Problems with New Comcast Box & TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-01-2010, 05:26 PM - Thread Starter
BigWorm50's Avatar
Can anyone help me with this: I have a 32" Sharp Aquos HDTV with Comcast cable connected with a HDMI cable. I had an old Mortorola HD Box that outputted 1080i to my tv, which is 1080p/i. The picture was awesome, until my DVR stop working so Comcast switched to their new Mortorola HD Box. Now only the 480i signal output works, and the picture does not look as good, especially the colors. I've tried switching to 720p and 1080i but the picture gets really fuzzy & distorted. Why did I get a great picture with the old box & can't get the new box to work properly?
I also get this message on my tv that it is "receiving audio signal (now)". What does this mean? I never received this message before.
BigWorm50 is offline
post #2 of 4 Old 11-01-2010, 08:12 PM
txrose's Avatar
Originally Posted by BigWorm50 View Post
Can anyone help me with this: I have a 32" Sharp Aquos HDTV with Comcast cable connected with a HDMI cable. I had an old Mortorola HD Box that outputted 1080i to my TV, which is 1080p/i. The picture was awesome, until my DVR stop working so Comcast switched to their new Mortorola HD Box. Now only the 480i signal output works, and the picture does not look as good, especially the colors. I've tried switching to 720p and 1080i but the picture gets really fuzzy & distorted. Why did I get a great picture with the old box & can't get the new box to work properly?
I also get this message on my TV that it is "receiving audio signal (now)". What does this mean? I never received this message before.
Help us understand your problem.
" Now only the 480i signal output works, and the picture does not look as good, especially the colors. I've tried switching to 720p and 1080i but the picture gets really fuzzy & distorted. "
Do you mean the STB (Motorola DVR) only outputs 480i (as displayed on the STB and set)? What did you switch to 720p and 1080i? The set, the STB or something else?
I can't guess what the audio error message means.
Just trying to help.
If it isn't 720p or 1080i/p it isn't HD. If it is 720p or 1080i/p it may not be HD content.
txrose is offline
post #3 of 4 Old 11-02-2010, 07:11 AM
McDonoughDawg's Avatar
Quoted: 22 Post(s)
Liked: 35
On the surface of it, sounds like you got a bad box..it happens.
Peachtree City Golf Cart Rider
McDonoughDawg is offline
post #4 of 4 Old 11-03-2010, 05:22 AM
CaptMorn2374's Avatar
What box do you have now and what cable is used, hdmi? It could be bad box but I've seen some settings affect a fuzzy picture too.
CaptMorn2374 is offline
Reply HDTV Technical
