FiOS CableCARD - AVS Forum | Home Theater Discussions And Reviews
Old 09-09-2008, 07:40 AM - Thread Starter
kavakos's Avatar
I was told that I need to rent a CableCARD from Verizon if I wanted to get rid of their STB...I don't mind doing this, but wasn't clear as to whether or not I still need a TV Tuner for my HTPC build.
Thanks!!!
kavakos is offline
Old 09-09-2008, 07:49 AM
BeachComber's Avatar
Thanks!!!
If you are planning to use the cablecard as a DVR, You either need a complete CableCard Equiped HTPC which are sold as a complete system (not in parts) or a Series 3 Tivo that will take a CableCard.
BeachComber is offline
Old 09-09-2008, 08:10 AM - Thread Starter
kavakos's Avatar
Thank you for the reply.
I'm still confused as to the set-up. I plan on using the HTPC as the DVR; if you wouldn't mind commenting on these parts (this might not be the right thread), I'd appreciate a quick explanation for what the CableCARD will do, and if I'm missing anything I need to make my HTPC a solid replacement for my DVD player and STB. Thanks again.
ASUS M3A78 Pro AM2+/AM2 AMD 780G HDMI ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Produc...82E16813131325
AVerMedia AVerTV Combo PCIe ATSC/NTSC/QAM TV Tuner Card (White Box)w/L-P Bracket 7 95522 96058 0 PCI-Express x1 Interface - OEM
http://www.newegg.com/Product/Produc...82E16815100015
Pioneer Black 5X Blu-ray DVD-ROM 12X DVD-ROM 32X CD-ROM SATA Internal Blu-Ray Reader and 12X DVD±R DVD Burner Model BDC-2202B - Retail
http://www.newegg.com/Product/Produc...82E16827129016
AMD Athlon 64 X2 6000+ Windsor 3.0GHz Socket AM2 125W Dual-Core Processor Model ADX6000CZBOX - Retail
http://www.newegg.com/Product/Produc...82E16819103773
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Produc...82E16822136218
A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Produc...82E16820211066
kavakos is offline
Old 09-09-2008, 09:57 AM
Ken H's Avatar
As already noted, you can't build a CableCARD PC. You have to buy it already assembled. This is primarily due to security issues forced by content owners.
The function of the CableCARD is to unencrypt the digital tier and premium channels from your cableco. The only channels viewable/recordable without a CableCARD (or cableco STB) are the local HD channels in your area; ABC, CBS, FOX, MNTV, NBC, PBS, The CW. The CableCARD will allow you to view/record ESPN HD, TNT HD, Discovery HD, etc.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Old 09-09-2008, 10:17 AM - Thread Starter
kavakos's Avatar
That's not cool...
Do you have any recommendations for CableCARD HTPCs?
kavakos is offline
Old 09-09-2008, 11:11 AM
mjones73's Avatar
Friend of mine has a Dell XPS 420 he's been happy with. He got the dual ATITV Wonder Digital Cable Tuner option to go with it to give him two cablecard enabled tuners. This of course requires renting two cards from Verizon.
The Recorders and/or HTPC sections would probably offer more suggestions for you.
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
