comcast hd channels: did they shrink? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-01-2010, 10:58 AM - Thread Starter
Matt97GT's Avatar
I noticed this awhile back.
My HD channel used to take up the entire screen. Now, it's only about 2/3rd's of the screen, with black bars on the top and bottom. I can change my aspect ratio on my tv to zoom to get back to full screen, but the quality isn't HD anymore.
I find myself watching the regular version (mainly espn and espn2) just because it's full sized.
this is comcast HD.
Matt97GT is offline
post #2 of 4 Old 03-01-2010, 11:15 AM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
this is comcast HD.
un zoom your tv and try a few things
make sure you are using hdmi or component input
check zoom settings on cable box
dm145 is offline
post #3 of 4 Old 03-01-2010, 11:33 AM
iontyre's Avatar
Your cable box may also be set to only output SD. HD channels being output as SD always to include black bars at top and bottom, so I am sure you are only getting 480i/p from the box. Try unplugging the STB, let it sit a few minutes, then plug it back in, it may give you the setup menu to tell it what resolutions to output.
Proud Galactic Imperialist
iontyre is offline
post #4 of 4 Old 03-01-2010, 12:01 PM
Ken H's Avatar
Channels are the same, it's your set up.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Reply HDTV Technical
