Help for Verizon FIOS newbie. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-02-2010, 12:35 PM - Thread Starter
JustBusiness's Avatar
Quoted: 43 Post(s)
I haven't seen any recent discussion on FIOStv, so I thought I would make a fresh topic.
Situation: I am moving in to a new apartment building that is prewired for Verizon Fios (in East Amherst, NY 14051). I have never operated FIOS, or seen FIOS picture.
Questions:
1). What are the most up to date set top boxes?
2). Do the channels offer surround sound? 7.1? Is there a list of which channels offer surround sound?
3). Will I encounter any problems when streaming video and audio through HDMI to my Pioneer VSX-21TXH?
4.) Can I plug a hard wired ethernet cable from the router in to an 8 port switch? Is there a brand that works best with the fios receiver?
4). Is there any other must know information?
Thanks for everyone's help. Verizon's customer support/tech support hasn't been much help.
JustBusiness is offline
post #2 of 2 Old 08-02-2010, 12:49 PM
mjones73's Avatar
1) Not sure
2) Yes most channels broadcasting in HD offer DD surround, 5.1 max.
3) You shouldn't.
4) Yes, any ethernet switch will work, just plug it into one of the switch ports on the supplied router/access point
5) Good thread full of info - http://www.avsforum.com/avs-vb/showt...highlight=fios
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
Reply HDTV Technical
