Any way to use two antennas at the same time (with a splitter)? - AVS | Home Theater Discussions And Reviews
post #1 of 11 Old 11-01-2009, 05:59 PM - Thread Starter
Awesomeness's Avatar
I have one antenna that gets 90% of what I want. CBS and another channel can be recieved if I move the antenna, but then I lose FOX and other channels.
Can I attach two antennas to a splitter and run that to the television? That way I could have one antenna pick up what I get now, and another antenna pick up CBS that I don't get now.
Awesomeness is offline
post #2 of 11 Old 11-01-2009, 07:03 PM
ProjectSHO89's Avatar
Quoted: 103 Post(s)
Liked: 82
There's more to it than what you've given us.
As always, run your TVFool plot and post your results link so we can see what channels are in play and where they come from.
ProjectSHO89 is online now
post #3 of 11 Old 11-01-2009, 07:52 PM
Colm's Avatar
Liked: 90
Combining antennas can be tricky depending on what each antenna picks up and how their signals will interact when combined. That said, if what each antenna will pick up is mutually exclusive of what the other will pick up, then you should be able to get away with something as simple as a combiner/splitter. Or you can use a rotator.
Colm is offline
post #4 of 11 Old 11-02-2009, 01:27 PM
DAP
DAP's Avatar
I use two antennas, but I use a switch for my STB, and separate tuners for recording.
If you can get one or more of the channels with both antenna directions, that channel will interfere with itself, and may kill your ability to receive that channel just like multipath.
DAP is offline
post #5 of 11 Old 11-02-2009, 02:23 PM
Tschmidt's Avatar
First step is to plug in your address in: http://tvfool.com/ and post the results.
If signals are strong, and multipath is not a problem using a splitter as a combiner may work fine. The down side you lose half the signal and the off-axis antenna may add excessive multipath.
Another option is to use Channel Master JoinTenna: http://www.warrenelectronics.com/Ant...Jointennas.htm
Tschmidt is offline
post #6 of 11 Old 11-02-2009, 04:59 PM
willscary's Avatar
Liked: 29
Yes!
http://webpages.charter.net/willscar...er-1%20web.jpg
These 4 antennas, plus two more in my attic, are all joined together and I can watch any channel on any of 4 different TVs at any time...no rotor.
It is not guaranteed to work, but if you are lucky and your channels work out correctly, it can work wonderfully. As said above...post your TV Fool plot. Be sure to use your exact coordinates of your antenna location (per google earth) and your antenna height.
Bill
willscary is offline
post #7 of 11 Old 11-02-2009, 06:46 PM
Panth1's Avatar
I have two antennas joined with a splitter. One faces north, the other south. It produced some multipath with analog but the digital channels come in fine.
The only way to know for sure is to try it out. Everyone's location will be different.
Panth1 is offline
post #8 of 11 Old 11-03-2009, 09:13 AM - Thread Starter
I can't highlight and copy the info, so I'll summerize it.
All my local channels come from the same Azimuth True and Madn.
The distance for local channels are very close to 20 miles.
The signal goes from Pwr(dbm) -46.1 to 59.5.
Real channel the lowest number is 12 and the highest is 51. Real channel 12 is 2.1 here and a hard one to get. It is also the one with the highest Pwr(dbm).
WLS is another hard one to get. They broadcast on 44 mapped to 7.1. I get nothing on 7.1, but on 44.1 I get WSNS which says it's real broadcast is 45. In the chicago thread people are saying there is interferance and they expect 44.1 to get booted.
Path is 2edge on all of them.
post #9 of 11 Old 11-03-2009, 01:34 PM
DAP
DAP's Avatar
Click on the "save image" button on the web page to save a picture of the display, then upload that picture here.
This will create a picture of the web page.
DAP is offline
post #10 of 11 Old 11-03-2009, 01:58 PM
Quoted: 103 Post(s)
Liked: 82
It is far better to cut and paste the link that is given for sharing as THAT page allows individual stations to be focused upon, should it be needed.
post #11 of 11 Old 11-03-2009, 04:00 PM
willscary's Avatar
Liked: 29
If you can give us your latitude and longitude at your antenna, I will plug it in then paste the results here.
Bill
Reply HDTV Technical
