Motorola DCH3200 lower channel problem? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-14-2008, 06:27 AM - Thread Starter
SteelCityZ's Avatar
I am searching for a solution to a problem I originally thought may be a signal issue. I recently added a Samsung HD LCD to a room downstairs. I also added a Comcast issued Motorola DCH-3200 STB with HDMI hookups. After hooking everything up and auto-programming the TV for channeling, it only received the upper channels (63 and up basically) but only ch. 1, 17, 22, 31 and 55 in the lower numbers. I troubleshot the problem online with a Comcast tech and he stated he had never seen that problem and suggested I exhange the box, which I did. They gave me another 3200 STB and it does same thing. I did some cable searching and really didn't find a problem. I swapped my older Motorola HD box (no HDMI) from my 42" LCD Panny upstairs and after programming it, all channels work on the Samsung downstairs!!! I hooked up the 3200 STB to my Panny and it only gets the channels I listed here. Does anyone know if this config problem is something I can fix or does Comcast restrict you to calling one of their half-trained techs to attempt to fix it. I am really getting sick of shodding equipment and inflating prices from Comcast and am thinking about satellite again. But can anyone shed light to fix the 3200 STB problem?
Much appreciated in advance folks!
SteelCityZ is offline
post #2 of 11 Old 10-14-2008, 07:02 AM
walford's Avatar
Is itt possible that you have a splitter in cable lines that suppress some frequencies? Since the lower channels are actually transmitted on different frequencies witth the DCH then with older 300.
walford is offline
post #3 of 11 Old 10-14-2008, 07:06 AM - Thread Starter
SteelCityZ's Avatar
I just checked the 2 splitters and they are a 3-way and 4-way Antronix 5-1000mhz splitters. Can a splitter go bad?
post #4 of 11 Old 10-14-2008, 07:26 AM
mjones73's Avatar
Can you bypass them just to test?
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
post #5 of 11 Old 10-14-2008, 08:28 AM - Thread Starter
SteelCityZ's Avatar
Matt, I just unhooked the input line to the splitter and used a female-female barrel connector directly to the feed line of the 3200 STB....no change. I auto-programmed the TV again to make sure but it doesn't get the lower channels still.
post #6 of 11 Old 10-14-2008, 08:58 AM
walford's Avatar
If you are using no spliters then there may be a problem with the cable signal itself not handing all QAM frequencies properly. Suggest you contact Comcast again.
walford is offline
post #7 of 11 Old 10-14-2008, 09:10 AM
mjones73's Avatar
Could be an old filter hanging out on the line up on the pole or in the box out front depending on how your service enters your house, they'd need to come out and remove it.
One question though, what are you auto programming? The box should be handling the tuner, shouldn't need to program anything on the TV.
Matt
mjones73 is offline
post #8 of 11 Old 10-14-2008, 09:23 AM - Thread Starter
SteelCityZ's Avatar
I put the TV through it auto programming mode as it finds all available channels. If the tuner handles it then I guess it didnt need to be done.
post #9 of 11 Old 10-14-2008, 09:56 AM
mjones73's Avatar
No, you should just be selecting the HDMI input the STB is attached to on the TV.
Matt
mjones73 is offline
post #10 of 11 Old 10-14-2008, 04:24 PM - Thread Starter
SteelCityZ's Avatar
Thats how I have it setup....on the HDMI only.
post #11 of 11 Old 10-14-2008, 06:27 PM
raouliii's Avatar
Make sure of what?
Why would you be running an auto-programming function on your tv if your problem has to do with your cable stb connected to the TV's HDMI input? If you are using the tuner in the stb then the HDMI input should be selected on the tv and the tv's tuner is not being used.
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
Reply HDTV Technical
