TV speakers pop while changing the channel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-01-2009, 11:22 PM - Thread Starter
bl4ke360's Avatar
I have the LN46B640 LCDTV, with the Motorola DCX3200 HD receiver, connected via HDMI. I'm using Cox cable. I noticed a bad lag for the channel to change, and popping sounds from the speakers while the channel is in transition to change. Is this a well known problem that anyone knows the answer to, or is it a problem with the TV or the receiver?
bl4ke360 is offline
Reply HDTV Technical
