WQXR: Reduced TX Power - Which Antenna? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 07-19-2010, 07:35 PM - Thread Starter
ota.dt.man's Avatar
I checked with Ken H about which AVS forum would be most appropriate for this question and he suggested HDTV Technical since it is a reception issue:
A family member lives 40 miles LOS from WQXR FM (NYC). She enjoyed listening to it for many years. However, all that changed on July 14, 2009:
WQXR has less range and population coverage on 105.9 than it had with its old signal on 96.3. WQXR's old and new signals both radiate from the same FM master antenna atop the the Empire State Building; but while WQXR's old signal (now WCAA's) is 6,000 watts ERP (effective radiated power -- the energy concentrated toward the horizon), its new signal (WCAA's old one) is 600 watts. The calculated signal strength of the new signal at 30 miles (covering about 14.5 million people) is the same as the old 96.3 FM signal at 42 miles (covering about 17.1 million people).
FM Fool WQXR analog reception results:
  • 105.9
  • 0.6 kW
  • Signal RX: -69.4 dBM
  • 26.7 Ft AGL LOS
  • Rank order: #41 out of 65 total stations
They currently have a rooftop omni-directional turnstile antenna similar to the CM-3026, which is no longer able to receive WQXR due to its reduction in power from 6000 to 600 watts.
Which directional rooftop FM antenna will allow them to reliably receive WQXR?
Broadcast TV - a vital national public resource
Just say "no" to a never-ending subscription TV bill that increases faster than the rate of inflation.
ota.dt.man is offline
post #2 of 17 Old 07-19-2010, 07:43 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
have they tried this?
http://www.wqxr.org/audio/help/
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #3 of 17 Old 07-19-2010, 07:49 PM
Kal Rubinson's Avatar
Quoted: 679 Post(s)
Liked: 461
I did, even though signal strength is still more than adequate at my apartment and at my office. But once you get that far, who needs WQXR? Not only did they change their frequency and power, they have further diluted their program content and increased the inanity of their announcers. The Internet is filled with dozens and dozens of better classical music stations.
Kal (who grew up with WQXR)
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #4 of 17 Old 07-19-2010, 07:54 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
oh, believe me I get that..sad to say OTA radio is dead IMHO..
Bob
post #5 of 17 Old 07-19-2010, 09:00 PM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
This antenna has worked well for me down to around -80dbm.
Digital Rules is offline
post #6 of 17 Old 07-19-2010, 10:21 PM - Thread Starter
ota.dt.man's Avatar
Hi Kal,
Thanks for the update on WQXR's 105.9 programming. Sounds like they may no longer be worth the reception effort. Can you recommend a classical music station in the NYC / NJ metro area that is most similar to the previous 96.3 WQXR?
post #7 of 17 Old 07-19-2010, 10:26 PM - Thread Starter
ota.dt.man's Avatar
Thanks for the FM6 recommendation - a cost-effective solution for FM fringe reception.
post #8 of 17 Old 07-20-2010, 08:05 AM
Quoted: 679 Post(s)
Liked: 461
Hi Kal,
Nope. That's why I now rely on Internet radio. Of course, your family member may actually like what they have done as their blog seems to indicate that many do. My bias is for less talk (especially if it is insipid and irrelevant) and more non-repetitious music. Others may differ.
Kal Rubinson
post #9 of 17 Old 07-20-2010, 08:47 AM - Thread Starter
ota.dt.man's Avatar
Hi Kal,
Less talk and more non-repetitious music sounds like a great combination. Which classical station in the NYC / NJ metro area comes closest to this ideal? They're currently have dial-up and their internet is limited to one room. The internet audio isn't connected to all the main living areas like their FM receiver.
post #10 of 17 Old 07-20-2010, 08:55 AM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 157
In addition to the Antennacraft there is three models from Winegard. I used a Channel Master 4408 for many years, unfortunately, it has been discontinued.
I solved my fixed and mobile radio reception problem several years ago with Sirius XM , no fades or flutters (picket fence effect) no matter where I go in the CONUS (except tunnels). For serious listening I still use the old CDs.
Wendell R. Breland is online now
post #11 of 17 Old 07-20-2010, 02:42 PM - Thread Starter
ota.dt.man's Avatar
Hi Wendell,
Thanks for the Winegard suggestion & link.
post #12 of 17 Old 07-20-2010, 02:46 PM - Thread Starter
ota.dt.man's Avatar
Kal,
Is there an FM station in the Philadelphia metro area that is most similar to the original 96.3 WQXR?
post #13 of 17 Old 07-20-2010, 04:15 PM
Quoted: 679 Post(s)
Liked: 461
Hi Kal,
None. There are only two, afaik: WQXR and Q2, their internet-only modern music station. The latter has less jibber-jabber but is not really a mainstream music station.
Kal Rubinson
post #14 of 17 Old 07-20-2010, 04:16 PM
Quoted: 679 Post(s)
Liked: 461
Dunno. Never stayed in Philadelphia long enough to find out. Mebbe I will in the future as my granddaughter just started grad school there.
Kal Rubinson
post #15 of 17 Old 07-20-2010, 04:51 PM - Thread Starter
ota.dt.man's Avatar
Thanks Kal. Please let us know if you decide to x-mit out of Philly.
post #16 of 17 Old 07-20-2010, 09:34 PM
Quoted: 679 Post(s)
Liked: 461
Cute. My next transmission will be from St. Louis.
Kal Rubinson
post #17 of 17 Old 07-20-2010, 11:41 PM
AntAltMike's Avatar
Quoted: 130 Post(s)
Liked: 62
I drove through Philly about three years ago, using the Sscan" feature on my car radio, and found that three radio stations were playing Billy Joel songs at the same time.
AntAltMike is offline
Reply HDTV Technical
