Question on Coaxial Cable Splitters; HD Cable Box and Cable Modem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-29-2008, 05:47 AM - Thread Starter
deuce1973's Avatar
I hope this is the right forum for this question.
I am trying to have my Comcast HD Cable Box and Cable Modem in the same room from the same wall outlet. I don't really know much about splitters and wanted to get some ideas on what the best splitter for something like this would be? What should I look for in a splitter to make sure it will work for what I want it to do?
Should I be concerned about TV picture degradation if I do this?
Would this item be a good choice?
Thanks in advance for any suggestions and tips!!
Display: Panasonic Plasma TH58PZ800U
AVR: Pioneer Elite SC-67
BD: Panasonic DMP-BDT210
Media: Apple TV4, AppleTV2 (for optical out)
5.1.2: Aperion 6T/5C/5B/4B, Bravus 12D sub
DVR: Comcast X-1 - Game: PS3, Nintendo classic - Remote: Harmony 700
deuce1973 is offline
post #2 of 6 Old 12-29-2008, 07:22 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
Two problems with that splitter -- Gold and $17. The 2.5GHz bandwidth is a waste also (cable TV only uses 5-1000MHz).
You can get premium quality CATV materials here.
CIAO!
Ed N.
egnlsn is offline
post #3 of 6 Old 12-29-2008, 09:53 AM - Thread Starter
deuce1973's Avatar
Ok, I am a noob, but what is wrong with gold? Are you saying that that splitter is just too fancy (it will work but is more expensive), and that a cheaper one will get the same results?
Will HD content be more than 5-1000MHz? I just want to make sure that whatever splitter I get will be able to work with HD content and split to a cable modem.
I welcome any and all comments. Thanks everyone!
post #4 of 6 Old 12-29-2008, 10:21 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
The gold plating can cause Common Mode Distortions, which can cause grief for pictures. Cable systems only go up to a maximum 1000MHz. The majority in the United States go up to only 750 or 860MHz. Anything above 1000MHz is just a waste. $17 for a 2-way splitter is a big waste of money. Why not just use the same stuff that the cable companies use?
CIAO!
Ed N.
egnlsn is offline
post #5 of 6 Old 12-29-2008, 12:42 PM - Thread Starter
deuce1973's Avatar
Ok, then something like this would do the trick, eh?
I really only need to split the cable 2 ways. Does it make a difference if the device splits 2 ways / ways etc? Thanks again for the information on this.
post #6 of 6 Old 12-29-2008, 01:38 PM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
Splitters for CATV need to be solder-backed and not epoxied. They also should have printed circuit boards and not just have the components loose inside.
If you did get that one, you would also have to pay shipping, which would most likely bring the total cost to more than the ones at CENCOM.
CIAO!
Ed N.
egnlsn is offline
Reply HDTV Technical
