svideo upconversion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-17-2009, 08:20 PM - Thread Starter
bmack299's Avatar
Is there any way to upconvert an svideo cable connected to a direct tv receiver to a higher definition, such as, 1080i/p WITHOUT using a receiver. Is there any type of cable that can be connected to the svideo
bmack299 is offline
post #2 of 2 Old 02-17-2009, 08:44 PM
mjones73's Avatar
No, s-video itself can't output more then 480i, you'd need a scaler of some kind to make it any higher, I wouldn't expect major improvements in PQ either if you did scale it up.
If you have a fairly recent TV, it should be upconverting it's s-video input to whatever it's native resolution is anyway.
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
Reply HDTV Technical
