Best VHF attic antenna? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-13-2009, 08:15 PM - Thread Starter
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
I need a serious VHF antenna for my attic. I'm 15 miles from the VHF station, but I just tried a 60 mile rated VHF antenna (clearstream 5) and it didn't pick up anything in the attic. My UHF only antenna on the other hand is working great in the attic.
No, I don't want to mount an antenna on my roof or use a set top antenna or rabbit ears. I want my antenna in my attic where I have already run all my wiring and was doing fine until FOX Austin screwed everyone by going from UHF to VHF.
All suggestions will be appreciated!
"The boom is dead, long live the bass"
CZ Eddie is offline
post #2 of 8 Old 09-14-2009, 05:28 AM
Joel Graffman's Avatar
I suspect you had a bad connection someplace. Unless you have a tin roof or are trying to receive a low power station almost any antenna should work.
Have you looked at the Local HDTV Info and Reception forum for your area?
Mastermoto
Joel Graffman is offline
post #3 of 8 Old 09-14-2009, 06:17 AM
jtbell's Avatar
KTBC (FOX) on channel 7 is running at a respectable power level for a VHF station, either 30-something kW (a fairly typical number) or about 70 kW (which is getting rather large) depending on whether they've finished building out their construction permit. Either way, you shouldn't need a big antenna at 15 miles. Definitely ask in the Austin thread in the local HDTV reception forum here and see if anyone else has issues with that station.
I don't know about the Clearstream 5, though. It's a new model and I haven't seen any actual measurements of its performance. Its design is very different from the traditional, proven VHF designs. In your situation I'd expect a medium size high-VHF Yagi like the Antennacraft Y5-7-13 to be more than enough, at 1/4 the cost of the Clearstream 5. Or a combination high-VHF + UHF solution such as one of the Winegard HD769x series, but those are more expensive than the Y5-7-13 and you already have a working UHF setup.
How are you combining the signals from the two antennas? For best results you shouldn't use a simple splitter in reverse, but rather something like the Pico Macom UVSJ which is specifically designed for combining / splitting VHF and UHF.
jtbell is offline
post #4 of 8 Old 09-14-2009, 06:56 AM - Thread Starter
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
I've already done all the troubleshooting, including a homerun connection.
I've got no problems with going to a single antenna solution (VHF/UHF/FM).
I've not a normal roof made from OSB and cheap shingles. It's a typical Texas home.
CZ Eddie is offline
post #5 of 8 Old 09-14-2009, 07:08 AM
arxaw's Avatar
See the other thread you started.
arxaw is offline
post #6 of 8 Old 09-14-2009, 02:52 PM
Rick_R's Avatar
I use a Winegard 7015 UHF/VHF antenna in my attic. It is pretty cheap at $37.99 from solidsignal.com. Has great VHF reception and pretty good UHF reception. Since it receives down to channel 2 it is kind of large as all such antennas are.
Rick R
Rick_R is offline
post #7 of 8 Old 09-15-2009, 01:06 AM
mirayge's Avatar
I live 19 miles from WILL PBS 12.1 (9 VHF.) I recieve it fine with some old rabbit ears found in the garage and moved to the attic. I even recieve 18.1 (11 vhf) from Indiana some nights. Try the rabbit ears spread straight out and adjusted for length to your frequency.
mirayge is offline
post #8 of 8 Old 09-15-2009, 01:06 AM
NeedMyTV's Avatar
Originally Posted by danielbatson View Post
Hi,
I think you should go with DB2 HDTV Antenna.Here some specification about this device.
1) Range: 1-30 Miles
2) Multi-directional (pulls in signals from many directions)
3) Achieves a high gain of up to 11.4 dB
4) Ideal for UHF channels 14-69
5) Great for indoor, outdoor, and attic use
6) Dimensions 12 in H x 19 in W x 4 in Deep
7) Weight: 2.8 pounds
8) Lifetime Warranty
Thanks for sharing this information.
He wants a VHF antenna, not a UHF. I suggest a Winegard YA-1713. Use it along with your current UHF antenna and the UVSJ jtbell suggested and you should be in business.
NeedMyTV is offline
Reply HDTV Technical
