Directv - No sound for HD channels - AVS Forum | Home Theater Discussions And Reviews
Old 11-26-2008, 12:17 AM - Thread Starter
Oktoberfest's Avatar
I'm at the in-laws for Thanksgiving and they have Directv. They have numerous HD channels, but get no sound out of any of them. They flip to the exact same channel in SD and sound comes thru fine. At a loss as I have checked the connections and settings. I may be missing something simple? Any ideas?
Oktoberfest is offline
Old 11-26-2008, 01:18 AM
BeachComber's Avatar
What format is the audio set to?
You don't bother to list the IRD, connection or TV so not a lot to guess at.
BeachComber is offline
Old 11-26-2008, 09:09 AM
Tracy RainH2o's Avatar
Is it a HD DVR? If so, I find that 99% of problems are solved by resetting the unit. Mine has a reset button behind a flip down panel on the front.
Tracy RainH2o is offline
Old 11-26-2008, 11:10 AM - Thread Starter
Thanks for the replies. I realize my post was a bit vague. They have a very low end HTIB that is mainly going to be used in place of sound from TV.
Directv recorder to Samsung 720p DLP (HDMI to DVI)
Directv recorder to HTIB (LG LHT854) Red/Yellow/White
HTIB to TV (Green/Red/Blue)
The is basically it. I'm thinking I need to run an optical connection from Directv recorder to HTIB. Any ideas?
The HTIB has very limited connections. I could run HDMI to HDMI, but hoping to avoid cost of buying one at a store while I'm here. Will the component (Red/Green/Blue) pass HD video. I was not able to get the video running thru the HTIB, so I ran the HDMI/DVI directly to TV. I realize I increase the chances of audio lag, but did't see a better way.
Any suggestions?
Old 11-26-2008, 12:23 PM
HDMI Guy's Avatar
Quoted: 169 Post(s)
Liked: 40
Tune the Directv recorder to an HD channel and check the audio output settings. Sometimes settings are grayed out unless you are on HD. Sounds like HTIB is on the correct input because you get sound from SD channels.
HDMI Guy is offline
