DirecTV - Channel 602 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-15-2008, 08:13 PM - Thread Starter
BallsDeep's Avatar
I have this DirecTV channel I watch daily called TVG - Channel 602 and this channel uses a 480i broadcasting resolution. If you get a chance, view the channel before replying to this message. I have a high end 46" Sony XBR4 HDTV flat panel. This TV really exposes the flaws of SD channels, especially if set to "Vivid".
The problem:
This channel has a terrible look to it, epecially around the edges of the 4:3 picture. What is this? Why does thie edges and the fonts on the screen look like this? It looks horrible.
BallsDeep is offline
post #2 of 3 Old 08-16-2008, 03:00 AM
BeachComber's Avatar
The problem:
First, because you are using Vivid which is only meant for Showrooms to attract customers to the one with the brightest picture.
Second, because D* broadcasts 480i in 480x480 - the lowest resolution for SD channels of any provider. You screen isn't square and the picture resolution shouldn't be either.
Congratulations - you have SD-Lite.
BeachComber is offline
post #3 of 3 Old 08-16-2008, 09:09 AM
Ken H's Avatar
Not HD. Topic closed.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Closed Thread HDTV Technical
