HD picture quality for NFL games - AVS Forum | Home Theater Discussions And Reviews
Old 12-31-2009, 11:44 AM - Thread Starter
PMA
PMA's Avatar
Quoted: 32 Post(s)
I recently purchased a Samsung UN55 8500 LED HDTV which is a major improvement in picture quality for NFL games since it runs at 240 Hz vs. my prior Sharp TV. In comparing game broadcasts between Fox, CBS, NBC, NFL Network and ESPN, I still see what I believe is referred to as macroblocking on NBC during any motion. Picture quality on NBC Sunday night games appears inferior to all the other networks who broadcast games.
Is this true for others as well? If so, why would NBC not have as good a picture as the other networks?
Cheers and Happy New Year.
Paul
PMA is offline
Old 12-31-2009, 01:23 PM
coyoteaz's Avatar
KNTV, like all other NBC O&Os, carries 2 SD subchannels in addition to the primary HD program. This limits the HD broadcast to about 13.5Mb/s. KPIX, being a CBS O&O, has no SD subchannels and sends out video at 17+Mb/s. As a general rule, lower bitrates result in lower quality.
Those who are in markets where the CBS affiliate crams a bunch of SD subchannels into the stream (Milwaukee comes to mind, with 3 SD subchannels) may see the opposite.
coyoteaz is offline
Old 12-31-2009, 02:59 PM
TVOD's Avatar
Quoted: 75 Post(s)
Liked: 76
NBC used to have a quite inferior network distribution for both video and audio. Since they moved to their new system the network feed is much improved. As stated, it's some of the affiliates, especially the O&Os, that are an issue. However it's possible now for a NBC affiliate to look very good on network programming.
ABC uses a similar system for their network distribution but is limited by their O&O affiliates with a second HD subchannel (LiveWell) and an SD. Bitrates are better than when they first added Livewell but not as good as they once were. KGO is an O&O.
TVOD is offline
Old 12-31-2009, 03:22 PM
sillysam's Avatar
I find that NBC has one of the best quality pictures of all the networks.
sillysam is offline
Old 12-31-2009, 04:33 PM
CharlieB-oz's Avatar
I agree. This season NBC has a very good NFL game picture. I watch over WDSU in New Orleans OTA, which has one subchannel.
CharlieB-oz is offline
Old 12-31-2009, 06:27 PM
BCF68's Avatar
Yeah I can verify that. WTVF( CBS ) used to not have any subchannels and looked great. Now it has 2 and you can tell the difference.
BCF68 is offline
Old 01-01-2010, 07:54 AM
RCbridge's Avatar
In my area the OTA NBC football does look very good, I don't see much distortion during fast motion scenes.
However I am using a plasma display.
Also the quality of NFL channel is also very good.
Fox and ESPN (ABC) seem to vary but overall good.
RCbridge is offline
Old 01-03-2010, 07:45 PM - Thread Starter
PMA
PMA's Avatar
Quoted: 32 Post(s)
Thanks for the explanations. Looks like this is unique to the SF Bay Area and KNTV.
PMA is offline
Old 01-03-2010, 07:56 PM
Ken H's Avatar
Did you check the local topic for your area?
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Old 01-07-2010, 11:26 AM
joeh4384's Avatar
Watching the bcs, i could notice that fox's quality on the sugar bowl was worse than abc's during the rose bowl.
joeh4384 is offline
Old 01-08-2010, 01:37 PM
TonyXL's Avatar
The rankings are based on the direct QAM feed.
#1: FOX. Very sharp. Little to no artifacts.
close #2: NBC. Very sharp as well. A tiny bit of noticeable artifacts.
#3: ABC. Not sharp at all. Looks low-res. Artifacts during motion and around static graphics.
#4: CBS. Terrible. Blocking artifacts fill the screen on fast motion. Just gross.
TonyXL is offline
Old 01-07-2012, 05:31 PM
robertawillisjr's Avatar
Quoted: 13 Post(s)
Resurrection.
NBC football coverage has been poor all season. Today's playoff game (Houston) does not appear to be true HD. The picture is soft, there is a good deal of pixellization during fast movements and PQ varies between cameras.
robertawillisjr is offline
Old 01-07-2012, 05:41 PM
ybsane's Avatar
Quoted: 57 Post(s)
Liked: 29
Originally Posted by robertawillisjr View Post
Resurrection.
It is in in High Def, your local provider (OTA,Cable,other) is providing you with a poor feed. The bit rate over satellite is 18Mbps MPEG-4
All Comments made are my own and not of my employer.
ybsane is offline
Old 01-07-2012, 07:46 PM
cgmv123's Avatar
Quoted: 39 Post(s)
Liked: 36
22.5, but your point is valid. The game looked great on my affiliate.
As always, the closer a source is to you, the more control they have over content.
Here, NBC beats CBS every time. Both of my local affiliates have 1 subchannel, but WMTV (NBC) has their's well managed, while WISC's (CBS) is less than well managed.
Max Vrany
All opinions are my own unless otherwise specified.
I make no guarantees as to the accuracy of any information given.
GO Pack GO! On Wisconsin! Go Brewers!
cgmv123 is offline
Old 01-07-2012, 07:52 PM
coyoteaz's Avatar
Should be looking better on NBC O&Os now that Universal Sports is gone. KXAS has completely removed .3 and given that bitrate back to the HD channel. I would imagine the others have done the same since NBC apparently has no plans for putting something else up. Probably still won't be as good as CBS O&Os running without subchannels, but better than it was a week ago.
coyoteaz is offline
Old 01-07-2012, 07:57 PM
cgmv123's Avatar
Quoted: 39 Post(s)
Liked: 36
CBS O&O's will be adding subchannels shortly.
Max Vrany
cgmv123 is offline
Old 01-08-2012, 06:20 AM
adb
adb's Avatar
Resurrection.
I agree with NBC's picture not being very good. Rather than being from the local feed my impression was it was the network. There were some local HD commercials that were sharp.
adb is offline
Old 01-08-2012, 06:32 AM
cgmv123's Avatar
Quoted: 39 Post(s)
Liked: 36
Big difference in motion. NBC's network feed is top notch. Your local affiliate has the most control over the picture quality you see.
Max Vrany
cgmv123 is offline
Old 01-08-2012, 03:34 PM
Ken H's Avatar
NYC will be very soon, LA to follow, but the other O&O markets may take more time, and at least one without local news (Detroit) may not get a subchannel at all.
Ken H is offline
