Weird Image On Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-08-2010, 07:42 AM - Thread Starter
stanld's Avatar
Need help on identifying the attached image on my Toshiba 42HP66 screen. I have a Comcast 8300 Atlantic cable box and use a Harmony 650 remote to one button watch HDTV TV. No problem in watching DVDs. The cable company blames the remote settings and Logitec says its the cable box. I can eliminate the problem by rebooting the cable box or switch my remote to watch a DVD and then watch HDTV.
Anybody in AV land witnessed an image like the one attached and what can one do to eliminate the problem Thanks in advance for any help anyone can provide me.
stanld
stanld is offline
post #2 of 3 Old 08-08-2010, 09:31 AM
Jim Shaffer's Avatar
Full-page closed captioning (stream 2 or beyond) turned on? (Just a guess, I have no idea whether digital TV provides the same CC options as analog.)
Jim Shaffer is offline
post #3 of 3 Old 08-08-2010, 09:43 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1029
Do you have the problem if you only use the Tosh remote and/or the SA remote?
If not, it's probably the Harmony remote.
Ratman is offline
Reply HDTV Technical
