Delano, MN: Outdoor antenna recommendation please - AVS Forum | Home Theater Discussions And Reviews
Old 08-06-2010, 06:36 AM - Thread Starter
srj45's Avatar
Hello,
I am looking for an antenna to supplement my Dish service. I have no knowledge of antennas and after reading over numerous posts here I am still left wondering what to purchase. If anyone could kindly recommend which antenna to get it would be greatly appreciated. I am really only looking to get the "yellow" section of channels but if anything in addition would be welcomed. I plan on roof mounting the antenna. Is there anything out there for ~$50?
http://www.tvfool.com/?option=com_wr...9fbeff48363271
Thanks in advance,
Sean
Fixed link. Thanks BCF68
srj45 is offline
Old 08-06-2010, 07:57 AM
BCF68's Avatar
your TVfool link is messed up.
BCF68 is offline
Old 08-06-2010, 08:53 AM - Thread Starter
srj45's Avatar
Does anybody know anything about this antenna?
http://www.amazon.com/Channel-DIGITA...1106234&sr=8-4
srj45 is offline
Old 08-06-2010, 12:11 PM
BCF68's Avatar
BCF68 is offline
Old 08-06-2010, 09:23 PM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
I wouldn't get anything less than the Winegard 7694 with those signal strengths given that price range. The CM 2016 doesn't even come close in comparison.
Digital Rules is offline
Old 08-07-2010, 08:20 AM
arxaw's Avatar
srj,
You don't need to post your antenna questions in multiple threads. Antennas suitable for your TVFool results were posted in the Official AVS antenna topic thread.
arxaw is offline
Old 08-07-2010, 02:15 PM - Thread Starter
srj45's Avatar
Originally Posted by arxaw View Post
srj,
My apologies. I just wanted to see if this thread (since it was more visible) would get more responses or different recommendations then my other my question in the antenna thread. I will go with the winegard. Thanks everyone who responded.
Sean
srj45 is offline
Old 08-11-2010, 04:32 PM
Rick_R's Avatar
I use the Winegard 7015 UHF/VHF antenna available at solidsignal.com for $37.99. A pretty good antenna for a good price. Its VHF is outstanding and its UHF is pretty good.
Rick R
Rick_R is offline
