HDTV not reconizing HDMI cable.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-07-2008, 11:11 AM - Thread Starter
lot6000's Avatar
First post everyone,
I have an Olevia 332-B11 32 inch hdtv. The hdmi output is not reconizing
HDMI cords from anything I plug into it. Is there something in the setup I can change or a firmware update I can download to fix this. I called Olevia and they said to unplug it and flip the off switch on the back of the tv for 3 hours and plug it directly into the wall rather than the serge protector I had it plugged in before.
lot6000 is offline
post #2 of 4 Old 12-07-2008, 11:59 AM
mjones73's Avatar
For help with your Flat Panel, this would be the best place to ask - http://www.avsforum.com/avs-vb/forumdisplay.php?f=166
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
post #3 of 4 Old 12-07-2008, 01:35 PM
gbynum's Avatar
Quoted: 25 Post(s)
Originally Posted by lot6000 View Post
I have an Olevia 332-B11 32 inch hdtv. The hdmi output is not recognizing HDMI cords from anything I plug into it.
Is there a more fundamental problem here? I've never seen a TV with an HDMI _OUTPUT_, only inputs.
gbynum is offline
post #4 of 4 Old 12-07-2008, 02:27 PM - Thread Starter
lot6000's Avatar
Thanks. I'll try there.
lot6000 is offline
Reply HDTV Technical
