OTA Antenna Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-30-2009, 11:01 AM - Thread Starter
tranzparentl's Avatar
I have been trying to get OTA reception and so far have tried 2 different antennas. I am in Troy, NY 12180 just outside of Albany and all the towers are about 17-18 miles from me.
RCA ANT1500
- get most of the channels I want except FOX doesn't register at all and NBC signal comes in and out. CBS, ABC, and WB are perfect.
I went to Radioshack to try an amplifier but the guy talked me into a Radioshack Amplified Indoor Antenna - actually gets worse reception than the ANT1500.
My next step was gonna be one of these Clearstream4 antennas
Here are my results from Antenna Web and TVfool.
From what I understand all of the main stations are either on the same tower or right next to each other and I don't think there is any mountains or whatnot near me.
Any suggestions for getting WXXA (FOX) to register?
HD BLOG: TeknologikL
tranzparentl is offline
post #2 of 11 Old 01-30-2009, 11:10 AM
IDRick's Avatar
Liked: 24
Your two problem stations are high vhf (ch 7, WXXA, Fox and ch 12, WNYT, NBC). You need an antenna that can acquire high vhf channels. A winegard 7694 antenna would work very well for you on the roof. I don't know how well the clearstream antennas work for high vhf channels. But, I would investigate thoroughly before buying one....
IDRick is offline
post #3 of 11 Old 01-30-2009, 11:21 AM - Thread Starter
Thanks, i'll look into that one.
Do you think I could get away with putting it in my attic or does it need to be on the roof?
I could probably put it on the roof if necessary.
post #4 of 11 Old 01-30-2009, 11:40 AM
IDRick's Avatar
Liked: 24
The 7694 may work in your attic as you are close to the towers with LOS and high signal strengths. You will likely need to test multiple locations before you find the hotspot. Locate the antenna away from any metal ductwork or wiring that may be in your attic. Signal strengths may be better if you can aim through the gable end of your home rather than through the roof.
Good luck!
IDRick is offline
post #5 of 11 Old 01-30-2009, 11:56 AM
winegard's Avatar
I would suggest looking into a MS-2000 omni-directional antenna. From our data we see the FOX station being behind you the other direction.
Andy Crowner
WINEGARD COMPANY
Andy Crowner
Winegard Company
For more information including Product Manuals, Engineering Specifications and questions answered by Winegard technicians please visit www.winegard.com.
winegard is offline
post #6 of 11 Old 01-30-2009, 12:01 PM
IDRick's Avatar
Liked: 24
Andy Crowner
WINEGARD COMPANY
So, both antennaweb and tvfool got it wrong? Got a link to verify that?
IDRick is offline
post #7 of 11 Old 01-30-2009, 12:32 PM
winegard's Avatar
Let me explain that a little differently, I misunderstood one of our techs. The FOX and NBC stations are actually broadcasting from the exact same location as the other channels you are receiving. WYPX (Ion) is also broadcasting to the Northwest and you will probably need a omni-directional to pick that up as it is right on the edge.
It seems like you are currently having some UHF issues with FOX and NBC.
Andy Crowner
WINEGARD COMPANY
Andy Crowner
Winegard Company
winegard is offline
post #8 of 11 Old 01-30-2009, 12:56 PM - Thread Starter
Well I don't care as much about WYPX, I'd be happy with FOX and NBC.
So do you think that Winegard 7694 would be a good one?
post #9 of 11 Old 01-30-2009, 01:00 PM
IDRick's Avatar
Liked: 24
Andy,
WXXT and WNYT are high *VHF* not UHF. Look at the supplied antenna web and tvfool info by transparentl.
Rick
IDRick is offline
post #10 of 11 Old 01-30-2009, 02:12 PM
winegard's Avatar
You will also most likely experience a change during the transition as stations ramp up to full power and your NBC station moves over to the other broadcast location.
If your not worried about the Ion channel then the Winegard HD7694P in the attic should be a great option. With a small amount of luck you'll get the Ion channel as well.
(Your right about the High VHF vs. UHF that I stated earlier. It's been a long day.)
Andy Crowner
WINEGARD COMPANY
Andy Crowner
Winegard Company
winegard is offline
post #11 of 11 Old 01-30-2009, 04:16 PM
arxaw's Avatar
HD7694P should work well.
arxaw is offline
Reply HDTV Technical
