Closed Circuit HDMI solution? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-27-2010, 03:58 PM - Thread Starter
lancewynn's Avatar
Hello,
I am trying to figure out how I can instal 4 LCD screens in various parts of an office, each will display a scoreboard, and they will all display the same image. The scoreboard is supplied by a PC with an HDMI output. The max distance from the PC to the farthest screen will be roughly 80' maybe as much as 100' but should not be more than that. All the screens are 1920x1080 and it would be nice if I could keep that resolution
I have been researching HDMI splitters, but it some folks were saying they may not work, or are a bit flaky, and I am not sure how long the cables can actually be. I am also wondering if HDMI to Component, Coax is a viable option.
I wonder if anyone here has any experience with this type of scenario, and can offer some guidance.
Thanks in advance
Lance
lancewynn is offline
post #2 of 6 Old 05-27-2010, 05:09 PM
bdfox18doe's Avatar
Quoted: 241 Post(s)
Liked: 135
yea, take a look at the HDMI splitter devices over at monoprice-dot-com. I have used them in a similar manner with good results. You can also read the reviews.
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #3 of 6 Old 05-27-2010, 06:27 PM - Thread Starter
lancewynn's Avatar
Unfortunately it looks like they are all out of stock, but at least I have an idea of what to search for.
Thanks again for responding.
post #4 of 6 Old 05-27-2010, 06:38 PM - Thread Starter
lancewynn's Avatar
Ok, I found these little mini receivers.
siig-dot-com /ViewProduct.aspx?pn=CE-H20211-S1
they are on sale at Amazon for $28. Can I place one of these on both ends of a Cat5 cable, with an aplified splitter like this:
amazon-dot-com /4-Port-1x4-HDMI-Splitter-Certified/dp/B0012N1YDG
so I'd have 8 receivers and one 4 port splitter, would this work at all? It seems like all the solutions I am seeing are in the $200 plus range, and this seems pretty cheap, so I wonder if it is because it will not work...
post #5 of 6 Old 05-28-2010, 06:44 AM
ndoggac's Avatar
try searching google shopping for "hdmi distribution" sans quotes.
One Model came up Accell UltraAV 4x8 HDMI distribution for $166.
You can also get fairly inexpensive long runs of HDMI at
http://www.monoprice.com/products/su...02&cp_id=10240
Hit CNTRL+F and search for 50ft, 75ft and so on...
You may want to read this as well.
http://www.bluejeanscable.com/articl...n-hdmi-run.htm
ndoggac is offline
post #6 of 6 Old 05-28-2010, 08:53 AM - Thread Starter
lancewynn's Avatar
Thanks for all the input, I ended up going with a product from this site http://www.hdtvsupply.com/hdmi-splitter-over-cat5.html it does the HDMI to Cat5, and includes 8 powered receivers. It's more than I need, but if we ever want to upgrade to more screens, then hopefully it will support it. Also, I have plenty of Cat5 cabling around.
I'll post back in a couple weeks when I get everything setup and let you all know how it went.
Thanks a ton for all the help!
Lance
Reply HDTV Technical
