Hisense USDTV db2010 Digital Tuner - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 80 Old 05-29-2009, 08:11 PM - Thread Starter
dogleg69's Avatar
Originally Posted by Rammitinski View Post
Where did you come up with that? The non-subscription boxes from Wal-Mart originally went for $300.00.
Yep. And I heard through the grapevine that the production cost to USDTV was around $115 per unit from Hisense. So, I don't think $45 is that bad for these boxes. I still use my everyday. They do have an older (less sensitive)tuner and do not handle multipath as well. However, they do have excellent picture quality.
dogleg69 is offline
post #62 of 80 Old 07-01-2009, 05:41 PM
TomMcComb's Avatar
Hi I have a USDTV 2.7.15 unit. I'm a windows person, as I understand it, the only way to get to FTA is via a LINUX formatted and loaded USB Drive.
Right?
Anyone out there that's been down this road that has such a stick that I could borrow??
-Tom
TomMcComb is offline
post #63 of 80 Old 07-01-2009, 06:49 PM
TomMcComb's Avatar
OK, figured out that DD file was for use in windows. Got the USB drive set up. WHen I plug in the Hisense Unit, the Yellow logo comes up on the screen, it accesses the USB drive for a few seconds, the screen goes black, then it continues to boot normally and nothing changes. Duh.
It's a 128MB thumb drive- too big?
Anyone with a working setup? Can I borrow your drive?
-Tom
post #64 of 80 Old 07-01-2009, 07:22 PM
TomMcComb's Avatar
OK- I saw where someone had success using a small SD card and a USB card reader.
Used DD to put the image on a 32MB SD card in a reader. Tried that- SUCCESS!
post #65 of 80 Old 07-03-2009, 10:43 AM - Thread Starter
dogleg69's Avatar
Great. Glad you got it to work. You were too fast for me to respond. Yes, the 128MB stick has trouble. This is due to the linux kernel that is being used on the box. It can't recognize and mount it **depending on the brand**!
I have some cheap 128 sticks that work and some that don't. I read somewhere on the SanDisk site about an incompatibility with linux.
I have also read that if you just pull the USB stick out of a computer without "safely ejecting" it, it can damage the stick (I have no idea if this is actually true, but I did read that on the SanDisk site).
dogleg69 is offline
post #66 of 80 Old 07-28-2009, 11:23 AM
Magnum_lp's Avatar
dogleg69, I remember reading that you had considered modifying this system to be a PVR. Have you done anything like this yet or considered it. I just got this system a few months ago and think it is pretty good but would love a PVR option for it. Is there anything I can currently do to make it a PVR? Thanks for your time.
Magnum
Magnum_lp is offline
post #67 of 80 Old 07-29-2009, 06:28 AM - Thread Starter
dogleg69's Avatar
Magnum
The main issue is streaming HD to a storage device over the USB 1.1 port. Writing data out thru the USB port on this box is not an issue. However, I since it is a USB 1.1 device its limits the bandwidth to 12Mbps. I think that most MPEG2 High Def require around 19.4Mbps.
dogleg69 is offline
post #68 of 80 Old 07-29-2009, 09:45 AM
Magnum_lp's Avatar
Is there anyway to update the USB port. I have not opened up my receiver but I'm guessing it's not like a cpu where you can replace the hardware. Are there any other alternatives to making it a pvr at all? Thanks.
Magnum
post #69 of 80 Old 07-31-2009, 10:06 AM
BluTom's Avatar
I would like to thank dogleg69 for providing the FTA software update. I had the USDTV subscription db2010 digital tuner boxed up in my storage for several years. I found this thread and learned that the software can be updated to FTA. After downloading the fromService293 image and putting it on a 64MB USB memory stick I successfully converted the box to FTA. The tuner is now working perfectly. Thanks for the great work!
BluTom is offline
post #70 of 80 Old 07-31-2009, 06:47 PM - Thread Starter
dogleg69's Avatar
Thanks for the note. I appreciate the acknowledgement.
Did you upgrade just to 2.9.3 or to 2.9.5? I mention it because there are a number of fixes and the addition of timer in the 2.9.4 & 2.9.5 versions.
dogleg69 is offline
post #71 of 80 Old 07-31-2009, 08:19 PM
speedlaw's Avatar
Quoted: 42 Post(s)
Liked: 33
I paid $199 for mine from Wal mart. There were never any USDTV stations here in the NY area, and at some point found out though this forum that they had an update for FTA. I wrote the company (when they were still intact) and was sent a thumb drive. I updated the box and sent back the drive (who knew the software would one day be valuable ?) and the update was great.
In Vienna we sit, in late night cafe. Straight Connection, on T.E.E.
speedlaw is offline
post #72 of 80 Old 08-01-2009, 02:02 AM
Rammitinski's Avatar
Yeah, I do recall that some Wal-Marts did knock the price down some right at the end, but many did not. Mine never did.
Rammitinski is offline
post #73 of 80 Old 08-01-2009, 06:04 AM
jtbell's Avatar
I still have the receipt from Wal-Mart tucked inside the manual for my USDTV box. $198.76 on 8/8/05. I don't remember now whether that was a reduced price.
jtbell is offline
post #74 of 80 Old 08-02-2009, 04:14 AM
Now you guys have got me wondering. Maybe they actually were originally $200.00, and not $300.00.
I could swear they were $300.00, though. I just remember for sure that when they were clearing them out, they dropped them $100.00 some places - but not here.
I was waiting for them to go down in price, because I bought one, and just thought it was way too overpriced at the time (I just wanted to see what I could get with it - it was the first ATSC tuner I ever tried. I remember being more impressed with the picture quality than anything else. I had tried a couple of them, and they both had that "audio dropout/lock-up" problem still).
When people started reporting the clearance price, I kept checking here, but it never changed, and then one day 2 out of the 3 boxes that had been sitting here for over a year just disappeared - and then about a week later the second one did. But the price never did go down here.
My posts from that time are chronicled here - probably in the archives somewhere.
post #75 of 80 Old 08-02-2009, 01:26 PM
BluTom's Avatar
I left it on 2.9.3 for a while, but today I have installed the 2.9.5 version (using the .bin file on the FAT32 partition USB memory stick). It worked without a problem. Thanks for all your work!
BluTom is offline
post #76 of 80 Old 08-29-2009, 02:32 PM
vickhirani's Avatar
does it work with unecrytpred QAM?
vickhirani is offline
post #77 of 80 Old 08-29-2009, 06:31 PM
jtbell's Avatar
No, it receives only ATSC (8VSB) over-the-air signals that you pick up with an antenna.
See the Official AVS HDTV STB Synopsis for HDTV receivers that can receive unencrypted QAM.
jtbell is offline
post #78 of 80 Old 02-01-2015, 04:43 PM
Liked: 0
I hope someone is still checking this thread. This device was given to me and I believe it had been sitting in storage for a while. When I plug it in, the signal light is amber and the power light is green. I get nothing on my TV screen. I've searched for an hour for a solution and have found nothing yet.
Any suggestions?
Virginia
breckrider is offline
post #79 of 80 Old 04-03-2015, 01:24 PM
speedlaw's Avatar
Quoted: 42 Post(s)
Liked: 33
This sounds like antenna-is the antenna "known good" by another TV or device ?
Any suggestions?
Virginia
speedlaw is offline
post #80 of 80 Old 04-03-2015, 02:23 PM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
Any suggestions?
Virginia
You could have the TV connected to the wrong output, or the USDTV output could be set to a format that your TV cannot view. And without seeing the menu screens it can be tricky to set the output correctly. You have 2 basic output types: component (RGB) and composite (Yellow). Component can be 480i, 480p, 720p, or 1080i. Composite (and S-Video) can only be 480i. If the output is set to anything but 480i, you will only have a picture on an HD TV connected with Component cables.
To force the box to 480i: (after turning it on and giving it time to boot)
Press "USDTV Guide" on the factory remote - big red guide button
Press "aspect"
Press "USDTV Guide" again
Press "2"
FYI 2=480i, 3=480p, 4=720p, 5=1080i
If you are using Yellow composite and still have no image after forcing 480i. (try a couple of times since you can't see the menu) the try connecting your yellow cable to the green component output. You should have a monochrome (black and white) picture. The menu will be hard to navigate but you should be able to find the "set video mode" screen in the "setup" menu and select the "composite - s-video" item if it is set to "component - 480i" mode
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is online now
Reply HDTV Technical
