HD cable box and remote lost distance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-20-2009, 06:01 PM - Thread Starter
jrdrennan's Avatar
I have a motorola hd dvr,panasonic 58 inch plasma ,yamaha reciever(older model),dual tuner tivo, and a panasonic bd30 br player, all once it my remote does not have the distance,that it had, you have to get about 4 feet from the box for it to work,it used to work great, I even changed the box and remote, what could it be?, Insight told me I will probably have to just live with it. Any help please?
jrdrennan is offline
post #2 of 6 Old 02-20-2009, 06:15 PM
walford's Avatar
Poor remote distance can be caused by weak batteries or possibly by a dirty IR receiver?
Does your remote have to be 4 ft from each of the boxes that it can control?
walford is offline
post #3 of 6 Old 02-21-2009, 06:39 AM - Thread Starter
jrdrennan's Avatar
no, it is just the cable box, plus there are new batteries in the remote
post #4 of 6 Old 02-21-2009, 07:53 AM
aemeeich's Avatar
There is a possibilty the plasma is emitting spurious IR, and that is causing interference with your remotes. Here is a post that describes the issue.
http://www.avsforum.com/avs-vb/showthread.php?t=1062076
I remember reading in a different post that putting some masking tape (sometimes multiple layers) over the IR receiver on the STB filters out the spurious IR and allows the remote to function properly.
Michael
aemeeich is offline
post #5 of 6 Old 02-21-2009, 10:27 AM
HDMI Guy's Avatar
Quoted: 169 Post(s)
Liked: 40
My mother had a motorola cable box and had the same problem. We solved it by either putting a piece of paper over the "eye" on the cable box or turning down the backlight on her LCD.
HDMI Guy is offline
post #6 of 6 Old 02-21-2009, 04:51 PM - Thread Starter
jrdrennan's Avatar
I did the peace of paper and it worked! thanks
Reply HDTV Technical
