bought lava a2805 antenna having problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-24-2009, 05:24 PM - Thread Starter
mikedz5's Avatar
I bought an lava a2805 antenna on ebay and I can't get it to work. I ran the cable from the antenna to the receiver but the receiver only powers on for 2 minutes then goes out and won't come back on. I already had the receiver and power supply replaced once because of this. I tested the new one and it is showing no power coming out of it according to two meters.
So since this is my 2nd power supply with the same results what is my next course of action? How should i resolve this problem and get my antenna to work?
thank you
mikedz5 is offline
Reply HDTV Technical
