Delay changing channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-12-2008, 01:14 PM - Thread Starter
bklyn1028's Avatar
Quoted: 17 Post(s)
Not sure if this is right spot for this. Scientific Atlanta 8300hd box, sony R70XBR2. Hdmi from cable box to tv, Optical out to receiver. Then...everytime I change channels whether HD or digital channels, there was approx. 8-10 second delay. When I hit the "guide" button on the remote then "exit" the screen went black. Tech came out and said it's the HDMI. they were having trouble with the software. To fix, go back to component. And he was right. But my question is.....I want to get a new receiver (have ps3 to play blu ray -optical out)...and want to hdmi everything (heard much better sound). If I go from cable box to receiver then to tv, will I have the same result (delay)?
bklyn1028 is offline
post #2 of 5 Old 08-12-2008, 02:52 PM
mjones73's Avatar
"If I go from cable box to receiver then to tv, will I have the same result (delay)?"
Don't see why you wouldn't... You may have issues with the cable box not liking the fact the AV receiver is an HDMI repeater also.
".and want to hdmi everything (heard much better sound)."
Only for the PS3 due to the newer codecs used with Blu-Ray, cable is only DD and can be carried via optical/coax or HDMI with the same results.
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
post #3 of 5 Old 08-12-2008, 03:05 PM - Thread Starter
bklyn1028's Avatar
Quoted: 17 Post(s)
then makes no sense spending $$$$ on a new receiver. Hmmmmm.....other thing is (if you don't mind) How can I get an optical out from ps3, dvd, and cable box with 2 optical inputs on yam.....I tried the toslink bi-dir splitter...(2 into 1 and vice versa)...didn't work.....I put the dvd, ps3 into the 2 opticals, and the cable box via dig out...but haven't figured out how to work the dig out. Sucks having that tv, hdmi and I can't use it..cable tech said it's a software problem with the box and hdmi..others are having the same problem
post #4 of 5 Old 08-12-2008, 06:44 PM
mjones73's Avatar
Well it does makes sense to take advantage of the newer sound codecs on Blu-Ray and to get additional inputs. Try the AV Receivers section for advice on receivers and hooking up your sound with the existing one.
Matt
mjones73 is offline
post #5 of 5 Old 08-12-2008, 07:11 PM
Scooper's Avatar
You can get TOSLINK switches, or TOSLINK/digital coax convertors. I'm using a convertor on the TV input, since the lone TOSLINK is on the DVD player input .
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
Reply HDTV Technical
