Pace RNG-110 HD Cable Box (Comcast) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 09-28-2009, 04:25 PM - Thread Starter
chrisgeleven's Avatar
I just got a Pace RNG-110 HD cable box from Comcast for my new HD TV in the bedroom. Seemed to be pretty straight forward to setup, but no matter how hard I try, the Comcast menus/guide is stretched.
4:3 channels do not stretch, but for some reason the menus/guides do. I tried everything including to turning on auto pillbox in the device's settings, but nothing works.
I hate having the guide and menus stretched. Is there any way to get them not to?
chrisgeleven is offline
post #2 of 29 Old 01-05-2010, 09:30 AM
gifty74's Avatar
Quoted: 52 Post(s)
Hi. Did you get an answer or figure this one out? I too hate the stretched guide, and my old Motorola box did not do this. Hope you have a solution. Thanks.
gifty74 is offline
post #3 of 29 Old 01-05-2010, 02:35 PM
PaulGo's Avatar
Quoted: 175 Post(s)
Liked: 95
That's the way it is supposed to be. It takes some getting used to but many people prefer it! I have also read comments from people who have the Motorola box that they wish their box would have this "feature". Beauty is in the eye of the beholder.
PaulGo is offline
post #4 of 29 Old 01-05-2010, 02:41 PM
PaulGo's Avatar
Quoted: 175 Post(s)
Liked: 95
Does anyone have sound problem with this box? I have it hook up through HDMI to a 23" Samsung 1080p LCD TV and on some HD channels (like HLN) I would got no or a stuttering sound. The only solution I found was on the hidden menu for HDMI was to put it on "pass through" instead of "auto". Again this sound problem is only on a few HD channels.
PaulGo is offline
post #5 of 29 Old 01-05-2010, 03:32 PM
Doug Mac's Avatar
no problem with sound on my box.....some minor lip sync with HDMI to TV and optical to avr
occasional channel changing problems with Harmony One when using favorite icons
Doug Mac is offline
post #6 of 29 Old 01-13-2010, 12:44 PM
beigecat's Avatar
Paul,
Yes, I too noticed your "stuttering" problem on both my Samsung 8500's. Only solution I found was to use the "pass through"
I also have the lipsynch problems with the RNG-110 box via HDMI to HDTV. Sometimes it's so bad that it is annoying to watch. At least if I go thru my receiver I can delay the sound to synch it up.
beigecat is offline
post #7 of 29 Old 02-08-2010, 11:22 PM
SBMongoos's Avatar
Heads up:
I read on the RemoteCentral.com forum about using the IR Sensor Extender that comes with the DTAs that Comcast has been sending out. So I went to the other room and removed it from the DTA I had there and plugged it into the back of the Pace RNG 110. Guess what! Works like a charm now. That would tell me that the sensor(s) on the RNG110 aren't very good. If the remote that comes with it performs no better or less that the Harmony remote but using a plug in IR Sensor does the trick...I think we have a fix here.
I was having a lot of problems with the remotes until I used the above fix.
SBMongoos is offline
post #8 of 29 Old 04-13-2010, 05:29 AM
kevhaas's Avatar
I have gotten two RNG 110 Pace STB for HDTV here in DC and both have failed with the following error...
V1.05 Pace Seattle DC701X Loader
The ASTB needs to download new software. This could take a few minutes, please be patient.
Tuning to frequency LKC: Done
Checking available software : P404sfj_
Find Software Channel : Done
Find Download Channels : Failed
SAM message not received
and it keeps rebooting and failing forever. Comcast technician's remote diagnostic doesn't "find" the box on the network.
Comcast is sending a tech, which will take 10 days. Is there a way to reset this box? Or is it just a brick now?
Is this a common problem? Seems to me it must be for 2 to go out in a row. Where's the quality control at comcast?
(I posted in the RNG 110 STB section over in non-HDTV, but it's really an HDTV STB...)
kevhaas is offline
post #9 of 29 Old 04-18-2010, 11:38 AM
R_J
R_J's Avatar
Hi,
I just installed this STB, as a secondary setup, connected to a panny plasma. If I set the HDMI in pass-through there is no audio on my TV. Auto works fine. Any suggestions? Also, can I use the optical out for DD audio (to my non HDMI receiver) while having the HDMI connected directly to the TV - is the audio out on both simultaneously?
Any comments on the PQ of this box? To me the HD PQ seems worse than that from my other STB/DVR (a Motorola DC*3412), and far worse than when I received some of the HD channels directly on clear QAM on the panny plasma. Are there any settings that I may not be aware of such as hidden menus affecting PQ/HDMI, etc? All outputs formats are enabled ('Yes' in the menu) except for 1080p24 and 1080p30.
R_J is offline
post #10 of 29 Old 05-11-2010, 07:06 AM
zeke04's Avatar
I have the a RNG110 connected HDMI to a Panny 50G25 with audio connected to a non-HDMI receiver via optical with no problem. Yes, you get sound from the TV and receiver simultaneously, you can mute the TV if you don't like it affecting the center channel on your speaker set-up.
zeke04 is offline
post #11 of 29 Old 05-11-2010, 07:17 AM
PaulGo's Avatar
Quoted: 175 Post(s)
Liked: 95
This was due to an older firmware installed on my box. I replace the box and the new one works fine.
Also in my area Comcast recently pushed through a firmware upstate that allow the RNG110 to work iith the older Comcast (silver) remotes ad well as the newer C0mcast (dark gray) remote. I cam now use my universal remote that had the older Comcast codes.
PaulGo is offline
post #12 of 29 Old 05-11-2010, 07:20 AM
SBMongoos's Avatar
Also, if you have a Harmony or Logitech Harmony remote you can have it send out a signal to mute the TV as it turns on your receiver, etc. I do this myself.
post #13 of 29 Old 05-12-2010, 12:50 PM
zeke04's Avatar
I find that the RNG 110 STB make a beeping noise when changing channels, somewhat annoying. Anyone else notice this?
zeke04 is offline
post #14 of 29 Old 05-12-2010, 06:29 PM
rec630's Avatar
Mine makes no noise at all.
rec630 is offline
post #15 of 29 Old 05-12-2010, 06:32 PM
rec630's Avatar
I've got the RNG110 box from Comcast. Are there SD versions of this box? Can/does Comcast alter them to not do HD or disable the HDMI port?
I expect to get a new TV with HDMI but don't have it yet. The comcast RNG stb has an SD sticker on the side. I'm wondering what they did to it.
rec630 is offline
post #16 of 29 Old 05-19-2010, 11:36 PM
pikoo's Avatar
I got mine yesterday. It is making beeping noise when changing channels. I have a samsung lcd tv connected via hdmi.
pikoo is offline
post #17 of 29 Old 06-21-2010, 10:23 AM
gelyon's Avatar
I have the Pace RNG110 in the bedroom hooked up through HDMI to an HDTV. The only problem I have with it is after about 1.5 to 2 hours the audio is noticably out of sync with the video. I have found that switching to another channel and then back puts it back in sync. Still annoying. I hooked it up via component video and the problem is not there.
gelyon is offline
post #18 of 29 Old 07-15-2010, 11:24 AM
TommyO's Avatar
I also have that annoying chirping sound when changing channels on my Pace RNG110 box. I have the Panasonic 50" G-20 and my connection is via a HDMI cable. I also notice an "out of sync" problem; voice is out of sync with the movements of someone's lips.. annoying as heck too and it bugs the hell out of me. My cable company is Comcast and I am under the impression that the sync troubles might be due to "over-compression" through their cable system. (too heavy a bandwidth, maybe?) I'm not too techno so if anyone can elaborate and correct me please if I am wrong. I want to switch to Verizon Fios but it is not yet available in my area, dammit.... Got to put up with Comcast & over-compression for a bit longer.
Does ayone else here have Comcast too, and are you having out-of-sync troubles too ???
TommyO is offline
post #19 of 29 Old 07-15-2010, 02:44 PM
Doug Mac's Avatar
I have two RNG-110's, the one feeding sound (optical) to an old Onkyo AVR has sync problems.....I need to upgrade to an AVR w/sync adjust......no chirping on either
Doug Mac is offline
post #20 of 29 Old 07-16-2010, 07:26 AM
kevhaas's Avatar
Found out from the tech that they were shipping the wrong software with the boxes from Maryland for their DC customers. Comcast SNAFU, as usual...
kevhaas is offline
post #21 of 29 Old 07-20-2010, 03:25 PM
PGHammer's Avatar
Originally Posted by beigecat View Post
Paul,
Not a problem I've had (I have an RNG110, and it is currently connected to a 4:3 Sanyo 27" CRT; I've also had it connected to my 42" Philips plasma, where I am hoping to reconnect it to after my aunt and uncle head back to Dallas). The connection to the Sanyo is via component, and to the Philips is via HDMI; in both cases, the output is 16:9/1080i.
PGHammer is offline
post #22 of 29 Old 07-20-2010, 03:33 PM
PGHammer's Avatar
Hardly a SNAFU; while the same technicians (especially contractors) can cover both systems, the two systems have different warehouse facilities (in DC's case, it's on Michigan Avenue, NE, while in Maryland, it's in Lanham, off of Annapolis Road) and have different headend setups (though both use primarily Motorola STBs). They have not completely solved the issue of STB interchangeability, even in similar systems.
The *wrong software* problem is because the boxes weren't *checked in* in DC's database (which is generally required prior to a box being deployed in any system), and that takes place at the warehouse (Michigan Avenue).
PGHammer is offline
post #23 of 29 Old 07-21-2010, 05:07 AM
Doug Mac's Avatar
you should get a $20 credit for the SNAFU
Doug Mac is offline
post #24 of 29 Old 07-30-2010, 09:17 AM
ellogovna's Avatar
Help. I am trying to control an RNG110 with a Prodigy PMC2E which has 6 IR outs which are 3.5mm mini jacks. My RNG110 has in "IR Receive" port and I would like to directly control the box this way. I tried connecting a stereo mini 3.5mm and a mono mini 3.5mm but neither worked. Anyone been able to make this work?
Worst case scenario I can use an IR emitter but I need to know the location of the RNG110's IR receiver. Any help would be appreciated.
ellogovna is offline
post #25 of 29 Old 08-29-2010, 05:51 AM
tagzmat's Avatar
I have noticed on the 2 occasions that I have used the wrong prower supply(it uses a usb voltage supply) that while the box sits there with it's lights blinking madly something gets wiped in the firm wear and when the right supply is used again it will just sit downloading software for eternity.
They come with the comcast soft wear loaded on em. The first thing you will see on a functioning unit when it's first hooked up is the channel info tab just like a motorolla box.
tagzmat is offline
post #26 of 29 Old 09-09-2010, 10:06 AM
andrios's Avatar
Having issues with this stb and my denon 2311ci. Lots of random screen flickers. It works fine when plugged directly in tv tho.
andrios is offline
post #27 of 29 Old 07-12-2013, 01:46 AM
Vinh Truong's Avatar
The Flash chip within the box is bad which prevents you from finishing the download. I suggest a replacement box.
Vinh Truong is offline
post #28 of 29 Old 07-13-2013, 06:34 AM
Ratman's Avatar
Quoted: 1459 Post(s)
Liked: 1158
(also.... refer to post #20)
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #29 of 29 Old 07-15-2013, 04:02 PM
PaulGo's Avatar
Quoted: 175 Post(s)
Liked: 95
I had to swap mine out because they still did not upgrade the firmware in my area. Every 10 days or so I had to unplug the box because I was not able to get VOD. I would get an error message telling me to unplug the box when I tried to access VOD.
PaulGo is offline
Reply HDTV Technical
