HD OTA on Panasonic DLP PT60DL54 50" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-01-2009, 07:37 PM - Thread Starter
freeskimonkey's Avatar
I have a Panasonic PT60DL54J 50" DLP. I can see the radio towers on top of Lookout Mountain from my 2nd story deck in West Arvada.
I just went to Best Buy and picked up an outdoor/attic HD antenna.
I ran about 30 feet of coax cable from the antenna directly into the COAX into the COAX antenna-in connector/port on the back of the TV.
I held the antenna pointed directly at the towers I could see (maybe 10 miles away, using a 50 mile range antenna) and could not get anything except for two spanish channels and some gospel channel, and none of the three are in HD.
I should be getting CW,CBS,ABC,NBC,FOX,UNI and more, and in HD.
My neighbor across the street gets these channels crystal clear in HD on his newer Samsung HDTV.
I am perplexed.
I was wondering if my TV is cable of dealing with the HD OTA signal as connected or if I needed some kind of HD receiver for it.
Please, please, please help me!
AtDhVaAnNkCsE !!! (thanks in advance)
Here's the manual for my TV: http://www.mediafire.com/?sharekey=d...4e75f6e8ebb871
Here's the antenna I got: http://www.antennasdirect.com/C2-Cle...V-antenna.html
-FM
freeskimonkey is offline
post #2 of 11 Old 11-01-2009, 07:48 PM
Ken H's Avatar
Does your HDTV have an ATSC tuner?
It may be called ATSC, 8VSB, DTV.
Edit: From what I can tell, your HDTV does not have a Digital TV tuner, which would account for why you don't get any HD channels.
If that is the case, you'll need an external DTV tuner. See this topic for a list: http://www.avsforum.com/avs-vb/showthread.php?t=179095
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 11 Old 11-01-2009, 08:02 PM - Thread Starter
Ken: While your answer makes me VERY, VERY, VERY unhappy, I greatly appreciate the response.
I think I may just build a Windows 7 (Windows Media Center) HTPC and get myself a WMC-supported USB2 Tuner.
Hauppauge claims these work with Win7:
http://www.hauppauge.com/site/suppor...duct_list.html
Hauppauge WinTV-HVR-850:
http://www.hauppauge.com/site/products/data_hvr850.html
Hauppauge WinTV-HVR-950Q
http://www.hauppauge.com/site/produc...a_hvr950q.html
Hauppauge WinTV-HVR-1950
http://www.hauppauge.com/site/produc...a_hvr1950.html
post #4 of 11 Old 11-01-2009, 08:30 PM
Ken H's Avatar
Yes, that will work and give you PVR capability, but it's not like watching TV; it's like using a PC.
Also, does your HDTV have RGBHV input?
Ken H is offline
post #5 of 11 Old 11-01-2009, 09:02 PM - Thread Starter
It has one HDMI input, three component (RGB but not RBGHV?) inputs, one VGA input, and three RCA connector inputs.
post #6 of 11 Old 11-01-2009, 09:06 PM - Thread Starter
Using WMC, I'll be able to flip sit on the couch with my WMC HTPC remote and flip through the channels, afaik. That's very much like watching TV, no?
post #7 of 11 Old 11-01-2009, 09:13 PM
Ken H's Avatar
Trust me, it's close, but different.
Ken H is offline
post #8 of 11 Old 11-01-2009, 09:15 PM
Ken H's Avatar
You'll use the VGA input.
The component inputs are not the same as RGB /RGBHV. VGA is.
You'll need some kind of program to optimize the PC video output to your HDTV's video input format. Do some research in the HTPC Forum: http://www.avsforum.com/avs-vb/forumdisplay.php?f=26
Ken H is offline
post #9 of 11 Old 11-01-2009, 09:24 PM - Thread Starter
Thanks for the links. I will for sure read through these before I build a new system. My current system is hooked up to the TV via component cables (HP laptop docking station has component cable output). Netflix and Hulu work great.
Do you think the VGA output would work better than the component cables?
It's XP Pro, so I don't have Windows Media Center, so I'd have to rely on some alternative Media Center software like XBMC, MythTV, or whatever software comes with the USB2 Tuner device I purchase.
Any thoughts?
post #10 of 11 Old 11-01-2009, 09:44 PM
Ken H's Avatar
If both are HD, it shouldn't matter, but I'd try both and see if there was a difference.
As for the rest, the HTPC Forum is the place with the best answers.
Ken H is offline
post #11 of 11 Old 11-01-2009, 09:45 PM - Thread Starter
Thanks for all your help!
Reply HDTV Technical
