External QAM tuner for a monitor? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-27-2010, 05:28 AM - Thread Starter
Soygen's Avatar
Hi guys,
I have a 42" 1080p Westinghouse monitor(no tuner). I currently have basic Comcast television along with their fast internet(20mb). Are there any boxes that will allow me to hook it up to my monitor and watch the decent handful of clear qam channels that Comcast broadcasts? DVI or HDMI outputs preferred. I tried Google'ing, but I'm not sure exactly the terms I should be searching. External QAM tuner doesn't seem to be it.
Specific model suggestions would be appreciated. Thanks.
Soygen is offline
post #2 of 8 Old 06-27-2010, 07:01 AM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
Or check out KenH's sticky thread. The Centronics Zat502 seems to be the most popular HD QAM tuner.
http://www.avsforum.com/avs-vb/showthread.php?t=179095
jjeff is offline
post #3 of 8 Old 06-27-2010, 01:23 PM
DAP
DAP's Avatar
Also consider a computer with a clear QAM tuner. Might even be cheaper if you have a computer already.
DAP is offline
post #4 of 8 Old 06-27-2010, 01:39 PM
Ken H's Avatar
Originally Posted by DAP View Post
Also conceder a computer with a clear QAM tuner. Might even be cheaper if you have a computer already.
That's a good idea.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #5 of 8 Old 06-27-2010, 02:27 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
That's only a good idea until you consider the power drawn by the pc just to run that little tuner card to watch tv..
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #6 of 8 Old 06-27-2010, 06:01 PM
Ken H's Avatar
Would it be that much more than a standalone DTV tuner?
Well, at least the PC would provide DVR function.
Ken H is offline
post #7 of 8 Old 06-28-2010, 02:57 PM
DAP
DAP's Avatar
Yes. the Centronics ZAT 502 HD uses about 10 Watts, a computer may use several hundred.
The trade off is that the Centronics ZAT 502 HD will only do live TV, it has no PVR functionality. Almost any computer setup will have PVR features. Also look at the cost of electricity, and how much TV you watch. Figure out exactly how much the extra power will cost you before you dismiss it.
DAP is offline
post #8 of 8 Old 06-28-2010, 03:41 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
Yea, but after having Tivo since day one I find a lot of PC DVR's lacking..that's why I record OTA via the PC, with a mapped network drive to my Popcorn Hour for playback. Which is really hogging the power..
Bob
Reply HDTV Technical
