Stories of the Digital TV Transition - What happened when analog went off the air. - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 125 Old 06-16-2009, 04:47 PM - Thread Starter
Ken H's Avatar
From the FCC
WASHINGTON, D.C – Consumers having difficulty receiving certain television
channels following the June 12 transition to digital TV should try these two tips for better
reception: “double rescanning”, and double-checking and relocating their antennas. Meanwhile,
local broadcasters are working to resolve those issues that originate with their signal.
Double Rescanning
Many consumers already know about the need to run the “scan” function on their digital
converter boxes or digital TV sets periodically following the June 12 digital TV transition.
Scanning searches for and “remembers” the available digital broadcast channels.
But in some cases where stations moved their digital frequencies on June 12, simple
scanning may not be enough. There is a procedure – sometimes called “double re-scanning” –
that can clear your box’s memory of saved channels. These earlier scans may have saved channel
information that is now incorrect.
There are five simple steps to a double re-scan for a converter box or digital TV, which
are as follows:
1. Disconnect the antenna from the box or digital TV
2. Re-scan the box or digital TV without the antenna connected. As with any scan
follow the on-screen instructions or owner’s manual for your device
3. Unplug the box or digital TV from the electrical outlet for at least one minute
4. Reconnect the antenna to the box or digital TV and plug the unit into the electrical
outlet.
5. Rescan the box or digital TV one more time.
Double Check & Relocate Your Antenna
You must have a “VHF/UHF antenna. “Rabbit ears,” rods, or other elements are needed
to pick up channels 2-13 (VHF), and a circle, bow-tie, or other element is needed to pick up
channels 14-51 (UHF). Some antennas marketed as HDTV antennas don’t perform well on VHF
channels; some antennas are VHF or UHF-only.
For the best reception of channels 2-6, extend the rods all the way out. For the best
reception of channels 7-13, reduce the length of the rods to 12-18 inches.
Location, Location, Location
The location of an indoor antenna is key. And one of the most popular spots for indoor
antennas – on top of the TV – may not be the best. Consumers having trouble with digital TV
reception should try moving their antennas to one of these locations:
• Near a window
• As high as possible
• Away from other electronic equipment, including computers, VCRs, DVD
players, converter boxes, and the television itself
• Change the direction the antenna is facing
• Rooftop antennas may be needed in some instances
Consumers may need to run the “scan” function again on their converter boxes after
moving the antenna
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #122 of 125 Old 06-17-2009, 09:27 AM
nicoge21's Avatar
the CECB's signal meter is also a very important tool. I use it whenever I have to do any kind of adjustments.
nicoge21 is offline
post #123 of 125 Old 06-20-2009, 02:13 AM
ChrisW6ATV's Avatar
Here in the San Francisco Bay Area, all of the NTSC stations (except the two that shut off in February) stayed on the air right up until midnight Friday night, June 12.
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
post #124 of 125 Old 06-25-2009, 12:36 AM
oldsyd's Avatar
I finally was able to post my photos and videos of the last analog shutoff in my market.
See it here.
Thanks to Kirk, Niels and Ryan for letting me be a fly on the wall that night.
oldsyd is offline
post #125 of 125 Old 07-16-2009, 03:57 PM
MarioMania's Avatar
thanks for the pictures
MarioMania is offline
Reply HDTV Technical
