What HDTV tuner card should I buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-26-2009, 06:56 AM - Thread Starter
edarz's Avatar
I am starting this new thread because I found nothing written on this recently.
My computer runs Vista Ultimate [64 bit] with Media Center. I hope to find a HDTV Tuner card
that will enable me to use my computer as a DVR.
Which HDTV tuner cards are best for my 64 bit computer?
Is there anything out there with a cableCARD slot?
Thanks in advance for your suggetions.
edarz is offline
post #2 of 2 Old 02-26-2009, 08:03 AM
mjones73's Avatar
1) Try the Home Theater PC Section of the forum.
2) To use cablecards you need a PC that's been certified by CableLabs, basically you need to buy a prebuilt cablecard enabled PC.
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
Reply HDTV Technical
