Interest in ATSC 8VSB Modulator? - AVS Forum | Home Theater Discussions And Reviews
Old 04-17-2010, 12:07 PM - Thread Starter
R5000-HD's Avatar
We (Nextcom, LLC) have a design for an ATSC Modulator (8VSB) that was developed into an actual working prototype a couple years ago but was pretty much shelved. I was wondering what kind of interest there is in such a device. Basically it works via a USB connection and modulates any standard MPEG transport stream (HD, SD, or multiplexed) onto a UHF carrier (ch 14/15). It does not do any encoding and thus does not accept component or HDMI input. The stream can be disk-based or captured live via any hardware/software combo that produces transport streams. The main limiting factor is that it is PC-based and not stand-alone.
This would be an inexpensive solution (a fraction of the $1500+ for current commercially available hardware) and could be used to distribute HD via long coaxial runs or part of a MATV system. Could also display media center or other applications on a HDTV without a dedicated HDMI or VGA hookup.
If brought to the market, the only change we anticipate is possibly making it frequency agile. Thoughts, comments?
-R
Anyone interested can register via our website for further information...
R5000-HD is offline
Old 04-17-2010, 02:04 PM
Scooper's Avatar
bring it on !! I'd love to be able to do my own 8VSB for a/v sources alongside of the OTA channels, even if it is just SD.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
Old 04-17-2010, 02:13 PM
JWKessler's Avatar
I have a Dish Network system and they do not carry my locals so I keep cable for that. The Dish VIP722 receiver can pick up ATSC but not QAM so I can't record my cable channels on the Dish DVR. I keep thinking that it is so close - just convert QAM to ATSC some how. It looks as if your device will not do that however.
If you intend this device to be used to distribute HD video, how will that compete with the Sling devices. These reasonably priced boxes will allow you to distribute HD video over your home wireless network.
JWKessler is offline
Old 04-17-2010, 02:45 PM
AntAltMike's Avatar
Quoted: 126 Post(s)
Liked: 62
I could use it for the broadcast, 8VSB master antenna systems I maintain where the lobby camera signal is still analog. In my applications, I wouldn't require a SAW filtered output, because my channel lineups are light and I could often put it on the VHF lowband by itself.
Is ths device capable of taking a digital output from an affordable surveillance camera and converting it to a form such that a conventional TV tuner would recognize it as a channel, or would I still have to put an MPEG encoder between the camera output and your device's input?
If you do come up with an agile modulator, you would want it to be UHF channel-plan capable, since most digital TVs will not process an 8VSB signal if it is set to its "cable STD" channel plan, nor will they seek out and "capture" an 8VSB signal that is 2MHz off frequency when their tuner is set on "antenna", whereas the AFT circuitry will do that with analog signals.
AntAltMike is offline
Old 04-17-2010, 03:39 PM
Trip in VA's Avatar
Quoted: 467 Post(s)
Liked: 136
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
Originally Posted by R5000-HD View Post
Thoughts, comments?
-R
I would buy one or more. Make one that'll do multiple SD video sources and I'll buy multiple!
(I would love to feed some FTA satellite around my house via ATSC...)
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
Old 04-17-2010, 03:45 PM
bdfox18doe's Avatar
Quoted: 199 Post(s)
Liked: 110
Basically it works via a USB connection and modulates any standard MPEG transport stream (HD, SD, or multiplexed) onto a UHF carrier (ch 14/15). It does not do any encoding and thus does not accept component or HDMI input. -R
I don't think that part was heard very well by most here. However what you describe would work very well with TSReader, (Rod would have to write the interface) and I would buy at least one.
It sounds very similiar to this unit:
http://www.dektec.com/Products/USB2/DTU-215/
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
Old 04-17-2010, 04:09 PM
Trip in VA's Avatar
Quoted: 467 Post(s)
Liked: 136
Hm, I had missed that. Still, I have lots of spare computers. As long as I could figure out how to create a compatible transport stream out of SD video sources, I think I'd be in good shape! =)
- Trip
N4MJC
RabbitEars
Old 04-17-2010, 04:22 PM
bdfox18doe's Avatar
Quoted: 199 Post(s)
Liked: 110
That's not too hard with a good pc, the right hardware and TSReader. I have
a box I will try that on..
Bob
Old 04-17-2010, 04:53 PM
Trip in VA's Avatar
Quoted: 467 Post(s)
Liked: 136
How would one go about doing that? I can do the things I need to with TSReader, but I gather that it's much more powerful than what little parts I use.
- Trip
N4MJC
RabbitEars
Old 04-17-2010, 05:08 PM
Scooper's Avatar
What most people would find most useful is a device that will let you take an NTSC audio/ video analog inputs , convert to MPEG2 and modulate that out as an UHF ATSC TV signal. THAT would be worth buying....
Scooper is offline
Old 04-17-2010, 07:05 PM
walford's Avatar
Certainly there are a few people who would like to have an 8VSB modulator, however, IMHO you dould never make a profit by with the product due to the launch, training and support requirements.
walford is offline
Old 04-17-2010, 07:38 PM
bdfox18doe's Avatar
Quoted: 199 Post(s)
Liked: 110
Sad to say Walford is correct, IMHO...even the ever-declining MATV market isn't enough to justify an ATSC modulator. Now QAM is another story..
Bob
Old 04-17-2010, 07:55 PM
Trip in VA's Avatar
Quoted: 467 Post(s)
Liked: 136
I wish the CECBs would understand QAM...
- Trip
N4MJC
RabbitEars
Old 04-18-2010, 08:36 AM
walford's Avatar
We US Tax payers subsidized the purchase of CECBs in order to allow users watching analog only channels using an antenna to still be able to watch the same channels with a TV's analog tuner after the digital cutover and nothing more.
walford is offline
Old 04-18-2010, 12:24 PM
Trip in VA's Avatar
Quoted: 467 Post(s)
Liked: 136
As there exists no inexpensive ATSC modulator, but at least one QAM modulator, I am now unable to watch things I had modulated into my house's coax in analog.
And in the interest of accuracy, US taxpayers paid nothing for the coupon program. Auction revenue paid for that.
- Trip
N4MJC
RabbitEars
Old 04-18-2010, 01:23 PM
AntAltMike's Avatar
Quoted: 126 Post(s)
Liked: 62
Originally Posted by Trip in VA View Post
...in the interest of accuracy, US taxpayers paid nothing for the coupon program. Auction revenue paid for that...
But we auctioned off the taxpayer's airwaves.
Old 04-18-2010, 01:45 PM
walford's Avatar
walford is offline
Old 04-18-2010, 01:50 PM
bdfox18doe's Avatar
Quoted: 199 Post(s)
Liked: 110
I have connected an HD camcorder with firewire out to TSReader, such as the Sony HVR-Z1. Now if Rod would write an interface to forward a firewire stream to a USB modulator one could do what Mike needs. I have a Canon XL-1 SD camera I need to try that with.
Bob
Old 04-18-2010, 02:35 PM
AntAltMike's Avatar
Quoted: 126 Post(s)
Liked: 62
Not that I even need high definition, but here is a camera available new in quantity on eBay for $299. I need the building blocks to get from that output or something like it to 8VSB modulated, channelized RF.
http://cgi.ebay.com/FULL-HD-1080p-12...item2a065bfd57
Old 04-19-2010, 09:36 AM - Thread Starter
R5000-HD's Avatar
The trend in camcorders is away from HDV which is an MPEG-2 format to using AVC/H.264. Firewire connectivity is part of the DV/HDV spec and it supports live streaming, for example using the MSDV driver. However, DV (which is SD) is not the same as MPEG-2. Technically, anything that can be encapsulated into a standard transport stream format can be modulated onto 8VSB. However, your digital receiver is probably not going to know how to handle anything except for MPEG-2 (even though theoretically it can as long as it has a suitable decoder).
The new AVC camcorders are designed to transfer live video via an HDMI or component connection and to offload the video via USB. You could capture the video using an HDMI or component capture board and then encode to MPEG-2 realtime (for HD this is going to take a computer with quite a bit of horsepower).
Our approach would most likely focus on using a standard API like DirectShow for receiving an MPEG transport stream input.
-R
R5000-HD is offline
Old 04-19-2010, 10:12 AM
Wendell R. Breland's Avatar
Quoted: 283 Post(s)
Liked: 146
Bob,
I assume you mean streaming in realtime from TSReader to the Nextcom ATSC Modulator? If so, do you believe Rod would do an interface?
Files recorded (.TS or .TP) by TSReader should work fine with the Nextcom.
For R5000-HD: Would Nextcom offer a SDK with this device?
Wendell R. Breland is online now
Old 04-19-2010, 10:50 AM
bdfox18doe's Avatar
Quoted: 199 Post(s)
Liked: 110
Originally Posted by Wendell R. Breland View Post
do you believe Rod would do an interface??
Only Rod can answer that question.
Bob
Old 04-19-2010, 11:32 AM
walford's Avatar
All OTA digital broadcasts are broadcast using 8VSB modulation and the actual content of video is ATSC standard MPEG2. Also the content of almost all/if not all Digital QAM modulated digtial broadcasts is also encoded using ATSC standard MPEG2.
Some of the posters in this thread are confusing the delivery modulation method used with the internal video format of the the content being delivered. They need to realize that when you send a letter by air, ship, or train that does not also determine the lanquage that the letter inside is written in.
walford is offline
Old 04-19-2010, 09:10 PM - Thread Starter
R5000-HD's Avatar
Bob,
Its pretty early to tell what/if anything will be delivered but I imagine if we go ahead with this that some sort of development info would be made available along with a demo app & its source code. The goal would be to make it easy for third-parties to develop applications around it and at this point we're thinking that packaging the functionality into a DS driver maybe the easiest way to accomplish that.
R5000-HD is offline
Old 04-19-2010, 10:09 PM
Quoted: 283 Post(s)
Liked: 146
Sent Rod an email inquiring about his interest in this project.
Old 04-19-2010, 10:22 PM
Quoted: 283 Post(s)
Liked: 146
Thanks for the info. IIRC, TSReader interfaces with devices using BDA drivers to obtain data. I know that he can stream data (.TS) from TSReader to VLC media player or Firewire devices. I have no idea what methods he (Rod Hewitt) uses.
Old 04-20-2010, 09:00 AM
dr1394's Avatar
Quoted: 100 Post(s)
Liked: 51
Originally Posted by walford View Post
All OTA digital broadcasts are broadcast using 8VSB modulation and the actual content of video is ATSC standard MPEG2. Also the content of almost all/if not all Digital QAM modulated digital broadcasts is also encoded using ATSC standard MPEG2.
The standards body for cable (and QAM modulation) is not ATSC, it's SCTE (Society of Cable Telecommunications Engineers). MPEG-2 video constraints are defined in SCTE43.
http://www.scte.org/documents/pdf/st...SCTE432005.pdf
If you analyze actual cable MPEG-2 bitstreams, you'll find that not everyone follows SCTE43 to the letter. Many providers use a full size VBV buffer for HD (9781248 bits) instead of the SCTE43 constrained 7995392 bits. It's because that VBV size constraint goes way back to when 8 Megabits of memory was expensive. These days, where you can't even buy SDRAM smaller than 256Mb, the VBV size constraint is pretty silly.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is offline
Old 04-20-2010, 10:32 AM
bdfox18doe's Avatar
Quoted: 199 Post(s)
Liked: 110
Has anyone talked with ZeeVee to see if the chipset used in their QAM modulator can support ATSC? Even if they don't offer that capability.
Bob
Old 04-20-2010, 12:00 PM
Trip in VA's Avatar
Quoted: 467 Post(s)
Liked: 136
All I know about ZeeVee is that they said they won't do it because QAM is open while ATSC transmission is apparently patented or something like this.
- Trip
N4MJC
RabbitEars
Old 04-20-2010, 12:15 PM
bdfox18doe's Avatar
Quoted: 199 Post(s)
Liked: 110
Yes, Zenith holds the patents.. or did..
Bob
