question about comcast digital migration and my over the air hd? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 65 Old 04-08-2010, 11:03 AM
Scooper's Avatar
Originally Posted by QZ1 View Post
No, he could find a much less expensive splitter, that works much better; gold splitters are no good, not conductive enough, and Radio Shack /= quality. The reviews, as I expected, are poor; way overpriced junk, as often is the case with Radio Shack.
My recommendation is for him to buy a splitter online, something like the cable cos. use; Regal, Broadband Extreme, or Antronix, and others like Steren are good too. No gold, and 5-1000MHz is all that one needs to look for in one of those good brands.
Agreed - that was just to show an example of "what" a splitter is - not a "recommendation" for that particular one.
I find the splitters you can find at Ace, or Home Dept / Lowes Home Improvement, to be of equal or better quality than the fancy "gold" ones and work just fine.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #62 of 65 Old 04-08-2010, 11:19 AM
QZ1
QZ1's Avatar
Understood. My point, though, was the 'fancy gold splitters' are actually worse, (and way overpriced). They work sometimes, but that is because any given home might have extra signal to offset the unnecessary extra signal loss from the gold splitter. (Also, a Radio Shack splitter's construction is questionable.)
QZ1 is offline
post #63 of 65 Old 04-10-2010, 07:04 AM - Thread Starter
gregdpw's Avatar
ok i went to homedepot today and got my ab switcher and splitter. hopefully i can get this working. thanks guys
gregdpw is offline
post #64 of 65 Old 04-10-2010, 07:29 AM - Thread Starter
gregdpw's Avatar
got it working! thanks guys. yeah i went to homedepot and got a splitter and a switch for only 8 dollars. thanks
gregdpw is offline
post #65 of 65 Old 04-10-2010, 02:56 PM - Thread Starter
gregdpw's Avatar
that just saved me a monthly fee for a cable box. take that cable company!!!!!!!!!!!!!
gregdpw is offline
Reply HDTV Technical
