Dish Network In 2 Rooms - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-10-2009, 07:22 AM - Thread Starter
sssouthguy's Avatar
This is my first post.and I hope it is posted
in the right place. I have had a C band dish since
1988. I am think of adding Dish network to my home.
I have 2 HDTV's one in my great room the other in my
bedroom. I am single and the 2 TV's are never on at the same time.
If I get a Dish ViP612 would I be able to use the HDMI output for my
Bedroom and the YPbPr component output for the TV in the great room
to receive HD programing on both sets.
I'm not sure if the 2 outputs are active at the same time.
It would not be a problem to switch between the two.
I really do not want to pay to lease 2 HD receivers
when I can only watch one of then at a time.
Thank you for any infomation you can provide
for economical solution....Sonny
sssouthguy is offline
post #2 of 5 Old 01-10-2009, 09:58 AM
gatorman's Avatar
The outputs are supposed to be active at the same time. You may also be able to use an HDMI switcher and an extra cable for the second tv. Of course, the length of the cable run to the second tv may be a problem.
gatorman is offline
post #3 of 5 Old 01-10-2009, 11:23 AM - Thread Starter
sssouthguy's Avatar
The actual distance from one TV to the Other is about 18 foot. Then I have to allow 7ft
up the wall and 7ft down so about 32ft plus some extra to make the connection.
Is 40ft to long of a run. I could probable get that down to 25ft if I have to.Thanks
post #4 of 5 Old 01-11-2009, 07:23 AM
gatorman's Avatar
I don't know the length limitations. I do know there are HDMI boosters/repeaters/extenders for longer cable runs. That might be your best option especially if you want to use a one wire solution that keeps the signal digital. Otherwise, you'll need a long component cable as well as audio cables. A little google research will probably give you some idea of max lengths.
gatorman is offline
post #5 of 5 Old 01-11-2009, 10:05 AM
BVfan's Avatar
I'm using this to a projector and it works.
The cables can also be purchased with 2 audio cables included for a total of five wires. If you have HDMI on both TV/s, it will cost more, but a HDMI switch box and a 35 foot HDMI cable would be a cleaner run.
BVfan is offline
Reply HDTV Technical
