is that a straight cable with VGA on one end and HDMI on the other won't work, since the signal needs to be processed electronically first, but I wanted to make sure.
"Mixing a teaspoon of manure with a gallon of ice cream produces a gallon of manure."
RSongco is offline
Old 06-25-2008, 10:12 AM
walford's Avatar
Too bad he did not buy an HDTV that also has a VGA input.
Yes, he would need a converter box.
It would probably be cheaper and would provide better results to get a new graphics card for the computer that has both DVI and VGA outputs and then use a DVI-HDMI cable.
walford is offline
Old 06-25-2008, 11:05 AM
mjones73's Avatar
Where did you find a VGA to HDMI converter that cheap?
I'd have to agreed with walford, a video upgrade would probably make more sense.
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
Old 06-25-2008, 11:46 AM
Ratman's Avatar
Quoted: 1277 Post(s)
Liked: 1026
Or better still... get a video card that has an HDMI output.
Ratman is online now
