Screen Blank When Switching Channels (Comcast STB, HDMI) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-07-2011, 08:10 AM - Thread Starter
brianlichter's Avatar
Hello,
I apologize if this is a repeat topic, but I have not been able to find a specific answer on Mitsubishi 265 series TVs
I have a Mitsubishi LT-46265 that I just purchased a month ago. My Comcast HD box is the RNG110. I also have an XBOX 360 hooked up. All connections to the tv are through HDMI.
The problem I have is that when switching channels (perhaps from 720p broadcast to 1080 broadcast), the screen goes black and stays that way. I have to change inputs and then change back to get the picture to come back on. The same thing happens when I am watching Netflix through my XBOX 360. When I exit out of a program, the screen goes blank until I do the input switch.
I tried upgrading my HDMI cables to version 1.4 with no success. I thought it was simply an issue of the speed with which the TV recognizes the resolution switch.
Mitsubishi also replaced the TV last week and the brand new one has the same problem.
Are there any settings on the cable box or TV I can change to stop the blank screens? For $2000, I do not want to put up with this annoyance.
Any help would be greatly appreciated.
brianlichter is offline
post #2 of 7 Old 01-07-2011, 08:32 AM
Ratman's Avatar
Quoted: 1247 Post(s)
Liked: 1002
Try setting the cable box to "fixed" 1080i video output.
Ratman is offline
post #3 of 7 Old 01-07-2011, 08:34 AM - Thread Starter
I will try that. Thank you.
post #4 of 7 Old 01-07-2011, 08:42 AM
walford's Avatar
Does the problem only occur when the resolution of the input changes on the different HDMI sources you are using (one for Comcast and a different one for the XBOX)?
Do you have other devieces between the Comcast box or the XBOx and the TV such as receiver, swtch or splitter?
walford is offline
post #5 of 7 Old 01-07-2011, 08:50 AM - Thread Starter
No - all devices are hooked directly into the TV.
post #6 of 7 Old 01-07-2011, 01:29 PM
walford's Avatar
You did not say if the problem only occurs on a resolution change?
How long are your HDMI 1.4 or HDMI high speed cables, I don't think they are any part of your problem but I am curious?
walford is offline
post #7 of 7 Old 01-15-2011, 02:15 PM
Troubled's Avatar
Just wanted to let you know that this is a problem I am experiencing also. I have swapped cable boxes, HDMI cables, and have returned the TV once already and the problem still exists. The TV just seems to lose the signal and can't re-acquire it. This does not happen on my other HD TV's (720).
Troubled is offline
Reply HDTV Technical
