comcast hd box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-24-2010, 09:08 PM - Thread Starter
Calcvictim's Avatar
here is the setup, 2 rooms, both have hd comcast boxes hooked up through component cables to plasma tvs.
one of the tvs has artifacts on 3 channels, 804, 805, 807 all the other channels are fine. the second room has no artifacts on the same channels. until 4 days ago both cable boxes were fine, no artifacts.
I went to the comcast office and swapped what I thought was a bad box, same ****.
any suggestions?
Calcvictim is offline
post #2 of 5 Old 02-24-2010, 09:28 PM
dave1216's Avatar
Quoted: 97 Post(s)
Liked: 59
any suggestions?
Did you check the cables leading and into the TV giving you trouble?
dave1216 is online now
post #3 of 5 Old 02-24-2010, 09:29 PM - Thread Starter
Calcvictim's Avatar
i checked the cable going into the tv and it's good, is it possible for it to be a bad cable but only to affect a few channels?
post #4 of 5 Old 02-24-2010, 09:35 PM
homcom's Avatar
Yes.
homcom is offline
post #5 of 5 Old 02-24-2010, 10:25 PM
jay2031's Avatar
Have you configured the video settings for the output of the box to match your sets?
Press POWER to put the set-top in stand-by mode. With-in two (2) seconds press the MENU key on the front panel.
If the TV is on, the on-screen User Settings menu lists the STB settings that can be adjusted
Change the video settings to give you the best results. Settings vary between Motorola, Pace and Scientific Atlanta / Cisco boxes.
jay2031 is offline
Reply HDTV Technical
