Centronics ZAT 502 HD / RTC DTA1100HD / Digiwave DTV5000HD - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #271 of 484 Old 01-08-2010, 12:45 PM
ngarrang's Avatar
I missed that. Thank you.
ngarrang is offline
post #272 of 484 Old 01-10-2010, 09:14 AM
Lsang04's Avatar
So let me see if I got this straight... The software engineer was able to extract the TV ratings and Program Title from the PSIP data, but just wasn't able to force himself to extract important things like the Program Description ?? Did he go on vacation, or was he involved in some sort of accident ? Congrats to the product manager on getting this thing out the door regardless... you're doing a heck of a job.
Lsang04 is offline
post #273 of 484 Old 01-12-2010, 12:33 PM
bleatingherd's Avatar
Can someone please confirm for me that the ZAT shows the same signal strength percentage regardless of the channel being viewed? I have another DTV converter that jumps between 59 at the low end up to 90 at the high end whereas the ZAT is always showing 55 or 56%.
bleatingherd is offline
post #274 of 484 Old 01-12-2010, 02:15 PM
DAP
DAP's Avatar
No.
I just went through my channels and got the following signal strengths:
85
88
82
86
63 -> 86
84
81
90
51 ->73
90
69
87
51 -> 70
88
82
84
0 -> 40
76
88
78
90
84
36 -> 53
Where you see the -> I switched to a secondary antenna that receives those channels better.
DAP is offline
post #275 of 484 Old 01-12-2010, 02:18 PM
Originally Posted by DAP View Post
No.
85
88
82
86
63 -> 86
84
81
90
51 ->73
90
69
87
51 -> 70
88
82
84
0 -> 40
76
88
78
90
84
36 -> 53
Thanks DAP. That confirms that my unit must be defective. I appreciate your taking the time.
post #276 of 484 Old 01-13-2010, 06:16 AM
aero12's Avatar
I have one centronics, and one digiwave, and for almost all channels I am at 55% to 56% because those are all coming from one local tower. I dhave channels from other directions getting 30%, 40% etc, but strangely not one above 58%.
aero12 is offline
post #277 of 484 Old 01-13-2010, 02:28 PM
DAP
DAP's Avatar
Those are antenna signals, if you are getting your signal from cable, those should all be the same power.
DAP is offline
post #278 of 484 Old 01-16-2010, 06:25 PM
davidon1138's Avatar
One channel works fine no problem. When I switch to a CBS channel I get sound cut outs every now and then for a sec or two and also blackouts for a sec or two..don't think its the HDMI cable since it works for the other channel. Any clues?
davidon1138 is offline
post #279 of 484 Old 01-21-2010, 11:34 AM
pmorris1's Avatar
Hi. I have two of the zat-502HD The one I just got is defective after only using it a week.When you power it on, it won't power up. If you keep hitting the power switch, it sometimes will come on.And also the signal from the antenna source won't pass thru the unit to the TV. I called Centronics, and they said to send it back, but they once again don't have any at this time.Maybe they will have them some time the end of febuary.
The other unit I have had for a year. When I am watching the TV the Brightness will go up for a short time, and then it will go darker. Would anyone have any idea what might be causing this?
pmorris1 is offline
post #280 of 484 Old 01-31-2010, 06:09 AM - Thread Starter
douglas-b's Avatar
Hey there...I think I have a problem with my ZAT. I have a multiple antenna array now (2 antennas pointing in opposite directions, I burnt up my rotor) The problem is this, only two channels exhibit this behavior and it only does it on the TV with the ZAT. My question is, why only 2 channels? Both of them are above 80% signal strength...they just get wired lines of pixialation all through the picture. It does not do it on my plasma that has a internal tuner. Any guesses? Only two frequency's messed up??? The receiver also seems to be very sensitive to outside interference. My neighbor has a large table saw in his garage and I know exactly when he turns it on...it screws up my picture. I know it sounds dumb but another neighbor started his van and it messed it up to. When he drove off...problem stopped.
douglas-b is offline
post #281 of 484 Old 01-31-2010, 09:45 AM
rabbit73's Avatar
Quoted: 399 Post(s)
Liked: 159
Are the 2 channels VHF?
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #282 of 484 Old 01-31-2010, 10:23 AM - Thread Starter
douglas-b's Avatar
I have seemed to have fixed the problem for now. I removed one of the antennas from the equation and the problem went away. The problem seems to have been from interference with the two antennas not the ZAT.
post #283 of 484 Old 01-31-2010, 03:10 PM
rabbit73's Avatar
Quoted: 399 Post(s)
Liked: 159
Thanks for the feedback; glad to hear that the problem is solved.
What I had in mind was that noise interference is worse on VHF. I suspect that digital tuners are not able to reject noise interference as well as the old analog turret tuners that switched coils for each channel.
Lord Kelvin, 1883
rabbit73 is offline
post #284 of 484 Old 01-31-2010, 03:25 PM - Thread Starter
douglas-b's Avatar
All my channels are UHF so I'm going to get the exact same antenna (UHF only) and point it the direction needed and hopefully all will go well. I'm going to fire a email to Winegard before I order it though...don't want to waste any more money.
post #285 of 484 Old 01-31-2010, 06:46 PM
ngarrang's Avatar
I have finally tired of the poor ATSC tuner in my Vizio LCD TV. The TV is an older 32" model. I have been making do with it, thinking I screwed up the antenna, but I have been noticing some other things that make me thing the Vizio simply has a really bad ATSC tuner.
So, I am taking the plunge and ordered the DTV-5000HD. Given all of the info here and elsewhere, it can only do a better job than the buil-in tuner of the Vizio.
I am not going to steal the Analog converter I use in my kid's room, since I am looking for real HD.
UPDATE: Order place on Sunday. Processed on Monday. Shipped on Tuesday. w00t!
UPDATE: And according to my USPS shipping notice, is now sitting at my front door waiting for me to get home. New toy! New toy!
ngarrang is offline
post #286 of 484 Old 02-05-2010, 04:43 PM
ngarrang's Avatar
The Digiwave DTV5000HD is now installed! Huzzah!
Wait...where are my other plethora of channels?!
Oh, right, winter snow storm.
Well, despite mother nature trying to interfere with my TV reception, I have 34 channels detected. I am missing the Channel 25's, and 54's, which I always have trouble receiving -- even in good weather.
Home: Oxford, Ohio
Channel 54: south of Cincinnati across the river
ngarrang is offline
post #287 of 484 Old 02-06-2010, 12:01 AM
silverantonius's Avatar
I bought mine from "electorica" on eBay. This is a Canadian seller.
The unit came poorly packed, but in flawless condition, brand new.
It has a suprisingly nice chasis.
I was expecting a dinozaur, you know, made in China piece of shi*.
I hooked it up I pluged a 12" long 16 gauge wire into the antena input.
I didn't have patience to install a new antena I bought earlier.
After I started the quick setup - this box found ... 56 channels!!!!
Just on a piece of twisted and bend wire!
I just can't believe it. I live in 90503, but still.... wow.
Good luck to everyone, and thank you for your opinions that helped me make my decission.
EDIT: Box has no brand shown. Instruction manual has DTA1100HD shown on the last page.
During the day it won't display all the channels it found yesterday in the evening.
The unit requires more than just a short wire.
Another important note is that manufacturer warranty period is 90 days as shown on page 17 of the manual.
So if you get 1 year - you better stick with a good and estabilished store.
silverantonius is offline
post #288 of 484 Old 02-06-2010, 06:58 PM
ngarrang's Avatar
I plugged in the optical audio cable into the surround sound receiver, set the audio to AC3 and now we are cookin' with evil gas.
And now that the storm has passed, I have the Channel 25 subchannels. Yay! 39 digital channels.
ngarrang is offline
post #289 of 484 Old 02-07-2010, 10:46 AM
I conected mine to a WINEGARD HD4400 antenna and it found 73 digital Channels altogether, which means there is probably a 100 out there including analog broadcasts from Mexico. Most of the channels are foreign though. Signal strength is mostly 64-72% so even that antenna needs amplification. The antenna was $30 in a local store, but it normally costs $22 online.
I connected it with a 12ft long cable. I did not instal the back shielding bars to save space, bacause I put it inside my room behind a desk. The image quality is just mind blowing.
post #290 of 484 Old 02-08-2010, 06:52 AM
ProjectSHO89's Avatar
Quoted: 206 Post(s)
Liked: 109
ngarrang,
Point me to where you got yours. I've been looking around but it seems everyone is out of stock.
I just endured a Super Bowl on a 65" projector that was up-converted SD via Dish. Looked like crap, only bigger.
I told the kids I'd set them up with an antenna and an HD converter for their local stuff so now I need to find a box for them.
ProjectSHO89 is online now
post #291 of 484 Old 02-08-2010, 06:57 AM
ngarrang's Avatar
Summit Source. But in checking this morning, they look to now be back-ordered. I ordered mine at just the right time, apparently.
If you want something in the closer-time, you might have to bite the bullet and buy a more expensive unit.
ngarrang is offline
post #292 of 484 Old 02-20-2010, 10:09 PM
Quote:Every channel seems to have its own aspect ratio of anywhere from 4:3 to 9:16 [/q]
I keep on reading people have problems with aspect ratio.
I disagree. Maybe I misunderstood the concern, but I think it's just the Display Format setting issue.
It took me some time to figure out 480i 4:3 TV screen should be set to "Center" - not "Full". It just works great.
I feel this is just a perfect buy.
This box made me happier than I originally thought it would.
S-Video works great, but the difference between itself and the cinch connectors is very very minor.
Of course it has issues. No analog tuner makes it hard in some locations with analog cable or TV.
I also think it is silly not to have a function of disabling the unwanted channels.
I have over 70 channels in LA and most of them are foreign Korean, Japaneese and Chinese - so it makes perfect sense to skip them during chanell + - function.
Does anyone here went through this manual setup to rid all these?
Is it hard? Is there any other way of getting rid of unwanted channels?
post #293 of 484 Old 02-21-2010, 06:11 PM
DAP
DAP's Avatar
The aspect ratio problems are real, but if you are using it for OTA reception it is not as much of a problem. It is much worse with cable especially on the less often viewed channels that Comcast uses extreme compression on. Some of those channels will appear as a tall skinny box for which no amount of monitor tweaking can make the aspect ratio correct.
There is no problem with HD signals, nor with the higher data rate SD signals.
DAP is offline
post #294 of 484 Old 02-26-2010, 09:22 PM
Yakuman's Avatar
Is a manual for this device available online?
And who sells this thing?
Yakuman is offline
post #295 of 484 Old 02-28-2010, 06:32 PM
battey's Avatar
My Centronics ZAT 502 HD at time puts a large block box on the screen (covers maybe 80% of the screen) with the text "8A" (or variations) in it, in a normal sized font at the top of the black box. The variations that I see are like 8A* or "8A*8A*8A.
If I change channels and then change back to the original channel, the text & black box is gone, but often reappears a few minutes later.
Has anyone else seen this? Can anyone tell me how to stop this?
battey is offline
post #296 of 484 Old 02-28-2010, 11:25 PM
Rammitinski's Avatar
A few places. Google is your friend.
Rammitinski is offline
post #297 of 484 Old 03-01-2010, 02:45 PM
DAP
DAP's Avatar
Check and see if you have any of the closed captioning stuff enabled for that channel.
DAP is offline
post #298 of 484 Old 03-02-2010, 01:19 AM
TriFocals's Avatar
I received my ZAT 502 HD today after 2 months back order.
What a great picture but noises (cracks and pops) in the audio through the HDMI when less then 100% volume via the ZAT's vol control are distracting. Anyone else hear (of) this?
The optical audio out was fine but I did not always want to run the audio amp of my receiver. I thought I would reprogram the ZAT's remote to operate my TV's (Samsung HLP6163WX) volume control as well as it's power switch. What went wrong is the Zat's internal volume was turned down to zero before the remote was reprogrammed for the TV's volume control. Now I have no vol out. I can't figure a way to reset the internal ZAT's volume to 100% as the remote is now set up for the TV.
I have removed batteries from remote but it won't reset. I have also unplugged the ZAT 502 to reboot it but no luck. Ideas?
RMA it for noise in HDMI output? Cable bills for more months.
I have once again painted myself into a corner. Time to sit and watch the paint dry.
TriFocals
WOM memory. I've got it how about you?
TriFocals is offline
post #299 of 484 Old 03-02-2010, 01:34 AM
Yakuman's Avatar
I looked in Google before and the only hits are small retailers.
Yakuman is offline
post #300 of 484 Old 03-02-2010, 01:13 PM
DAP
DAP's Avatar
The definition of a niche market...
DAP is offline
Reply HDTV Technical
