Can I split Comcast cable internet and OTA antenna on same coax? No. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 05-06-2009, 11:17 PM - Thread Starter
technoreid's Avatar
I want to cancel my comcast cable tv services but still use their internet services COMBINED with an OTA ANTENNA...(trying to reduce my bills) Can I do this on one coax cable with a diplexer....
I hope someone can help me here as I will greatly appreciate it!
thanks! techno
technoreid is offline
post #2 of 19 Old 05-07-2009, 12:11 AM
coyoteaz's Avatar
No
coyoteaz is offline
post #3 of 19 Old 05-07-2009, 04:58 AM
RCbridge's Avatar
Quoted: 16 Post(s)
I second that no, overlapping frequencies!!
RCbridge is offline
post #4 of 19 Old 05-07-2009, 06:29 AM
CRT Dude's Avatar
What are the odds of internet and an OTA station using the same channel?
CRT Dude is offline
post #5 of 19 Old 05-07-2009, 06:30 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
Let's go with a 3rd "NO" vote.
CIAO!
Ed N.
egnlsn is offline
post #6 of 19 Old 05-07-2009, 06:34 AM
Scooper's Avatar
Absolutely not.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #7 of 19 Old 05-07-2009, 06:35 AM
Scooper's Avatar
That isn't the issue - it's the fact that you're now providing a way for the cable signals to be broadcast OTA.
As well as the potentional using the same frequencies.
Scooper is offline
post #8 of 19 Old 05-07-2009, 06:49 AM
rm00k's Avatar
thanks! techno
I thought I read in a comcast forum somewhere that if you have cable internet that you can still get unencrypted local channels. In that case, you wouldn't need an antenna. I have not tried this but I'm also thinking of dropping my tv subscription and just keeping the internet.
rm00k is offline
post #9 of 19 Old 05-07-2009, 06:59 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
Guaranteed, both the downstream and upstream frequencies are being used in the outside world for something. Those somethings will cause grief for cable modems.
CIAO!
Ed N.
egnlsn is offline
post #10 of 19 Old 05-07-2009, 07:00 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
Dropping your cable TV subscription will increase your internet bill by $10.
CIAO!
Ed N.
egnlsn is offline
post #11 of 19 Old 05-07-2009, 07:11 AM
bgdpmp79's Avatar
I don't know if it this makes a difference, I have Time Warner in central TX. I canceled cable a few months ago and kept my internet. I still receive my locals digitally through the QAM tuner of my TV but the analog versions are pretty fuzzed out.
bgdpmp79 is offline
post #12 of 19 Old 05-07-2009, 08:29 AM
Ken H's Avatar
Yes, but you'll need a QAM tuner.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #13 of 19 Old 05-08-2009, 06:15 PM - Thread Starter
technoreid's Avatar
Thanks for everyones help! And you are right Comcast said internet alone would be $65 a month! (+ maybe even a disconnect charge or truck roll fee)
What a monopoly Comcast is. Lower your service/package and they up another service! Crazy!!!!
*Anyone know how high I can go with an antenna? I have cemented a 1" pole into a home depot 5 gallon bucket (using 50 pounds of quickcrete) and it's only 7 feet high. Seems if I go to 15-20 feet high I will have to have some kind of base under the bucket for wind? Maybe I can make an X with some 2X4's as a base....
Would a 1" inch pipe be stable at 15-20ft? Seems as if the base is more important....
thanks, techno
thanks, techno
post #14 of 19 Old 05-08-2009, 08:50 PM
maggiefan's Avatar
The basic cable TV package with the internet would be about the same or maybe even less than having just the internet alone. I know it's crazy, but it's been priced that way for years now. Here it's $15 off of the internet price if you have any TV service at all.
Larry
maggiefan is offline
post #15 of 19 Old 05-08-2009, 11:06 PM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
thanks, techno
No.
CIAO!
Ed N.
egnlsn is offline
post #16 of 19 Old 05-11-2009, 09:18 PM - Thread Starter
technoreid's Avatar
It's actually it's 1" and 1/8 inches in diameter.... and it's steel. Might be a water pipe? Comes in 10 foot lengths at home depot.
I cannot bend it for the world.
It wouldn't be stable at 15-20 feet? even with wires or a base of some sort to stop it from tipping in high winds?
thanks, techno
post #17 of 19 Old 05-12-2009, 05:31 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
If you guy it good, it will probably be alright, then.
CIAO!
Ed N.
egnlsn is offline
post #18 of 19 Old 05-12-2009, 09:57 AM
lovebohn's Avatar
I would agree at 20' your going to be top heavy.
lovebohn is offline
post #19 of 19 Old 05-12-2009, 11:53 AM
nicoge21's Avatar
yea if you cancel your cable and leave only internet they'll raise the price
verizon does it too
nicoge21 is offline
Reply HDTV Technical
