Any need for 75 ohm terminators on unused cable RG6 RF outlets? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 09-25-2008, 11:03 AM - Thread Starter
pnkflyd51's Avatar
Location: Hopkinton, MA (originally from Bloomington, IN)
Hello-
I was wondering if anyone knows if placing 75 ohm terminators on unused cable outlets does anything to boost signal strength on the other connections.
something like this: http://www.amazon.com/Type-75-Ohm-Te.../dp/B000AAN76Y
Thanks much for any info. AL
pnkflyd51 is offline
post #2 of 26 Old 09-25-2008, 11:19 AM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
They don't help signal strength or boost signals. Just helps prevent interference entering from unused/unterminated ports. They are good to use and worth the $5 expense.
Ratman is online now
post #3 of 26 Old 09-25-2008, 11:26 AM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
You can also buy them in 2 packs from Radio Shack. You may want to call ahead though. I had to check with 3 stores before I found them.
Digital Rules is offline
post #4 of 26 Old 09-25-2008, 11:26 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
They also prevent reflections.
CIAO!
Ed N.
egnlsn is online now
post #5 of 26 Old 09-25-2008, 02:15 PM
Ratman's Avatar
Liked: 1022
... or in layman's terms, "ghosting".
post #6 of 26 Old 09-25-2008, 02:53 PM
Super Moderator
DrDon's Avatar
Quoted: 868 Post(s)
Liked: 1726
I dunno. I screwed one onto my forehead and now I don't dwell on the past so much.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #7 of 26 Old 09-25-2008, 06:32 PM - Thread Starter
pnkflyd51's Avatar
Thanks for all the feedback- I do have ghosting on one or two channels on two of my old analog TVs. I'll check out radio shack. Too bad monoprice doesn't seem to carry them- I'm about to place an order from them...
Thanks again! AL
post #8 of 26 Old 09-25-2008, 08:32 PM
mattdp's Avatar
Quoted: 34 Post(s)
Does a small static multipath signal make a crap of a difference with digital TV?
mattdp is offline
post #9 of 26 Old 09-25-2008, 11:25 PM
txrose's Avatar
Wow. What a good question. I am serious. The effect of an open tap is dependent on the loss proceeding the open port. For example, an open 7 dB tap will have less effect then an open 3.5 dB tap. I would think the effect would be very small for analog TVs since the time delay of the reflection is very small. Does anyone know the answer for digital TV?
If it isn't 720p or 1080i/p it isn't HD. If it is 720p or 1080i/p it may not be HD content.
txrose is offline
post #10 of 26 Old 09-26-2008, 05:39 AM
RCbridge's Avatar
Quoted: 16 Post(s)
Just get the terminations and install them they are very inexpensive, and may save you some headaches!!
It is really the isolation from port to port but again just terminate the unused ones.
RCbridge is offline
post #11 of 26 Old 09-26-2008, 08:16 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Another result of reflections (in addition to multiple images (ghosting)) is standing waves. If the standing waves are severe enough, some packets don't make it to their desired destination. The result can be disruption of service.
CIAO!
Ed N.
post #12 of 26 Old 09-26-2008, 08:20 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
That ghosting could be ingress.
There are some high return loss terminators here. Definitely better than the ones at Rat Shack.
CIAO!
Ed N.
post #13 of 26 Old 09-26-2008, 11:04 AM
Ratman's Avatar
Liked: 1022
Yeah... from an unterminated port.
Get thee to the Radio Shack for (hopefully) a quick fix!
post #14 of 26 Old 10-05-2008, 07:43 AM - Thread Starter
pnkflyd51's Avatar
I finally bought some terminators last night and terminated my two unused cable outlets in the house. The two channels on two of my old SD TVs that weren't coming in clearly improved in quality- they're now as good as the others! Amazing!
Two additional questions:
1. Some devices, like VCRs have a Coax Out. I think a couple of my TVs have these too. If these are unused (but have a coax cable going in), should I put terminators on them?
2. Also, I noticed a grounding block like this in Radio Shack when I was looking for a terminator:
http://www.amazon.com/RiteAV-1-way-C...3214046&sr=8-6
Should I put one of these in my coax wiring right before the first splitter in my house to protect against lightning? Will this reduce signal quality at all?
Thanks much!
post #15 of 26 Old 10-05-2008, 07:52 AM
AntAltMike's Avatar
Quoted: 129 Post(s)
Liked: 62
FWIW, ingress ghosts are usually to the left of the images, because they get there first, whereas multipath ghosts are always to the right of it.
I'm going to be bummed out when the analog transmitters get shut off because when I am troubleshooting an underperforming, tapped "riser" coax in a highrise, multiple dwelling building, seeing double images to the left of the main image immediately tells me there is ingress in the line, and seeing them go away immediately tells me that whatever I just did has eliminated the problem, but I won't have that to rely on anymore after the February 17, 2008 shut-off occurs.
AntAltMike is offline
post #16 of 26 Old 10-05-2008, 08:16 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
I thought about saying that awhile ago, but figured I'd probably get shot.
I would think that in your area there would be more than enough OTA traffic in the 140-165MHz range to still allow you to do that (although not double images -- herringbone and other such crap. Heck, I used to have people listen to their police calls on WTBS, which was channel 20).
CIAO!
Ed N.
post #17 of 26 Old 10-05-2008, 08:39 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
I finally bought some terminators last night and terminated my two unused cable outlets in the house. The two channels on two of my old SD channels that weren't coming in clearly improved in quality- they're now as good as the others!
1. Some devices, like VCRs have a Coax Out. I think a lot of TVs have these too. If these are unused (but have a coax cable going in), should I put terminators on them?
Thanks much!
There should be a groundblock outside where the cable comes to the house. If not, there definitely needs to be one, unless the first splitter is outside and it's UL listed. Then, it (the splitter) can be used as a groundblock.
Not a bad idea on terminating the VCR out, I guess. Although, the return loss on a VCR's connectors is probably along the lines of 5dB, which means that you probably wouldn't see much, if any, difference.
Some TVs have a second input. Some TVs used to have 3 connectors on the back. One was the main input. There was an internal 2-way splitter, with one side going to the "A" side of an internal A/B switch and the other side going to the second connector on the back, which was intended for a converter box. The output of the converter box would then connect to the third connector on the back of the TV set. The only TV sets that have in and out connectors are CCTV monitors.
CIAO!
Ed N.
post #18 of 26 Old 10-05-2008, 10:59 AM - Thread Starter
pnkflyd51's Avatar
Thanks for the feedback Ed. I have extra terminators, so I'll put them on the "out" jacks on the various devices around my house.
You were right about the grounding block- there is one on the outside of my house and it has a wire that's attached to my electric meter box.
Thanks for all the help. AL
post #19 of 26 Old 10-06-2008, 06:08 AM - Thread Starter
pnkflyd51's Avatar
In addition to the two unused jacks in my house, I added terminators to the "out" ports on my hd cable box, a VCR, a DVR and the one TV that has them. I didn't see any additional improvement in SD video quality over what I saw when I added the terminators to my two unused jacks, but that's okay...
I'm sure I'm smoking something- I swear that my HD cable box is switching HD channels more quickly- half second to switch instead of a full second. Again, I'm probably imagining it...
post #20 of 26 Old 10-06-2008, 08:27 AM
11001011's Avatar
A 75 ohm terminator is just a 75 ohm resistor inside a cap.
How can this one be " Definitely better than the ones at Rat Shack"?
It must be the gold plating?
I think you are just Radio Shack bashing.
A 'phile and his money are soon parted...
11001011 is offline
post #21 of 26 Old 10-06-2008, 10:50 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
From the manufacturer's website: "Our F Series Terminators (same ones that are at Radio Shack and many other places) are used to provide a 75 Ohm termination on F type connections. Our F-59TH uses precise machining and component matching to achieve high return loss."
F59 specs are: Return Loss; 1GHz: 15dB; 2GHz: 10dB, 3GHz: 8dB Made out of Brass.
F59TH specs are: Return Loss; 1GHz: 40dB, 2GHz: 30dB, 3ghz: 22dB Made out of Zinc.
CIAO!
Ed N.
post #22 of 26 Old 10-06-2008, 08:59 PM
nybbler's Avatar
Time it, pull them off, and time it again. It's actually not an unreasonable symptom.
nybbler is offline
post #23 of 26 Old 10-07-2008, 03:20 AM
vman41's Avatar
For cable TV applications, the loss figures above 1 Ghz aren't useful.
vman41 is offline
post #24 of 26 Old 10-07-2008, 09:15 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
True. The question, though, was "How can this one be " Definitely better than the ones at Rat Shack"?"
CIAO!
Ed N.
post #25 of 26 Old 10-07-2008, 10:45 AM - Thread Starter
pnkflyd51's Avatar
I'd like to, but I dinged the finish on my cabinet when I pulled the cable box out and I don't want to get yelled at by the wife again...
post #26 of 26 Old 10-07-2008, 02:34 PM
spwace's Avatar
Quoted: 29 Post(s)
Liked: 46
If reflections are present, it might take the equalizer a little longer to settle in enough to extract the clock and decode the stream. The minimum time for lock up is determined by the GOP length (group of pictures or the number of frames from one I-frame to the next), and a half a second is fairly typical.
spwace is offline
Reply HDTV Technical
