Centronics ZAT 502 HD / RTC DTA1100HD / Digiwave DTV5000HD - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 484 Old 04-07-2009, 04:58 AM - Thread Starter
douglas-b's Avatar
They are shipping now and I should have it in my hands on Wednesday...I'll post a mini review after that.
Moderators Note: Please note all 3 units, Centronics ZAT 502 HD / RTC DTA1100HD / Digiwave DTV5000HD, are identical.
douglas-b is offline
post #2 of 484 Old 04-08-2009, 03:26 AM
Rammitinski's Avatar
Please do. Thanks.
Rammitinski is offline
post #3 of 484 Old 04-09-2009, 04:46 AM - Thread Starter
douglas-b's Avatar
Simple Guide
Signal Bars
Screen Aspect Ratio Setup
Parental Controls
Simple Guide
Remote
HD (with sidebars)
SD (with sidebars)
SD (full stretch mode)
SD (center stretch mode)
Channel Scan Modes
post #4 of 484 Old 04-09-2009, 09:43 AM
Ken H's Avatar
Can you tell us about the guide? Fast? How far does it go out into the future?
Where did you get it from?
Cost?
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #5 of 484 Old 04-09-2009, 11:47 AM
post #6 of 484 Old 04-09-2009, 11:50 AM - Thread Starter
douglas-b's Avatar
Cost?
It really doesn't have a guide when viewing HD material. You can bring it up and it will have an area where it should be but...just gives ratings.
I'm using component for my 1080i maybe that has something to do with it. I will check it out in further detail for you.
http://www.centronics.com/
post #7 of 484 Old 04-09-2009, 11:51 AM
Originally Posted by douglas-b View Post
It has screen adjustment for those wanting to use it as a converter box on a 4:3 screen.
Does it have an uneven, non-linear, "just"-type stretch option for 4:3 material (what people sometimes call "the fun house mirror effect"), or just an even, linear one?
post #8 of 484 Old 04-09-2009, 11:53 AM - Thread Starter
douglas-b's Avatar
Yea, it looks better if you don't stretch it. I can snap a few pics if you'd like.
post #9 of 484 Old 04-09-2009, 11:54 AM
That'd be excellent. It looks like the PQ is pretty good in general from your other pics so far.
post #10 of 484 Old 04-09-2009, 11:56 AM - Thread Starter
douglas-b's Avatar
HD quality looks great. I have had the set ISF calibrated though.
post #11 of 484 Old 04-09-2009, 11:57 AM
How's the general build quality? Can you add singular channels without having to do an "add-on" scan?
post #12 of 484 Old 04-09-2009, 12:08 PM - Thread Starter
douglas-b's Avatar
Build quality seems good...metal case...it is little though.
Yes, you can add single channels if you know the frequency they are broadcast on...or the analog channel (antennaweb) is how I did it.
post #13 of 484 Old 04-09-2009, 12:15 PM - Thread Starter
douglas-b's Avatar
[quote=ken h;16231790]can you tell us about the guide? Fast? How far does it go out into the future?
post #14 of 484 Old 04-09-2009, 12:29 PM - Thread Starter
douglas-b's Avatar
Depending how you do it in the inital setup...if you choose 16:9 you can not stretch HD material but you can zoom SD. If you choose 4:3 you can zoom HD and SD material is already zoomed. I have no idea why but you just have to figure out what you want to zoom or not zoom.
post #15 of 484 Old 04-09-2009, 12:50 PM
andgarden's Avatar
How's the remote?
andgarden is offline
post #16 of 484 Old 04-09-2009, 01:15 PM - Thread Starter
douglas-b's Avatar
The remote is alright but I use a Harmony H659 and I was impressed they already had the codes so I could use it instead.
post #17 of 484 Old 04-10-2009, 03:27 PM
rabbit73's Avatar
Quoted: 473 Post(s)
Liked: 198
Set up was straight forward and I had no difficulties in doing it. I set my rotor toward Fort Wayne and did a "Auto Scan". After that I used the "Manual Scan" so it wouldn't delete the previous channels it had just added. This receiver is sensitive and does a very good job of locking on to channels.
It has a "Signal Quality" and "Signal Strength" bars for tuning a station in better.
I've only had it for 12 hours and I'm very glad I bought it. For the price I paid for it...it's a steal for what it does. Having a older Mitts. without a tuner, I had to have something to get my HD again after canceling my Dish Network subscription. Now I've got it. If you have any specific questions, just ask and I'll do my best to answer. If you need a HD tuner...buy it, you'll be happy.
Thanks for posting the screen shot of the dual signal bars, which interest me because they are so helpful when finding the best location and aim for an antenna. It looks a lot like the Apex DT502 screen. Is that a coincidence or is there a connection between Apex and Centronics?
The ability to add a channel after scan puts it one-up on the Apex even disregarding the HD.
Is there a link for a PDF manual yet?
Update 3-9-2012:
Since the link to the photo of the dual signal bars that douglas-b took is broken, I am putting it in an attachment below. It is much better than the one I took (which is why I saved it), and I hope that he will not mind.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #18 of 484 Old 04-12-2009, 11:04 AM - Thread Starter
douglas-b's Avatar
I never found a PDF one either.
post #19 of 484 Old 04-13-2009, 08:03 AM
Lazza's Avatar
Does it have event timer functionality so that it can working with recording devices (eg, DVDR)? Short of that, any idea on its compatibility with IR blasters?
_Lazza
Lazza is offline
post #20 of 484 Old 04-15-2009, 09:48 AM
mousse's Avatar
Hmm, now I'm wondering if I should get the 502 or get a Samsung.
Which would be better if I did not want any black bars to appear when watching SD content? I've got a plasma and not a fan of those black bars.
mousse is offline
post #21 of 484 Old 04-15-2009, 11:38 AM
gerhard911's Avatar
After encountering a problem with my ZAT501HD I was offered an "upgrade" to the 502 by Centronics. I have to say that it is somewhat of a mixed bag as to which of those two is better.
ZAT502 v. ZAT501
+ better tuner (Samsung module vs. Thomson in the 501) gave me a few more channels
+ HDMI passes audio (the problem with my 501)
+ Dolby (but apparently only on the optical SPDIF out - mine only passes PCM over HDMI)
+ simplified setup and menus (the 501 was overly complex and sometimes undecipherable)
+ S video output
- cannot delete channels !
- no favorite channels function
- less detailed on screen guide
- no timer function (although I never used it on the 501)
- no VGA display port
- no serial port for software updates
As to it's screen filling zoom abilities, if a station is transmitting HD resolution none of the zoom modes will remove the left & right bars on 4:3 program content with the Screen Ratio set to 16:9.
So, unless your display has a zoom mode that will do it you will need to configure your ZAT502 Screen Ratio to 4:3. Then "Center" mode will stretch and remove the bars on 4:3 ratio SD program content and "Full" will provide proper screen fill for 16:9 HD content.
gerhard911 is offline
post #22 of 484 Old 04-15-2009, 02:02 PM - Thread Starter
douglas-b's Avatar
Good luck with that...they don't make it anymore. (Samsung) The places that said they had it wouldn't return my emails and they wanted like $250 for it.
post #23 of 484 Old 05-09-2009, 09:10 PM
dtam5874's Avatar
http://www.centralsatellite.com/productview-428.html
$85.50 and out of stock
http://www.summitsource.com/product_...te_banner_id=1
$89.95 and out of stock
Aren't they supposed to be available by now, and for $70.
dtam5874 is offline
post #24 of 484 Old 05-09-2009, 09:24 PM
zenoicus's Avatar
Centronics says their next shipment from China is supposed to arrive this Monday (in fact, their web site is already trumpeting its availability). It's also cheaper ordering directly from them then from Central or Summit:
ZAT502 HD at Centronics
But good luck finding a 502 for $70, shipped prices now are nearing $100 and up....
zenoicus is offline
post #25 of 484 Old 05-09-2009, 09:32 PM
zenoicus's Avatar
There are plenty of DTB-H260F receivers on eBay, occasionally even some new ones (there's one there now). But bidding is also pretty active. Currently there's also a new one listed at VideogoN.
zenoicus is offline
post #26 of 484 Old 05-09-2009, 09:40 PM
zenoicus's Avatar
Originally Posted by gerhard911 View Post
ZAT502 v. ZAT501
+ better tuner (Samsung) gave me a few more channels
I am confused. Does this mean you find the Samsung's tuner better than both the Centronics, or that the 502 is better than the 501 and the Samsung, or ????
zenoicus is offline
post #27 of 484 Old 05-10-2009, 04:13 AM
gerhard911's Avatar
Sorry for the confusion. I was only comparing the Centronics models. The tuner module in the 502 is made by Samsung while the 501 had one supplied by Thomson.
post #28 of 484 Old 05-10-2009, 06:54 AM
zenoicus's Avatar
...The tuner module in the 502 is made by Samsung while the 501 had one supplied by Thomson.
Thanks for the clarification. So how does the 502's module differ from the one Samsung itself used in its own and now defunct DTB-H260F? Rammitinski speculated in the DTB-H260F thread that the ZAT502 might have a 6th gen chipset. Does it?
zenoicus is offline
post #29 of 484 Old 05-10-2009, 08:14 AM
gerhard911's Avatar
Sorry, I do not know the answer to either question but I think it is safe to assume that the 502 does have a later generation tuner than the 501.
post #30 of 484 Old 05-14-2009, 10:33 AM
rabbit73's Avatar
Quoted: 473 Post(s)
Liked: 198
I ordered my Centronics ZAT502 HD on Monday 5-11-09 and it arrived on Wednesday.
Preliminary testing shows that its sensitivity equals the Apex DT502. I used the attenuator-to-dropout method as described in the link in my signature.
The dual bar display looks just like the one on the Apex. I was able to add a channel after scan, which the Apex can't do---an important feature for the DXer or someone located between two cities.
My primary interest is in boxes that have signal strength AND signal quality bars to use as a measurement tool. Good sensitivity is also important to me because my signals aren't very strong.
Lord Kelvin, 1883
rabbit73 is offline
Reply HDTV Technical
